Technical Open chamber heads willing flat top pistons?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Dec 20, 2025.
  1. Budget36
    Budget36
    “with” turned into “willing”
    Oh well;)
    I’ve a set of TFS 195 75 CC heads. Bit of a story how I came into them, so won’t bore anyone with it.
    I’m picking of a SBC 350 this week, and I’d like to put these heads to use.
    Crunching numbers on Wallace racing, if the block is zero decked with flat top pistons, it’s around 9.2 static CR.
    Say a mild cam.
    Is it a waste of these heads, I don’t need to squeeze every bit of obtainable power out of this engine, but certainly don’t want to turn it into a slug, and once the block is decked, I don’t want to pull the engine and use dished pistons, pay for balancing again, etc.
    I guess another thought would be to just square the block and running a domed piston, but would still require a tear down
    And more $$ if I needed to change it up.
    Thanks.
  2. Oneball
    Oneball
    Are you sure they’re 75cc. There doesn’t seem to be any listing for those heads with that chamber volume.
    You could skim the heads.
    Budget36 likes this.
  3. Budget36
    Budget36
    That’s what I was told. I too looked through Summit, and couldn’t find a TFS 195 open chamber head.
    When I get up later I’ll open a box, should be a part number on them for me to verify.
    Might be these
    https://www.trickflow.com/parts/tfs-30410012-m72
    Says 72 cc chambers and 75 cc exhaust runners. “Not available “.
    Maybe not produced anymore. I have had them for a few years.
  4. Budget36
    Budget36
    IMG_2543.jpeg Well, not sure what I was seeing a few years back…
  5. oldiron 440
    oldiron 440
    In my opinion good heads will make power no matter what compression ratio you have, camshaft selection is more important in relation to the compression ratio.
  6. Rodney Dangercar
    Rodney Dangercar
    Open chamber heads are not efficient and not really recommended for performance use. Horrible things so I'll take one for the team and offer to take those horrible open chamber heads off of your hands if you wish. ;)
    Those look like pretty closed for an open chamber head...
    Budget36 and seb fontana like this.
  7. Budget36
    Budget36
    This why I mentioned I didn’t know what I looked at a few years back.
    But hey, thanks for the offer, I’ve a spot for them though!;)
    Rodney Dangercar likes this.
  8. saltflats
    saltflats
    from Missouri
    0 deck the block and use proper head gaskets and send it.
    Tickety Boo and Budget36 like this.
  9. Budget36
    Budget36
    Tis the plan now I’ve looked Lol
    Tickety Boo likes this.
