Technical Cable adjustable flathead ford timing
Discussion in 'Traditional Hot Rods' started by Ryan, Dec 16, 2025.
  1. Ryan
    Ryan
    ADMINISTRATOR
    Alright fellas, this is not for me, it is for a friend who is deep in the weeds and needs reference photos before he starts cutting, drilling, and regretting things.
    I have seen this setup a handful of times, just enough to know it is real, and just enough to be driven insane by the fact that I cannot find a single clear photo of it now.
    Here is what we are looking for. A crab distributor mounted on an indexing plate, with a cable system that runs to the ****pit so the driver can reach down and bump the timing from the seat.
    Anybody have images of one, or a link, or even a photo out of an old magazine. My first p*** at searching turned up nothing but ghosts.
    LCGarage, Toms Dogs, Stogy and 4 others like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    jet996, LCGarage, Ned Ludd and 9 others like this.
  3. banjorear
    banjorear
    Ryan:
    One of the early versions of the Kong Championship distributor is set-up this way. I unfortunately don't have any info on it, but hopefully someone does.
    Stogy and lurker mick like this.
  4. Ryan
    Ryan
    ADMINISTRATOR
    Yes! And I know I've seen homemade versions of the same...
    Stogy and Outback like this.
  5. banjorear
    banjorear
    I'm really interested in what you uncover. I'm trying to envision a timing plate being loose enough to allow it to move without it being so loose that the timing becomes erratic. I'm envisioning it's moving the point plate inside the housing.
    Ned Ludd, Stogy and tractorguy like this.
  6. Dan Timberlake
    Dan Timberlake
    The star wheel micro adjuster is a good feature.
    Stogy and VANDENPLAS like this.
  7. Ryan
    Ryan
    ADMINISTRATOR
    So the distributor was mounted to the lead plate with locking nuts just tight enough to allow the distributor to rotate and the cable went from the distributor to a bracket mounted on a timing plate bolt, through the firewall, and to a bracket under the dash. I remember the cable having some sort of a locking mechanism.
    Yeah, that is cool.
    Stogy, porkshop and Outback like this.
  8. banjorear
    banjorear
    Neato.
    porkshop likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
  10. DDDenny
    Pardon my OT intrusion..........while you're looking, I've been trying for some time to find a magazine article that shows a flathead powered car with a crank/cable affair to drive a remotely mounted ?generator? under the car, I don't even own a flatty but it has eluded me for a long time.
    Preciate it.
    Stogy, porkshop and VANDENPLAS like this.
    Picturing something like a screw jack , used by machinists to make infinite adjustments.
    if the screw portion was hollow , distributor shaft drops through , and with a lever or thumb screw in the ****pit .
    you would need something resembling a geared “ pump” or the likes as with the distributor mounted up front a cable would be the only way to adjust it, would need something in place to keep it “ locked in”
    Toms Dogs, porkshop and tractorguy like this.
  12. Jay McDonald
    Jay McDonald
    My dad talked about doing that on his modified stock car back in the 50s, said you could bump the timing for a couple laps and it would get hot and have to back in down again.
    Stogy, porkshop and tractorguy like this.
  13. RodStRace
    RodStRace
    That screw jack is pretty and would probably be very accurate. I could se just a morse cable with a small wheel handle under the dash and a screw on the other end attached to an arm on the Dist.
    In all but the absolute sharp edge, it would simply need to swing 10-15 degrees and a degree or 2 of slop would be fine enough.
