Projects 1941 Ford Special, Field Car
Discussion in 'The Hokey Ass Message Board' started by eodcoduto, Nov 30, 2025.
  1. A Y-block to FH trans is not a hard find
    Seen a few nailhead ones
    but my 283 is as period correct as the FH it replaced
  2. I picked these up and sent to a member this summer
    Y-block to “37-48” ford ch***is according to the box
    way different than the Hurst mounts. Bolts to the timing cover and oil pan. Moves the gen above the intake
    LCGarage, porkshop and Okie Pete like this.
  3. Okie Pete
    Okie Pete
    Yes I got them . If your interested in them pm me
    porkshop and anthony myrick like this.
  4. hotrodA
    hotrodA
    Look for this when you get the crud off. See the crack between the valve and the cylinder.
    Came out of my once good running 40 coupe, now with SBC adapted to trans.
    SS327 and eodcoduto like this.
  5. PINEAPPLE
    PINEAPPLE
    If the block is good, and you can find a good 8ba type crank and rods, that would save you money on bearings and time setting up the tricky floater rods. buy mains for block year and rod bearings for the 8ba. I did this on a 40 block in my T roadster. Leave the outside finish in my opinion. It's neato.
    LCGarage, eodcoduto and porkshop like this.
  6. eodcoduto
    eodcoduto
    Its ready to pull but I have to go to a Christmas parade instead. The lifter valley is clean, the mouse houses were all in the exhaust and hot air heater tubing.
  7. rusty valley
    rusty valley
    Thats one of the cleanest I've ever seen! They usually look like a tar pit in there.
    porkshop, Squablow, SS327 and 2 others like this.
  8. patsurf
    patsurf
    buy that ticket!
    eodcoduto likes this.
  9. eodcoduto
    eodcoduto
    Pulled the engine today and got the stuck piston out, the rod bearing came out in multiple pieces but the journal nor the rod are scored. The engine spins now without any stuck valves but the bores are rough. This has a 3 ring dome piston, were these stock?
    I’ll finish teardown this weekend and mic everything to see what the damage is.
    IMG_3745.jpeg IMG_3748.jpeg IMG_3749.jpeg IMG_3750.jpeg IMG_3752.jpeg IMG_3753.jpeg
  10. warhorseracing
    warhorseracing
    from cameron wv
    Yes. Slight rebore new pistons, rings, and bearings, good to go.
    porkshop and eodcoduto like this.
  11. AmishMike
    AmishMike
    Those rings look like went a lot of miles
    porkshop likes this.
  12. kurt varga
    kurt varga
    if the liners are still in the motor knock them out and you have a perfect bore, find the over sized piston that was made to fit that bore and you will be good to go. Look up Barn find 08, fred wilner he may have what you need.
  13. eodcoduto
    eodcoduto
    Its apart minus the valvetrain, I want to order the right tools first. All the rod bearings were broken, the mains are rough but I might be able to save the crank.
    bobss396, Squablow, porkshop and 3 others like this.
  14. warhorseracing
    warhorseracing
    from cameron wv
    Man, what a mess you made! From what can be seen the crank should be OK with a polish or minor cut. Your rebuilder will determine what needs done. The pistons appear to have been hot and will need replaced. Can't really see the rods. At least everything came apart and no broken bolts yet. Are there any visible death blow cracks between the piston and valve surface. If not, still mag them to be sure and check line bore in the crank journals and cam. If everything checks out OK you are in luck.
    eodcoduto and Algoma56 like this.
  15. UpNorthGreg
    UpNorthGreg
    from Backus, MN
    If you need the .0825" over pistons and rings, give me a shout. I have a set that I'm not going to use.
  16. The37Kid
    The37Kid
    Did all 1941 Flathead engines have cylinder sleeves or was this engine rebuilt with them years ago? Nice project.
    Bob
    ClayMart likes this.
  17. warhorseracing
    warhorseracing
    from cameron wv
  18. rusty valley
    rusty valley
    I think in 1940 they all had sleeves, no? The "tin can" motors.
    warbird1 and porkshop like this.
  19. warhorseracing
    warhorseracing
    from cameron wv
    It varied as it was a changeover year of sorts. Henries' folk using everything they had in stock prior to moving on. Later years they were eliminated altogether.
    rusty valley and porkshop like this.
  20. Polara 500
    Polara 500
    from Bagdad
    What an excellent find! My 41business coupe was my favorite & still miss it dearly after 50 years. Per Warhorse, 41 was a transitional year, with some parts / components common to 40 & some common to 42-48. there are also Ch***is, sheetmetal & suspension differences (minor) between 41 & later years. Yours appears to be a very early 41 from what I can see, and being a "standard" likely has some engine parts leftover from 40. If that block isn't cracked you have a great start that can be modified/updated & no need for any other powerplant! My only caution would be to ditch the manifold heater; it isn't worth the risk unless you completely re-do it. 41's also came with hot water heaters (no carbon monoxide hazard). Congratulations & best of luck with will be a super cruiser when it's back on the road!!! I do have some 46 2 door quarter panel sheetmetal and a maybe few useable steering/suspension pieces if you run into a need!
  21. eodcoduto
    eodcoduto
    I still have the 1941 “raised”intake block. And I would like to find whoever designed this lifter system and punch them squarely in the nuts. I had to use a torch on two valves because there was no way they were coming out and the guides crumbled when I tried pulling them. I was going to be cheap, but I’m going to pull the trigger and put the updated one piece valve guides and straight valves in it.
  22. eodcoduto
    eodcoduto
    Machine shops don’t exist in North Alabama anymore. There’s one guy around that I’ve had turn cranks so I’m going to have him check the crank to see if it’s salvageable and then look around to find a shop to hot tank the block and get it checked out.
    porkshop and warhorseracing like this.
  23. Checked with Davis in Tus***bia?
    closest one near me that turns cranks is in Birmingham. Most local machine shops send cranks there. Very few have a crank grinder.
    They took care of a Willys flathead crank for me
  24. eodcoduto
    eodcoduto
    The only one I know of is Hals in Tus***bia. Roger’s in Florence shut down a couple years ago. I’ll give the Birmingham shop a call, its frustrating that I have to drive 2 hours away to find a good shop.
  25. guthriesmith
    guthriesmith
    Man, I feel for you guys. I live in a fairly small town but have a good one man machine shop that does all my work.
  26. We have one. But he doesn’t turn cranks.
  27. Friend of mine just picked up a 401AMC from there.
    Cleaned, 3 sleeves, bored, rods worked, pistons pressed, cam bearings, core plugs, crank turned, hardened exhaust seats, guides, valves worked, springs installed, surfaced
    $1200
  28. guthriesmith
    guthriesmith
    Ah, mine doesn’t either. He sends them to someone else about 30 minutes south.
  29. My local guy will do flatheads but not the valve work.
    porkshop and guthriesmith like this.
  30. @eodcoduto
    Trying to track down a guy in Carbon Hill, north of Jasper.
    Supposed to have a lot of NOS flathead bearings and rings. Other parts as well
    I’ll post here if I find him
