Build a bus? Why not?
Discussion in 'The Antiquated' started by iwanaflattie, Oct 2, 2025.
  1. CJ95
    CJ95
    Ok. I am a school bus mechanic professionally. This things cool as ****
    chryslerfan55 and Okie Pete like this.
  2. iwanaflattie
    iwanaflattie
    Like Ice cube said:"today was a good day"
    I finished patching the lower rear structural panel,and stared to make a rear p***enger patch panel since the old one was rusted out and smashed.
    I cut it out and told my self I'd figure out how to patch it.
    20251027_100003.jpg 20251027_100014.jpg 20251027_123335.jpg 20251027_145027.jpg 20251027_145053.jpg 20251027_145103.jpg 20251027_145116.jpg 20251027_154853.jpg
    Since we're working on the rear,I was going to cut the p***enger lower skirt since it was all ****ed up by the forklift.
    If you ever straightened 16 ga panels,you might know the pain and suffering I endured for a couple hours.
    I had to get 4 of my heaviest dollies and one of my biggest hammers tob"sorta" get this stupid panel looking decent.
    That was a pain in the *** and I don't think the neighbors enjoyed it at all... we all need to move forward tho,no time for thinking just doing. 20251027_155634.jpg 20251027_160718.jpg 20251027_165848.jpg 20251027_165852.jpg 20251027_165905.jpg 20251027_165913.jpg 20251027_170459.jpg 20251027_170453.jpg 20251027_170536.jpg 20251027_170544.jpg 20251027_170619.jpg 20251027_170654.jpg 20251027_172917.jpg 20251027_173446.jpg 20251027_173824.jpg
  3. iwanaflattie
    iwanaflattie
    I think Harv has the answer..most likely a big crucible.
    I think that's what It is.
    Nice..how do you like your job?
  4. CJ95
    CJ95
    I love when I do
  5. iwanaflattie
    iwanaflattie
  6. Okie Pete
    Okie Pete
    Will the rear tires be behind the body with a flatbed or utility bed ?
  7. Okie Pete
    Okie Pete
    Neighbor had an IH truck that was a short box body with a 6 ‘ flatbed. I think it was a Railroad truck at one time. He has a custom haying service. He used it to pull equipment with and stored tools , oil , twine and repairs in the box . Fuel tank was on the flatbed
    chryslerfan55 and down-the-road like this.
  8. iwanaflattie
    iwanaflattie
    Haha that's a funny visual but no,I've seen what you're talking about..
    We 86'd the wheel opening.im going to create my own with a smaller radius
  9. iwanaflattie
    iwanaflattie
    Now a question for the sheet metal gurus..
    I need to reduce the radius on this wheel arch trim..
    Is a bunch of metal work involved? Or basic section 4 pieces and weld together..??
  10. hotrodjack33
    hotrodjack33
    Why not build pseudo fenders similar to @anthony myrick 's bus and make the radius any size you want.
  11. Id section that wheel lip after I had it on a ch***is with its wheels.
    Them modify to fit
  12. Okie Pete
    Okie Pete
    After all the metal that you have hammered back into shape and made new again. A couple wheel moldings will be a piece of cake . Find a pair of the 48-52 Ford rear fenders and cut the side off . Then use the wheel radius.
  13. Okie Pete
    Okie Pete
    How’s progress on the bus ?
  14. iwanaflattie
    iwanaflattie
    We got rained on for a while..project stalled so I worked on something else..I made a deal for a clean front end off an f5 in Az,the guy ghosted me and pulled the ad a few days before i was supposed to go
  15. Okie Pete
    Okie Pete
    Dang it
    Don’t know why people do that .
    chryslerfan55 and porkshop like this.
  16. iwanaflattie
    iwanaflattie
    Yeah..it would've been perfect,,it had the same paint as mine.
    Oh well.
    I started taking the front clip apart after i moved the entire bus a bit so i could get the 37 ford next to it.
    The Driver side fender is way too far gone as is the hood.
    Ive been searching for a front clip with no luck.
    I found an f1 clip that someone welded it together for a tilt front end.
    I hope the welds are bad so i can take it apart easily.
    20251129_144617.jpg 20251129_144626.jpg 20251129_144559.jpg 20251129_144551.jpg 20251129_144602.jpg 20251129_144548.jpg Screenshot_20251130_083637_Facebook.jpg Screenshot_20251130_083646_Facebook.jpg
  17. iwanaflattie
    iwanaflattie
    Boys.
    I have a dilema I need your help deciding.
    One piece Front clip that is all welded,i dont know how easy is going to be to separate all the piece,idk how much bondo there is under all the paint, i have to drive 90 mins to go get it and pay extra for the trim.
    Pros: smaller wheel opening,looks to be pretty straight.
    He wants 400.00
    Or
    A whole f5 truck with flathead that can be delivered to me for 1k.
    Cons.
    Its a big ******* and i barely have the room for,its going to create more work.
    Big wheel opening
    Pros.
    Has ***le,i can sell everything else and make my money back(eventually),i could use the frame..
    It would look stock without the street rodder look and it would have the correct trim and wheel opening for the F5 bus.
    Screenshot_20251203_041758_Facebook.jpg Screenshot_20251203_041806_Facebook.jpg Screenshot_20251203_041755_Facebook.jpg
  18. RMR&C
    RMR&C
    from NW Montana
    Kinda depends on what ch***is you are using. That front clip is full of bondo at the seams, who knows what else is under there. Plus it has a nasty dent in the corner. Could you remove the hood and leave the rest together? BTW I have some hood trim for that if it helps. Cheap.