  14. Ziggster
    Ziggster
    Not too much help, but ChatGPT referenced this link when I asked this question:
    “Kong Championship adjustable distributor for Ford 59A flathead”
    There isn’t a modern production “Kong Championship adjustable distributor” that you can simply buy new for a Ford 59A Flathead V8 — what Kong distributors were are historic hot-rod parts from the 1940s–50s built by Charles “Kong” Jackson, often with dual points and an external cable-type timing control that allowed the driver to manually advance/retard timing from a knob or cable at the firewall. These are very rare collectible pieces today, not current aftermarket production items. Fuel Curve+1
    What the Original Kong Distributors Were
    • Kong Jackson was an early hot-rod parts maker who built ignition distributors with dual points and cable advance for flathead Fords and other engines. These offered more control than stock units and were used in dry-lake and early race applications. Fuel Curve
    • These units are collector pieces today and occasionally show up in the vintage parts market or on sites like eBay but are not actively manufactured now. Facebook
    https://fuelcurve.com/kong-jackson/
  15. Moriarity
    Moriarity
    SUPER MODERATOR
  16. leon bee
    leon bee
    No help from me, but I have an old English motorcycle with a magneto and advance/retard lever. I love being able to change timing a little. My HD XLCH Sportster, too, but was always in a hurry back in those days.
  17. alanp561
    alanp561
    Came stock from the factory and worked really well on Knuckle and Panhead Harleys, but we were moving the whole distributor
    hook00pad, Stogy, tractorguy and 4 others like this.
  18. Outback
    Outback
    from NE Vic, Oz
    The cycle car I've been working on moves the cam's for the points in the magneto to adjust the timing. The cam's ring is on the outside of the points not the shaft like normal Dizzy's - the points spin with the armature.
    But probably no help if you are looking for a specific item. Can get photos at work tomorrow if needed. (Dinner time now)
    Stogy, tractorguy and porkshop like this.
  19. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    jet996, Stogy, Outback and 2 others like this.
  20. Oneball
    Oneball
    If it’s a modified part rather than aftermarket. I wonder if they used a Lucas V8 Pilot distributor.
    jet996, Stogy, Outback and 1 other person like this.
  21. 19Eddy30
    19Eddy30
    from VA
    Are you or you friend looking for a vintage Performance made part
    Or Ideal how to do ?
    I would use a fine tooth clamp on housing with worm gear , Turn nob with resistance so you could feel pretty much each degree ,, would only need
    1- 14 teeth 1 tooth per deg & few extra for worm gear to max ,,, Have not did the math just given an ideal.
    Or same way thinking on inside just on points plate , more micro gear ,
    Or Lever Soild SS wire with notches measured out per 1 deg per notch ..
    alanp561 and Outback like this.
  22. Ziggster
    Ziggster
    Toms Dogs, Stogy, Outback and 2 others like this.
  23. Ziggster
    Ziggster
  24. Ziggster
    Ziggster
  25. 19Eddy30
    19Eddy30
    from VA
    You could also machine just cap & mounting plate / flange in way with use of band clamp or other so you could just turn cap only , & add torsion bearing l
    Slid /roll easy .
    Just curious are you looking for just around 10 deg's + or - ?
    Stogy and porkshop like this.
  26. Oneball
    Oneball
    Top 2 are Kong, bottom Meyer. You can see the attachment point for the Bowden cable on the body. IMG_0738.jpeg IMG_0736.jpeg View attachment 6598305 IMG_0739.jpeg
    StrickV8, Toms Dogs, Stogy and 3 others like this.
  27. Ryan
    Ryan
    ADMINISTRATOR
    Man... you guys rule. Thank you.
    theHIGHLANDER and Outback like this.
  28. Turning “Cap only “ will NOT change timing period.
    Stogy, Ebbsspeed, Outback and 2 others like this.
  29. 51504bat
    51504bat
    Not the same but years ago Gus in the Model Garage (in Popular Science?) series jury rigged a metal rod from the distributor to inside the car to adjust the timing on an old Cadillac to allow the owner to retard the ignition to allow the old worn our engine to start. Or something like that. But then this was over 60 years ago so the memory is a bit fuzzy.
  30. banjorear
    banjorear
    I wonder if you took the shaft from a helmet distributor, shorten the length that the rotor rides on, then use that in a crab body. With the extended male end with the cam tang, it should provide enough extra length to allow you to make a plate do go around and attach to the point plate and to allow you to adjust it.
    I'm just going off memory and, of course, you would need to measure everything to see if this idea would actually work.
    You would have to machine a new rotor mount at the end of the shaft.
