Technical Gasser Clutches & Pressure Plates?????
Discussion in 'The Hokey Ass Message Board' started by brigrat, Dec 18, 2025.
  1. brigrat
    brigrat
    from Wa.St.
    If this was 1960-1980 I would know what to run but technology has changed so what are the SouthWest G***er types running for a clutch & pressure plate these days? Building a '57 2dr. 150, blown BBC, 4 speed, slicks, 700-900 HP. Thanks!
    Rickybop likes this.
  2. 69fury
    69fury
    from Topeka
    A friend of mine used to run a Ramp power grip HD with a billet steel flywheel, then switched to the Defiant model which has smoother engagement at lower speeds. He drives it on the street alot and takes it to the track. The DefiantX is an adjustable pp, which needs occasional adjustment but doesn't take much more time than adjusting a conventional clutch linkage. This is most likely the set up i'll be looking at in the spring.
    Can't decide on a 13lb aluminum flywheel, though. I understand how it hurts the launch, but I think i'll enjoy it more once rolling. I do have a pretty flippin big tire though and hate to bog off the line...decisions, decisions...
    -rick.
    brigrat likes this.
  3. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^Do you need an inspection plate or bottom cover to make the adjustment?^^^^^^^^
  4. 69fury
    69fury
    from Topeka
    Either that or pull the trans back. He says it's just yearly inspection. I've never been there when he does it and i dont know what bell he runs. I have a Quicktime bell and there's neither an inspection plate, nor bottom cover.
    -rick
  5. 19Eddy30
    19Eddy30
    from VA
    What Trains ?
    m22 or a typical T-10 ?
    You will need to be looking into
    Liberty Jericho G Force ect
    Look @ Torque #s Not Hp ,
    BB , Blown & hooks needs to be strong with grip ,, Multi disk, or a slipper for adjustability if you want to do work & service frequently on street full lock up ,
    Track slip , Then you need to service steels .
    I do not see why a inspection plate
    Can be added to Quicktime , I think
    12 or so bolts Required ,
    There are other manufacturers of
    Can / bells with inspection.
    Just Gary and brigrat like this.
  6. brigrat
    brigrat
    from Wa.St.
    Running an M22 trans with an old NHRA Ansen bellhousing with belly cover.
    427 sleeper and Tickety Boo like this.
  7. Fogger
    Fogger
    A light aluminum flywheel sounds great but you give up the launch. Back in the '60s I ran an 11# Scheifer aluminum flywheel and my 2800# '55 Chevy ran consistent 11:40s. My friend Dave and I installed his small block in my car and it ran 2 tenths quicker, best ET was 11:21. Dave's engine made more power than my 327 and it had a heavy steel flywheel The launch was significantly more consistent.
  8. Kevin Ardinger
    Kevin Ardinger
    IMG_2174.jpeg Don’t use what this guy used !
  9. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^ A stock Aluminum bellhousing?^^^^^^^^^^^^
  10. 19Eddy30
    19Eddy30
    from VA
    @brigrat
    Is this BB going to be 500 of Torque
    Before the Blower ?
    M22 S-T10 rated @ around 450 Tq.
  11. 38Chevy454
    38Chevy454
    If planning much street driving, I think a multi-disc clutch (thinking dual disc) is going to be best. The old days of single metallic clutch disc with a high force pressure plate is tough on the street. Add in also tough on your left leg. The multi-disc clutch can be more forgiving clutch material, and having twice as much friction area it can get by with a lower load pressure plate. It will still work good on the strip, just tailor the clutch material to handle the application, maybe a hybrid with combination metallic and organic? There's been a lot of good clutch development with all the high power blown LS running on the street and track.
    brigrat likes this.
  12. brigrat
    brigrat
    from Wa.St.
  13. 19Eddy30
    19Eddy30
    from VA
    @brigrat
    Many on W -Coast . If not already researched CS1 reasonable
    I have seen complete
    Can ,clutch pack , Fly , shifter ,
    2-5 speed , reverser @ 3k .
    but replacement parts, some discontinued can be very expensive and hard to find, Planetary $$
    Even from Lenco .
    ST New around 10k .
    I was Not trying to be Negative
    Most do not realize Most after market
    are rated under 500 Tq ,even auto around a 2,800 pound or less vehicle . unless $$$ .. Bang for $ ,
    TH 400 dollar for dollar good strong oem with a few upgrades .
    I wanted to run Lenco in my 5W
    Even 2 speed w Reverser with use of stock seat will not fit.
    My 5W R-Rod , I swap around combo
    500 tq - over 6 00
    tires between 275 -315's 4-link change
    per engine & tire
    brigrat likes this.
  14. Weedburner
    Weedburner
    from Wa State
    GuyW, brigrat and Tickety Boo like this.
  15. brigrat
    brigrat
    from Wa.St.
    19Eddy30, all good points, thanks! Weedburner thanks for the link!
  16. oldiron 440
    oldiron 440
    Check what Mike Finnegan is using in his blown Hemi 55 Chevy , he’s been running 8,40s in the quarter and doing his drag and drives.
    He’s got a slipper clutch that he has got dialed in. He has gone over it on his YouTube channel…
    Tickety Boo and brigrat like this.
  17. mkubacak
    mkubacak
    With that much power, I would be looking at Liberty or G-Force.
    brigrat likes this.
  18. oldiron 440
    oldiron 440
    If you’re thinking about running in any of the SEGA races they require a clutch shifted four speed but then I don’t know if they have any blown cl***es.
    Tickety Boo and earlymopar like this.
  19. I ran a car with that kind of power, 9.63 at 141 weighing 3500#, aluminum flywheel, ram sintered iron adjustable 10.5" clutch. G force g-101 4 speed, never broke parts.
    I would sell the m22 and apply that cash towards a transmission that can handle that power reliably. The sintered iron clutch is adjustable and has to slip at the launch to avoid parts breakage. BUT the sintered disc is heavy and doesn't go together with a syncro transmission, it won't shift with a heavy disc. You have to combine this style clutch with a face plate style trans. It all works together.
    mkubacak, GuyW, Tickety Boo and 2 others like this.
  20. earlymopar
    earlymopar
    and it really looks like a lot of them only use the clutch to leave the line........
    427 sleeper likes this.
  21. oldiron 440
    oldiron 440
    I don’t know what they can get away with now, I haven’t been watching the races much over the past five years or so. They were off YouTube for a while and on payperveiw and when they got back on YouTube I was out of the habit of watching. I know that SEGA is owned by someone else now and maybe the rules have changed.
  22. crider
    crider
    I use a black magic soft lock in my 55 chevy. 511bbc and doug nash. Track only car
    brigrat likes this.
