Hot Rods 61 Chevy Performance drive shafts
Discussion in 'The Hokey Ass Message Board' started by 5096PS, Dec 20, 2025.
  1. 5096PS
    5096PS
    from iowa
    In process of building a NHRA legal Stocker, more of a "Retirement, H***el Free car" 283/215 with a Metric 200 and 5500 converter. Last car was my 66 Biscayne,,283/229 with a Jerico. Ran multiple Divisional and National Events including cl*** wins with wins at the US Nationals, just not wanting to work that hard anymore. Not very excited to run NHRA, may run a couple close to me. But, plans are to run a few local Nostalgia based races. Cautiously starting out with a stock rear end, short tire with 5:38 posi, just finished a 4th upper link, boxed lowers, all with Energy Suspension Poly bushings. Yeah, I know a 12 bolt would be better (cant do a 9 inch, not legal to cross bread a legal stocker) but gonna see if it will hold up to a low HP 283. Exploring drive shaft options without spending huge money. Are there decent options other than the shops like Inland empire drive line in Cali for example. Appreciate any X FRAME guru input. THANKS
    Stock Racer likes this.
  2. 1biggun
    1biggun
    Years back I had a horrible time keeping the two piece driveline center support bearing mount together in my 61 Impala .
    Im talking 1980 time frame.
    The driveline its self should be easy to source in A strong enough version . The bearing and all that would be my concern if iys retains a two piece drive line.
    5096PS likes this.
  3. DDDenny
    @saltflats to the white courtesy phone please!
    mad mikey, Tickety Boo and 5096PS like this.
  4. DDDenny
    Tickety Boo, Stock Racer and 5096PS like this.
  5. saltflats
    saltflats
    from Missouri
    I ran a urethan center support bearing only for a few years before going to a one piece and a P/O 9.3 rear end.
  6. Mr48chev
    There are some poly center supports with stronger metal supports on them around like this one.
    The back in the day trick was use non greasable solid crosses in the U joints. That from friends who ran those cars pretty hard back then. Most broken U joints break at the grease zerk if the the torque is pulling against it rather than pushing against it. Screenshot (2321).png
    X-cpe and 5096PS like this.
  7. slowmotion
    slowmotion
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    Center supports are one thing, the snout for it is another. They break with any power...I've found:oops:
    5096PS likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    The biggest problem most people have with these comes from not knowing the proper way to tighten the bolts that go from the ctr bearing to the x frame. I don't drag race one of these but My 348 61 Impala has had the same carrier bearing in it for over 40 years and 60,000 miles. You only tighten the bolts when the weight of the car is on the rear axle. never tighten it with the rear hanging down. Maybe everyone here knows that but I have run across a bunch of people that said they couldn't keep a hanger bearing in their cars that did not know this
    5096PS, SS327, mad mikey and 4 others like this.
  10. Stock Racer
    Stock Racer
    With a 283 automatic Stocker, I wouldn't be afraid to try the stock 2 piece with a urethane center support. You could do a 1 piece but for the RPM you'll need to keep that 283 happy, I'd do a 2 piece. You may be able to find a local shop more cost effective than Inland Empire to do upgrades like a slip joint. The 8.5" ten bolt (like those in second gen Camaro's) is a great alternative to a 12 bolt.
  11. saltflats
    saltflats
    from Missouri
    Right lane. 409/409 th350 4.56 gears with 9 inch slicks.
    5096PS, Tickety Boo and mad mikey like this.
  12. Taboo56Chevy
    Taboo56Chevy
    this is defiantly the thing that will keep the bearing happy.
    If you go to a one piece the next weak link in the rear would be that upper control arm mount on the housing. That thing is probably the weakest link on the rear suspension. The one in our 61 Impala has been rewelded up at some point and I dont think that car has ever been a hard racer at any point in its life. I know the original 61 348 /350hp Impala my grandfather bought brand new in 61 had to have it fixed from doing some street racing and at some of the local strips.
    5096PS likes this.
  13. All the 2 piece drivelines I’ve had or still have I put a slip yoke in the rear shaft. Adjust like @Moriarity says. The only carrier bearing I lost was a cheap Autozone unit after years of daily driving.
    5096PS likes this.
  14. Tickety Boo
    Tickety Boo
    from Wisconsin
    You're not lifting your skirt Salty, that time slip is from 2016, I've seen the Shaker go much Quicker :rolleyes:
    You wouldn't be trying to Hustle someone would you ;) :D:D:D
    Stock Racer, 5096PS and saltflats like this.
  15. milwscruffy
    milwscruffy
    I run/ ran healthy big blocks in mine. I run Inland Empire Driveline center support bearing supports as mentioned above for the last 27 years with zero issues. I also have the stock driveshaft halves converted to .125 wall and solid u-joints. This combo has held up to 550 HP & 550 ft lbs of torque since 1998. The early IED support bearing supports had a steel outer casing which I prefer over the billet ones, but they aren't seen so no big deal.
  16. saltflats
    saltflats
    from Missouri
    This was the quickest it went with the two piece drive shaft.
    Stock Racer, Tickety Boo and 5096PS like this.
