Featured Hot Rods 35/37 ford truck chassis thread
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Dec 14, 2025.
  1. iwanaflattie
    iwanaflattie
    Gang,
    Im looking for a good thread to build a 35/37 ch***is thread.
    I sent my flathead and 39 trans to get freshened up..
    Id like to start building the frame..
    I have a stock 37 frame but i dont want to cut it up.
    I also have the 37 frame rails,a dropped axle and a 9 that was once attached to said frame.
    Thanks in advance
    Toms Dogs likes this.
  2. AVater
    AVater
    I have pretty much completed my '36 ch***is. I built it for a Y block engine, F150 3 + 1 transmission and parallel leaf rear springs over a 9". The only big cut I made was to take the center box out of the X and replace it with something I fabricated, which I needed to do to accommodate the transmission. I used a '37+ steering box and ch***is mount to get the better easier? steering design.
    Looks like you want to use as '39 transmission, what are you planning for an engine?
  3. stillrunners
    stillrunners
    from dallas
    Seems like that is what I picked up for the flathead - think it's still running a tourqe tube.....have to uncover it and see.
  4. iwanaflattie
    iwanaflattie
    Its a 37 flathead
  5. ***Area-51***
    ***Area-51***
    from Ohio
    Should be same or similar to most 35- 40 ch***is builds.
    What’s you vision look like as a finished pickup?
    If going parallel leafs on rear, I would suggest the Posies setup...
    Any pics of what you have?
  6. iwanaflattie
    iwanaflattie
    My vision is simple,flat head,3 speed,hydraulic brakes,wide 5s or wire wheels,lowered, fenderless(I dont have fenders and cant afford rear fenders)
    Just a local parts getter
    20251214_150247.jpg 20251214_150148.jpg 20251214_150136.jpg 20251214_150018.jpg 20251214_150121.jpg 20251214_103825.jpg 20251214_103820.jpg 20251212_165400.jpg 20250802_093329.jpg 20250802_093322.jpg 20250802_074812.jpg
  7. ***Area-51***
    ***Area-51***
    from Ohio
    Looks to be a straight forward build.
    You might not want parallel rear leafs for a
    fenderless build for cosmetic reasons.
    Outback, Kiwi 4d and guthriesmith like this.
  8. ***Area-51***
    ***Area-51***
    from Ohio
    Ok, went back and re read, not sure why you wouldn’t use you the stock 37 frame.
    Also, do you really need a 9” for that driveline?
  9. I’d keep the stock rear
    building a low slung bobber truck?
  10. iwanaflattie
    iwanaflattie
    Didnt want to call it that..but sorta
  11. iwanaflattie
    iwanaflattie
    Im not shortening the bed
  12. I’d probably stick build one
  13. finn
    finn
    If it’s a local parts hauler, think long and hard about channeling it.
    Those cabs are tiny.
  14. alchemy
    alchemy
    Whatever you do, replace the spring mounts on that rearend. They look like garbage that could snap off with any bump.
  15. iwanaflattie
    iwanaflattie
    Thats my concern,,,,some of the welding on the old frame is not a looker,im kinda wanting to redo and upgrade the work,,im just green on early suspension.
  16. ***Area-51***
    ***Area-51***
    from Ohio
    I thought you were after a stock style ch***is pickup minus fenders.
    Bobber, that’s a different animal.
    Outback likes this.
  17. iwanaflattie
    iwanaflattie
    Im not bobbing the frame nor bed,,stock length just lowered a bit..
    Im looking for ideas on suspension mounts,crossmembers etc
  18. AVater
    AVater
    Outback and ***Area-51*** like this.
  19. uncle buck
    uncle buck
    "Bobber" Area-51 is referring to is a term often used for low fenderless pickups.
    Ditch that unsafe welded looking rear end and find a stock 35-40 rear or you are going to have to convert that 39 trans to open drive also. As mentioned, flatten the rear crossmember if you want it low
    lothiandon1940 and ***Area-51*** like this.
  20. alchemy
    alchemy
    If you are going to use a 9 inch, no use going through the extra struggle and expense of the’39 trans. The “hidden” stuff could be more modern and tougher.
    If you are going full bore vintage, you might want to research the style that pickups were built back then.
    ***Area-51*** and anthony myrick like this.
  21. iwanaflattie
    iwanaflattie
    I stand corrected. i didnt know that.
    I have 2 frames and i need to decide wich one to use thats why i want to see some ideas.
    Outback, Toms Dogs and ***Area-51*** like this.
  22. iwanaflattie
    iwanaflattie
    Ill do some research..I know theres better transmissions out there,i have a t5 on my model t,i love it....just want to use what i have thanks..
    Sadly all the older threads have issues with pictures,,
    ***Area-51*** likes this.
  23. alchemy
    alchemy
    Use what you have to save money? Not if you need to buy conversion kits to adapt the non-matching parts.
  24. iwanaflattie
    iwanaflattie
    I do value your input and i read all your posts and threads,you're one of my favorite members to look for early stuff,i dont know if im not clear,,i have a 1937 frame and
    Running gear(flathead,39 ******,37 sock ibeam, unsplit wishbone,37 banjo with all mechanical brakes,1947 truck hydraulic backing plates) and I have a 1937 butchered frame with a dropped axle,disc brakes,9" rear end,all the linkage,just trying to decide wich one to use.
    Thanks in advace
  25. A 41-53 ish truck 3 speed would have the slip yoke. I’m currently piecing together an A beater.
    I’ve located a 41-47 truck banjo and a top shift truck slip yoke trans. If I go flathead.
    The trans, rear plus the 41-47 front axle (can’t use the front axle) have 4 nice 16 inch steelies and juice brakes. All way cheaper than an open diff/trans conversion
  26. AVater
    AVater
    Looks like you have the makings of a good start for a shop truck. Based on what you’ve shared: decent ‘37 frame, engine, front suspension, rear end and ‘39 transmission. Sounds like you have hydraulic brake parts but will need pedal set from something like a ‘39 Ford. Maybe a set of radius rods for the rear?
  27. ***Area-51***
    ***Area-51***
    from Ohio
    Some great advice for success here...
    Outback, iwanaflattie and Toms Dogs like this.
  28. Toms Dogs
    Toms Dogs
    from NJ
  29. alchemy
    alchemy
    Personally, I’d use all the old stuff. If I wanted the truck lower I’d use traditional methods. But nothing drastic. Course, I can’t picture a good looking traditional 37 truck without fenders.
  30. 51504bat
    51504bat
