Technical V-belt / Pulley Engagement enough??
Discussion in 'The Hokey Ass Message Board' started by TagMan, Dec 7, 2025.
  1. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Tagman.......Why do you want your alternator sitting that high in front ? The whole engine would look better if you mount it lower and to the side, and it would solve your contact area problem as well. It just looks odd sticking up like that. :)
  2. 19Eddy30
    19Eddy30
    from VA
    This is a small illustration/list..
    Just for Reference and understanding because I'm not a good communicator look at all the different specs on these alternators how much amps they put out at idle , pulley ratios , Charge wire size and also starters for how much compression engine has which starter do you use.
    I think a lot of this information will kind of shock or change your way of thinking.
    IMG_4555.jpeg IMG_4560.png IMG_4557.png IMG_4558.png IMG_4559.png IMG_4561.png IMG_4556.png IMG_4553.jpeg IMG_4554.jpeg IMG_4552.jpeg IMG_4551.jpeg
  3. I failed to mention, I did not have an engine-driven fan, I ran an electric. I can't imagine trying to spin a fan and water pump with almost zero belt contact.
  4. 19Eddy30
    19Eddy30
    from VA
    Previous pic 427 ,
    It does work if match correct pulleys & belt Not even deep grove ,most my engine combo's Are 406 to 434 ,
    6k to 7,200
  5. TagMan
    TagMan
    Just working now with what came with car. I'm mocking up a different adjusting arm that will allow the alternator to lay over to the valve cover more and see if that works. If not, I'll start over from scratch.
    Thanks for all your inputs!
    SS327 likes this.
  6. Hahaha, love this. I always tell my wife, when she doesn't understand something I am trying to explain to her, that I will repeat my explanation one more time only LOUDER, maybe then she'll get it. Based on my confession, I believe that I too may not be a good communicator :D
    alanp561 likes this.
