Technical Advice on deck lid hinges for 1926 roadster
Discussion in 'Traditional Hot Rods' started by five-slot-mag, Dec 15, 2025.
  1. five-slot-mag
    five-slot-mag
    from Illinois
    Looking for advice on some exposed deck lid hinges. When I bought this car the deck lid and body were drilled for hinges mounted at the bottom so the decklid would open rumble seat style. I cannot find what hinges they planned on using. 1936 Plymouth are close. The bolt hole spacing is correct but they're not long enough or flat enough. Instead of trying to figure out what they had used, I'll probably abandon that idea and mount them up top. I have seen people use 49 ford hinges on hot rods and was just looking for ideas on what works in this situation. Thanks for your time!
  2. hotrodA
    hotrodA
    36 Ford humpback two door sedan trunk lid? Maybe.
    Or longer ones. Austin Healey
    flynbrian48 and Deutscher like this.
  3. KevKo
    KevKo
    from Motown
    Any idea how much curve is in the AH hinges?
  4. quickchangeV8
    quickchangeV8
    If this was my roadster I would forget about mounting the hinges on the bottom of the deck lid and mount them on top of the deck lid where they were originally mounted. There is very limited room in a 1926 roadster and quite often the gas tank and battery are mounted in the trunk area. Mounting the hinges on the bottom makes access to the trunk area just an absolute pain and the deck lid would always be in the way. Even trying to get a cooler or a lawn chair in and out of the trunk area wouldn't be all that easy either.
    Just Gary and Stan Back like this.
  5. 3blapcam
    3blapcam
    My buddy used the humpback hinges on his Model A coupe and they looked great! The only issue is they're designed for a very curvy decklid, so he spent time on a belt sander grinding wedges to make up the space between the hinge & lid, but it looked they belonged there. I vote on those hinges... (but those Austin Healey's look pretty slick too!)
    3blap.
  6. 48stude
    48stude
    I just went though this same thing on my T coupe trunk lid that I made. I tried to use Model A roadster hinges. I modified the **** out of them but couldn't get them work, so I started looking at external hinges . I ended up using aluminum hinges for a Mini Cooper Cl***ic. But they spent a lot of time on the belt sander to get them to articulate right. I like them because they're smaller than most that I could find . They are 3 1/2" long. I bought this set used from Eway out of Canada IMG_1470.JPG IMG_1488.JPG
    Just Gary, Deutscher and 3blapcam like this.
  7. hotrodA
    hotrodA
    Not much.
    Deutscher likes this.
  8. Thrif"T"
    Thrif"T"
    I used some off a Triumph tr4 18d0cac9-5fc7-4790-b80d-1ce5072be72a.jpg 805c5488-eba6-4448-8c41-4a59a5d15a0d.jpg
  9. krylon32
    krylon32
    from Nebraska
    AH hinges look good. The 36 hinges were used on the heavy Mullins trailer lids and seem to hold up. My vote goes to the 36 hinges.
    Just Gary likes this.
  10. tombstone
    tombstone
    from sk.canada
    These are 37 Ford sedan …. image000001.jpeg image000000.jpeg image000000.jpeg
  11. mr.chevrolet
    mr.chevrolet
    take your pick. 20170407_145831_resized.jpg trnkHinge1.jpg trnkHinge2.jpg trnkHinge3.jpg trnkHinge4.jpg trnkHinge5.jpg
    -Brent- and 34 GAZ like this.
  12. five-slot-mag
    five-slot-mag
    from Illinois
    willymakeit likes this.
  13. willymakeit
    willymakeit
    This came along in time. Looking for hinges to put on my 27 t coupe.
