Technical Original 1932 Ford frame repair
Discussion in 'Traditional Hot Rods' started by HaroldDegand, Dec 12, 2025.
  1. Hi. I repair an original 32 frame which had a collision. I need some information from jig owners or anyone could help.
    Is there some difference between frames ?
    On the diagram, at the front cross member, I should have 4’’ 7/8 between the bottom of the rail and the baseline. Mine has minder than that. About 1in minder.
    Thanks !
    HemiDeuce and oliver westlund like this.
  2. Mart
    Mart
    Does minder =less?
    All frames should be the same. Looking at the dimensions the height at the top of the rails near the front crossmember should be 1-1/2 inches above the top of the rails in the centre section.
    oliver westlund likes this.
  3. Yes Mart sorry. I ment less
    oliver westlund and Just Gary like this.
  4. I guess its bent
    I’ve got one with the left rail probably 3-4 inches up with a buckle at the cowl
    As soon as we get all the ugly boxing plates removed we will pull it down.
  5. Fordors
    Fordors
  6. Tim
    Tim
    from KCMO
    I would note that it shows that measurement with the belly of the rail “flat” on the ground and the frame horns hanging in the air. I could see sitting it so the horns touch the ground and that would skew that dimension.
  7. The rear horns are 2 1/4
    The front left is 2 1/8 and the right side is about 2 3/8 in.
    The frame is at my workshop, I can only exctly check it on monday.
  8. That’s a nice bench
    used em a few times
    would be super EZ to clamp down on that
  9. RockyMtnWay
    RockyMtnWay
    When I look at that schematic I might wonder if the 4 7/8 is the bottom of the frame or the spring mount height on the bottom of the crossmember.
  10. alchemy
    alchemy
    Harold, the tips of the front horns are higher than standard, but the middle of the arch is lower? That sounds like any bends in the area should be rather extreme, and visible to the eye. Unless the diagram is incorrect as you suspect.
  11. TCTND
    TCTND
    I agree. The way the drawing is laid out suggests that is the dimension to the crossmember, not the frame rail.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The crossmember is its own elevation drawing. Math is required to arrive to it’s own distance from lowest horizontal reference line up.
  13. Mr48chev
    I'd say you need for Krylon32 to see the thread and add his input. He is one of the Hamb 32 Ford Ch***is gurus.
  14. banjorear
    banjorear
    I have a copy of the original blue print. Let me see if I can find it to confirm the diagram mentioned is correct. Give me a little bit
  15. NoSurf
    NoSurf
  16. I asked Krylon32 to help but he said he can’t this time
    NoSurf likes this.
  17. Mr48chev
    I was figuring that he might see something that was not quite right or have a better way of checking.
  18. lamaison
    lamaison
    from Canada
    Here's one put out by Wescott's for what it's worth.
    HemiDeuce likes this.
  19. Corn Fed
    Corn Fed
    When I built my 32 specific frame jig I took measurements from 3 different original frames and compared them to both the Wescott and Cruisin Products drawings. Very few agreed dead nuts. I went with kind of the average, leaning more towards what I got off my frames since I don't know how many frames the drawing creators used.
    Right now I have a pair of new ASC rails in there. The measurement from the bottom of the rails to the center of the front spreader bar bolt is 3 5/8" which almost matches your RH frame horn picture.
    Is that exactly what Henry's designers wanted....IDK. But it's what mine measures.
    NoSurf likes this.
  20. Ok. I took better measurement.
    The kick up on the right side measure 4 7/8 as it should.
    The left one is 4 5/8.
    at the bottom of the left horn, I have 2 1/8
    The right one 2 1/2.
  21. 19Eddy30
    19Eddy30
    from VA
    Another Blue plant drawing I use but I still think it does not help you with the horn height
