Projects So this is how it starts T RPU turned Roadster
Discussion in 'Traditional Hot Rods' started by chlsnk, Jun 5, 2025.
  1. chlsnk
    chlsnk
    Thanks! It's really filling up quick.
  2. Tim
    Tim
    from KCMO
    Looks slick! The really was a nice clean bevel. glad my head full of old ford could be helpful :)
    laying pipe in a ditch sounds like an outtake line from a bob seager song haha
    Deutscher and chlsnk like this.
  3. Dave G in Gansevoort
    from Upstate NY
    Around here it was called snagging. And it was a dirty job! Was fun watching the welders welding on the live pipe when penetration was 101%…
  4. chlsnk
    chlsnk
    Took the opportunity of a sunny day to get some paint on the bed, it sure did take alot more paint markers than I expected and I still have some to go.
    Okie Pete, dwollam, Deutscher and 5 others like this.
  5. Tim
    Tim
    from KCMO
    Looks great man :)
  6. Outback
    Outback
    from NE Vic, Oz
    :D looking good
  7. Dave G in Gansevoort
    from Upstate NY
    Gonna buy stock in ****m. If everyone buys those pens for “painting” their cars, I could be a millionaire, or at least a hundredaire!
    Tim and chlsnk like this.
  8. chlsnk
    chlsnk
    The time has come to tackle the missing sections of rocker/sill/subrail. None of the body started out life together, 2 separate doors, a cowl from a ditch *which started it all* and a center tub from a touring out of the rafters of a lumber yard.
    The hope was to find a better body or a pair of subrails by now and avoid this. *That dream has failed to materialize*
    Today time was spent finding the flattest spot of concrete in the shop to lay out the body on. I'm thinking I'll make a jig to weld the cowl and tub section to and get everything held in the right spot allowing the doors to be opened and closed before I try splicing in material to fill the missing subrail sections. I only need 6-8" per side. I'm planning on harvesting this from the rear of the tub section where it was also cut; each side has around 9" I can prune off with what appears to be the same profile as what is missing in the front.
    A few days back the neighbor took a photo of me sitting in the car and I realized how high I sat even without any upholstery which led me to removing the seat riser. This ended up being a blessing in disguise once I started to get a game plan for the subrail repair as it allowed me to remove all the rivets holding the sill plate covers inplace.
    20251126_134231.jpg 20251126_134254.jpg 20251126_164044.jpg 20251126_164047.jpg
    Outback, Okie Pete, dwollam and 3 others like this.
  9. chlsnk
    chlsnk
    I also sloshed some paint on various other body parts today, wheeled the bed over to the solar oven for curing which worked beautifully, all the other parts I had hung up where still tacky when I closed up for the day. 20251126_122710.jpg
    Outback, Okie Pete, dwollam and 5 others like this.
  10. Tim
    Tim
    from KCMO
    Sounds like a good plan for connecting the dots
    chlsnk and Dave G in Gansevoort like this.
  11. GuyW
    GuyW
    I've long intended to make a small and a medium solar oven to bake enamel painted parts in. Who needs Earl Scheib?
    Outback and chlsnk like this.
  12. chlsnk
    chlsnk
    Things took a drastic turn today. The body I missed out on months back in Chicago showed up local to me forsale by another Hamb'r.
  13. Tim
    Tim
    from KCMO
    Ooooooooh buddy!
    J.Ukrop and chlsnk like this.
  14. chlsnk
    chlsnk
    I've been busy getting the roadster body set in place and a subframe built, found a old owner and got some photos from the 70's which has been neat. Settled on something like 4-5 inches of channel compared to the 10 or so the body once had.
    20251209_170731.jpg 20251208_193229.jpg 20251208_191217.jpg 20251207_183621.jpg 20251208_210430.jpg
  15. Tim
    Tim
    from KCMO
    Looking good! Gonna be cruising in no time!
    osage orange likes this.
  16. chlsnk
    chlsnk
    No earth shattering progress just chipping away at the subframe, body now stands under its own weight on frame. Tommorow the goal is to get the tail of the car tied into this tubular substructure, currently have a few pieces tackweĺded from the rear cross member to the tailpan to support the rear. The way the subframe is constructed I should be able to have a completely flat floor from cowl foot to rear crossmember.
