Projects JUNIORS- 1931 Av8 Build.
Discussion in 'Traditional Hot Rods' started by JR-69, Sep 13, 2025.
  1. Papa Tiki
    Papa Tiki
  2. sknz
    sknz
    from NW OH
    Fantastic work by an obviously highly skilled craftsman and photography to match! Found this at just the right time as I am dealing with a lot of the same issues at this time on my '29 roadster AV8 project. The throttle linkage solution is outstanding and will work for me as well. Just need to get a F1 steering box as my Randy Gross F100 box will no longer work on my car. Can't wait to see more of this build.
    Outback and porkshop like this.
  3. ne'erdowell
    ne'erdowell
    I'd like to echo the others, your work is very impressive. I consider myself a basic hack but do have an appreciation for those that have the chops. This will be a car that someone could spend a lot of time taking in the finer details. Thanks
  4. Dave G in Gansevoort
    from Upstate NY
    got ya covered…
  5. trucker1
    trucker1
    They make reproduction 32 e-brake handles and you can make an angle iron bracket to attach to 3 bolts on the transmission lid.
    porkshop likes this.
  6. JR-69
    JR-69
    Awesome! Glad it could be of help
    sknz and porkshop like this.
  7. JR-69
    JR-69
    thank you very much!
  8. JR-69
    JR-69
    Yes I know, I’d prefer to have original parts where I can. If I can’t find one by the time I can drive the car I’ll go repop.
  9. JR-69
    JR-69
    Not much progress to show yet.
    Christmas time so I have been busy trying to get as much work out of the shop as possible and making some Christmas presents.
    I’ll be back at it early January.
    sknz, Chucky and porkshop like this.
  10. JR-69
    JR-69
    Okay i'm back at it over the past couple week, Not a ton of progress but progress at least.
    Mounted the Master Cylinder in place and patched a few areas. Ill weld and metal finish the areas again when its apart.
    Ill be making my own bellcrank set up for the pedal connection
  11. JR-69
    JR-69
    I completely tore down the ch***is and have been working on final welding and getting it all clean metal again. I needed to check my metal finishing from all the seam welding i did on the rails, i guess surface rust is free ****m.
    I also wanted to add some rivits for looks. I welded my crossmembers because I had never actually done hot rivits before. I gave it a try in a few spots. Came out ehh- not sure if it was my homemade tooling or lack or experience or both. Its something i need to get good at.
    These plates are to support where the frame was sectioned and has a vertical weld. Rivits on one side, hardware on the other side where the K member supports bolt up.
    I just did some rivits in areas i could put the head on the outside and would get hidden anyways to try and practice.
  12. JR-69
    JR-69
    They're really just for looks, a completely smooth frame is suspect.
    DSC01120 Large.jpeg DSC01108 Large.jpeg DSC01110 Large.jpeg DSC01116 Large.jpeg
  13. JR-69
    JR-69
    Metal finished the sectioned and shortened rear frame horns that tuck up under the body
    I also added a little kidney shaped hole to the K member which will give me straight access for my brake line fitting on the MC
  14. JR-69
    JR-69
    Clean frame ready to go back into a roller for the last ch***is work. I am hoping to powdercoat the frame next month
  15. Chucky
    Chucky
    Excellent job on that frame!
    osage orange and porkshop like this.
  16. JR-69
    JR-69
    Thank you Chucky!
    sknz likes this.
  17. JR-69
    JR-69
    Some more progress from last weekend-
    Im back to sorting out the seat. Last time I revisited the seat i moved the base again.
    I want a plump looking cushion. Where i had myself sitting comfortable previously the back rest cushion was only about 2" and it just looks wrong.
    So i moved the seat back again, gave my hinges a little more angle and will sit me nice and comfortable with a 4" cushion + Upholstery thickness.
    Doing this i had to remove the seatback structure / package tray area which some suggested previously in my seat talk but I was trying to avoid because I like the way that piece looks.
    Onto making my own
    oliver westlund, porkshop and sknz like this.
  18. JR-69
    JR-69
    I started with a 1x2" rectangle tube and started cutting in my arched shape and reliefs for the body joins.
  19. JR-69
    JR-69
    Fold the material over to make the arched ends
  20. JR-69
    JR-69
    Next i cut down the Original package tray to just what ill reuse, and mocked up the new tube in place, clamped and tacked together. DSC01162 Large.jpeg DSC01165 Large.jpeg
  21. JR-69
    JR-69
    I extended the sheetmetal on the body another few inches, These will to into the new cross structure.
    It will also help to remedy the body cracking issues from the stiffness of the wood ending at the same point the original sheetmetal ends. DSC01195 Large.jpeg DSC01196 Large.jpeg
  22. JR-69
    JR-69
    Last bit of shaping to make some end caps for the new structure to tie into the original but extended body sheetmetal
  23. JR-69
    JR-69
    All welded and metal finished ends-
    DSC01238 Large.jpeg DSC01241 Large.jpeg DSC01243 Large.jpeg DSC01236 Large.jpeg
    and fitted in place-
    DSC01245 Large.jpeg DSC01251 Large.jpeg DSC01254 Large.jpeg DSC01258 Large.jpeg DSC01257 Large.jpeg
    This gave the body alot of strength and structure and a firm backing for my seat
    BigJoeArt, Danny105, lahti35 and 9 others like this.
  24. Deutscher
    Deutscher
    from Germany
    That looks great, fantastic work!
    Regards, Harald
    porkshop and Outback like this.
  25. Outback
    Outback
    from NE Vic, Oz
    @JR-69 that's beautiful work & a very non obtrusive way of strengthening the body, it would be easy to jam some steel tube in there, but it will always look like it is, your solution will look factory to most people with the exception of those who know exactly what stock looks like. a wonderful vision & an inspiration.
    porkshop and Deutscher like this.
  26. patsurf
    patsurf
    Deutscher and porkshop like this.
  27. alchemy
    alchemy
    The nutserts are a nice touch. I like to use captive nuts on parts with hard-to-reach backsides. Less skinned knuckles and dropped nuts on ***embly day.
    Deutscher, Outback and porkshop like this.
  28. cederholm
    cederholm
    Amazing craftsmanship! ...very inspiring.
  29. JR-69
    JR-69
    Thanks Harald! I just took a scroll through your thread great looking car! That volvo trans swap is cool
    sknz and Deutscher like this.
  30. JR-69
    JR-69
    Thank you very much! That is always the goal to make parts that look like they could have been factory
    sknz and Outback like this.