    The F5 looks really clean. Heavy stuff to work with, parts are hard to find,(like brakes, etc) super low gears and would need new wheels (those are widowmakers) and tires $$$$
    Basically comes down to what you want the bus to be...
    If you don't need that stuff right away, be patient, something better might come along
  19. iwanaflattie
    iwanaflattie
    I need to start taking measurements so can at least have a rolling ch***is.
    Thats why i need the front clip kind of soon.
    So i can bolt it and start on the suspension.
    Yes i figured the f1 front clip would be full of bondo,probably no pretty welds, a couple of dents but better than mine...
    I know the suspension on the f5 is heavy and parts are hard to get i was just thinking of using the frame and bolting the c20 suspension to it like i did on my GMC.
    Theres a lot of s****per out here that would take all the old suspension away for free but it would be a major workout.
    b-bop, chryslerfan55, SS327 and 2 others like this.
  20. RMR&C
    RMR&C
    from NW Montana
    Okay I see where you are going. Be aware the F5 frame is double..... one channel inside another from the firewall back. That's why I said heavy SOB.
    If you have a C20 or C30 ch***is I'd use that and the 1 piece clip
  21. iwanaflattie
    iwanaflattie
    I got a visit from code enforcement,she said "a neighbor complained about cars lookin like they are un operable and a van that is a butcher van"
    After i had a chat with her,i made my mind,i will not buy a truck that will take space and will take lots of work to part out.
    I told the F5 seller i couldn't buy the whole truck for that reason,i offered 700 for the clip and he declined,ok no problem,ill wait.
    I took the day off today because I wanted to pull the flathead to take to Utah to have it worked on and i woke up with a message from the one piece clip seller that he was back in town..
    I told him,yes i want it,ill start heading down to Az to pick it up.
    2 hrs later i was down in Kingman and I couldnt be happier,the front clip is as rust free and as straight as i hoped.
    They did a great job welding the supports to the fenders and they welded the hood to the fenders but they did a great job.
    They left everything in place and filled everything with bondo..not too bad.
    I took a few pics but it gets dark too soon.
    20251212_172758.jpg 20251212_172748.jpg 20251212_151013.jpg 20251212_151004.jpg 20251212_150958.jpg 20251212_150953.jpg
  22. iwanaflattie
    iwanaflattie
    *****azz rain trying to stop me from working on my stuff, and from grilling a couple of ribs.
    I was able to sneak a couple of hours moving some stuff.
    I decided to break the steps of the bus to rebuild them..
    They are rusty but luckily the sides are not that bad.. I got a sheet metal Brake for free,,ill see how it works..once the rain stops.
    I also propped the nose trim that Scott sent.
    I cherish all the parts and all the favors friends do for my builds..thanks again Scott.
    20251224_150056.jpg 20251224_150052.jpg 20251224_103715.jpg 20251224_075733.jpg
  23. leon bee
    leon bee
    Do you ever take days off?
  24. iwanaflattie
    iwanaflattie
    I try not to...stuff doesn't get done if im not out there..im like the usps
  25. iwanaflattie
    iwanaflattie
    Well the bus has been sitting for a second
    .if you follow my other useless threads,ive been working on my 37 ford truck and ive cleaning the backyard so if the city decides to come around,I dont have a junkyard(I wish I did)they only see some type of tax not being paid...what ever.
    As I clean up,I try to get rid of stuff and one of those things was the rusty steps,ive been moving them around for a minute,well today I decided to used them as patterns so I could throw them rusty *** **** away,ill let the pictures tell the story.
    Also I bought a 48 cab to steal the front mounts and firewall since the bus was ****edddd by the seller and his forklift..
    Im not sure what im going to do in the end but im always moving fwd.
    Im going to add some pics of my " diddys lubrication" station as it progresses..
    Btw,I just changed companies after 7 years,im going to work at a government facility for a company and hopefully I'll like the 3 day weekend and 3hr daily drive..
    20260119_125910.jpg 20260119_125913.jpg 20260119_134045.jpg 20260119_144001.jpg 20260119_151044.jpg 20260119_164843.jpg 20260119_164850.jpg 20260119_164857.jpg 20260119_165654.jpg 20260119_165652.jpg 20260119_170626.jpg 20260117_134225.jpg
  26. Greg Rogers
    Greg Rogers
    Great progress!
  27. iwanaflattie
    iwanaflattie
    Not much happening here in Scene city,between the bus,the 37 and not working for a couple of weeks, my wallet is draining FAST!!!
    I finally found an affordable rear end at 160.00,I had the springs from the last 14 bolt i had, i know I have the rear hangers in California but the fuel to go there might be cheaper to source them here..
    I started to take the springs apart to clean and paint..
    I started looking at lowering spindles but they are from 220 bux to 400!!!
    And i need two sets..
    1 to lower the Vanette..
    I still need a MC and booster..
    I quoted your post to ask if you Z'd the frame when you grafted the clip..
    I might end up doing that...
    And panckaking the xmember..
    Tomorrow i might throw the xmember in the pickle juice to start the degrease process.
  28. hotrodjack33
    hotrodjack33
  29. SS327 and down-the-road like this.
  30. Phil P
    Phil P
    He's serious and don't call him Shirley:D.
    Phil
    SS327 and Okie Pete like this.
