Hot Rods How about some love for the T-Bucket?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 9, 2021.
  1. 40ragtopdown
    40ragtopdown
  2. 40ragtopdown
    40ragtopdown
  3. 40ragtopdown
    40ragtopdown
  4. 40ragtopdown
    40ragtopdown
  5. Snicklefritz65
    Snicklefritz65
    from Mass.
    the 'gl*** image'. reportedly the first ever completed fibergl*** t.
    bchctybob and porkshop like this.
  6. RodStRace
    RodStRace
    On another site, a guy has an old Fibergl*** body. The cowl has the dropped edge that could hold insulation for a hood and it has the small back lower sections original Model Ts had.
    Any guesses on who did them this way?
  7. Dave G in Gansevoort
    from Upstate NY
    My Speedway body has the same firewall dropped edge, don’t know if it has the small back lower section. Here is a side view for you to determine
    Stock Racer, Deuces, deadbeat and 6 others like this.
  8. RodStRace
    RodStRace
    The area behind and below the curved back, under the trunk. Yours is mostly hidden by the rear wheel, but they are not there.
    The post at the top of this page, post 5371 with the graphics seems to have the back part, too.
  9. Snicklefritz65
    Snicklefritz65
    from Mass.
    that's an awesome project btw.
    porkshop and RodStRace like this.
  10. RodStRace
    RodStRace
    Yep, he's building a great car. The thread for Whatever is in his signature.
    Snicklefritz65 and porkshop like this.
  11. Snicklefritz65
    Snicklefritz65
    from Mass.
    a few companies did that. my body has it, made by a guy (see his card) in ri off old moulds of unknown origin. last photo is my body when i picked it up.
    Honest-Charley-T-Bucket-fiberglass-body 1966.jpg t body almquist advert 1965.jpg Kellison-T-Bucket-fiberglass-body 1964.jpg
    bondojunkie, Deuces, deadbeat and 7 others like this.
  12. RodStRace
    RodStRace
    @Snicklefritz65 Thank you! I knew there was someone who had some history of these!
    I'll share this with the guy. He said Bird, but that didn't sound right.
    I know a bunch of different people did bodies and it's tough to ID them, but this at least gets closer.
    The Honest Charley shows the lip at the cowl, too.
  13. Snicklefritz65
    Snicklefritz65
    from Mass.
    mine doesn't have the hood seal shelf.
  14. Snicklefritz65
    Snicklefritz65
    from Mass.
    that's cool! i wouldn't be surprised if guys didn't pull moulds off of compe***or's bodies. check out this jc whitney 1963 advert. JC Whitney 1963..jpg
    this may be of help too.
  15. RodStRace
    RodStRace
  16. Snicklefritz65
    Snicklefritz65
    from Mass.
    i haven't been on that forum in ages. thanks for all the heads up!
  17. Snicklefritz65
    Snicklefritz65
    from Mass.
  18. RodStRace
    RodStRace
    You know you are a showoff when the slicks are pinstriped!
    Judging from the details, that looks like a steel bed, too. Tailgate chains, hinges and the tonneau cover clipped to the bed rails.
  19. Dave G in Gansevoort
    from Upstate NY
    Now I have to start over! My body is inferior! I’d probably just cut it off anyway, so I guess I can do without it… interesting bit of gl*** body history though.
    RodStRace, bchctybob and porkshop like this.
  20. Dave G in Gansevoort
    from Upstate NY
    Thanks. Slow tho… but I’m getting better now!
    Deuces, RodStRace, bchctybob and 2 others like this.
  21. Snicklefritz65
    Snicklefritz65
    from Mass.
    i can relate to slow progress. thanks to rsr i know about your build thread.
    RodStRace and porkshop like this.
  22. lake_harley
    lake_harley
    With the "ladder" underslung tube on the bottom of the frame it makes me wonder if a full belly pan is planned?
    Just wondering...what's the wheelbase? My guess is 100" - 102". I like the position relationship of the rear axle to the turtledeck and body. Too often, for my taste, rearend position is too far forward which makes for too much turtledeck overhang, or it's too far back making for a un-necessarily long and un-attractive wheelbase. I like compact T's!
    Lynn
  23. Dave G in Gansevoort
    from Upstate NY
    It’s kind of a throwback to my racing days combined with track roadster racing from the early 50s. The wheelbase is 99 inches but it’s adjustable a little bit. I have plans in my head for a belly pan, running from the nose to the kick up just in front of the rear axle. That would be relatively easy to make as the tubing as well as the frame is square from front to back. So it would just take rolling some aluminum sheet around the tubes and attaching it with Dzus clips. The engine compartment side panels will be a bit more difficult because they have to get from the firewall to the nose, on a taper. The hood, well I have some trepidation on that part. And then getting it flush with the side panels.
    If you want a good laugh, go read the complete thread and see why it’s called the whatever project. And comment on everything you see. I am a great plaigerizer, so if you have done something similar I will certainly copy it somewhat.
  24. swifty
    swifty
    Isn't that a cover section which goes over the ch***is on an original set-up? You would need to check out an original T roadster minus trunk section to find out.
  25. RodStRace
    RodStRace
    Check out the pic in post #5378. That's exactly what it is.
    porkshop likes this.
  26. Looks like a steel body too. Hole in the back corner, and it looks like the door opens
  27. RodStRace
    RodStRace
    @Snicklefritz65 I did a search over there and found some more for your (and other's) collection.
    Of note, a 2 inch flange all around the bottom (back into that back lower area), opening tailgate on the bed and trunk on the turtledeck. Hard to tell, but looks like a fairly short, flat dash.
    upload_2019-2-12_11-35-29.png upload_2019-2-12_11-38-5.png upload_2019-2-12_11-39-29.png
  28. RodStRace
    RodStRace
    The Kellison address, highway 99-e Lincoln, CA is not a thing.
    Highway 99 goes North from Sacramento, Lincoln is NE of there.
    It may have been subject to freeway renaming, there is a highway 65 that goes thru Lincoln.
    porkshop and Snicklefritz65 like this.
  29. RodStRace
    RodStRace