    I have a 16gal round fuel tank 29" wide 12.5" tall thinking it will get mounted forward of the rear crossmember behind the seat leaving a well between tailpan and cross member for a small trunk or a possible battery location.
    20251208_165018.jpg View attachment 6598678 20251208_193042.jpg 20251217_152838.jpg 20251217_182128.jpg IMG_2586.jpg 20251210_182656.jpg 20251208_193222.jpg 20251208_164808.jpg View attachment 6598695
  17. Tim
    Tim
    from KCMO
    Awesome! Be rolling it outside to take a look in no time
    Outback likes this.
  18. Outback
    Outback
    from NE Vic, Oz
    Great work on the new body, I saw the comments on the other thread & had forgotten about this one. What a cool jigger
    chlsnk likes this.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    This is how it's done. Great work bringing an idea to life. I'm also excited to see it outside!
    osage orange and chlsnk like this.
  20. chlsnk
    chlsnk
    @Tim came by, lots of good ideas shared. He did a little rendering with a track nose bar and two little nerf bar steps infront of the rear tires to aid in entry. We both like the grill leaned back some, gives it a race look. Burned in just about the last of the subframe today and didn't take any photos of it.
    Outback, Deutscher, Papas32 and 3 others like this.
  21. Tim
    Tim
    from KCMO
    Was good seeing you today! Lots of good ideas percolating. Car really has a great feel in person. I think getting it outside for some photos will show it better but it feels, I dunno agressive? Rowdy? It’s a hot rod for sure either way you label it.
  22. willymakeit
    willymakeit
  23. That looks fantastic!
    chlsnk likes this.
  24. chlsnk
    chlsnk
    Wrapped up the subframe with some dog legs that tie in to where the original subframe was torched out extending into the factory pocket about 8 inches, the 1st of 2 holes drilled in this area for through bolts making use of a sandwich plate to really tie it all together in addition to some welding.
    A piece of 1x2" was split and used to tie in the factory tulip panel supports to the subframe. This brace stiffened up the body probably more than any thing else. It's a good feeling to grab any point of the body, give it a willful shake and the ch***is and body move as one.
    I'm thinking my next step(s) are going to be getting it steering and stopping. Hoping to try out a 36 ford dash ive been saving hopefully it won't put my column too low.
    Lots to think about with steering the original plan was to modify my F1 box to work in the A frame but the process of cutting the flange off and welding on a new one seems alittle daunting.
    Months back @Tim sent some photos of a car that had a 40-48 cross steer box mounted upside down allowing it to be used in a push/pull configuration and I liked the idea of that. 20251219_193209.jpg 20251219_112829.jpg 20251219_112846.jpg 20251219_112820.jpg 20251219_122306.jpg IMG_20251221_071202_164.jpg Screenshot_20251221_071321.jpg Screenshot_20251221_071216.jpg
    Outback, Deutscher and Tim like this.
  25. Tim
    Tim
    from KCMO
    Easy enough to mock up and see! It would also let you really play with steering column angle and minimize what dash modification you may need to make. It’s also going to let you cir***navigate some possible exhaust clearance issues. Always gets tight at the exhaust manifold/ steering column tube
    Outback likes this.
  26. chlsnk
    chlsnk
    20251221_151417.jpg 20251221_150912.jpg Some parts dress up today. Not digging that the aircleaners sit above the hoodline but that's something I should have taken into account before deciding on body placement.
    Outback, 26 T Ford RPU and Tim like this.
  27. Tim
    Tim
    from KCMO
    It’s not too extreme though. Id say be the time there are radiator hoses and a generator it’ll all just flow together.
    dash looks like you already color matched it lol. Malcolm here on the hamb had a 36 dash in his roadster originally I believe. Maybe a jump in the Time Machine back to 2011 will get some how to instructions to chew on?
    chlsnk likes this.
  28. Tim
    Tim
    from KCMO
    chlsnk likes this.
  29. chlsnk
    chlsnk
    Outback and Tim like this.
  30. chlsnk
    chlsnk
    Merry Christmas
