Way OT Build
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Nov 26, 2025.
  1. wetskier2000
    wetskier2000
    from NH
    Is this allowed here??
    I'm combining a 1998 Corvette, 1959 Coronet and 1961 New Yorker.. Yes, it's a freak show...
    I have a sheet metal question....
    I need to change the 90 degree flange on the front fender to a hem. The victim is a 1961 New Yorker fender and the flange is at the rearmost edge beside the door.
    I'm pretty sure I need to stretch the right angle flange to have it lay flat as a hem cuz the fender is curved towards the center of the car. Sound right?
    Okie Pete, LCGarage and chryslerfan55 like this.
  2. squirrel
    does the flange need to be as wide as it is now? although it looks like it probably won't be, when you get the gap even between the fender and door. If you're going to that much trouble, that is.
    I'd probably just narrow the flange to about 1/4" and not worry about the stretching thing, which will happen all by itself as you make the hem.
  3. wetskier2000
    wetskier2000
    from NH
    Decided to start in the wheel opening lip first using 1/2 square tube... First p***... A long way to go...
    Boris_Fender_lip3.jpg Boris_Fender_lip4.jpg Boris_Fender_lip1.jpg Boris_Fender_lip2.jpg
    Okie Pete, chryslerfan55 and leon bee like this.
  4. JimSibley
    JimSibley
    What in the hell are you building? Im intrigued, to say the least.
  5. wetskier2000
    wetskier2000
    from NH
    Exactly, LOL! It's name is Boris, but we call it the Corovet. It's all 1998 C5 Corvette underneath reskinned with 1959 Coronet rear and 1961 New Yorker nose.
  6. I love the idea of this, reminds me of a one off custom that a fellow named Murray Pfaff built using a similar concept. You should check it out.
  7. wetskier2000
    wetskier2000
    from NH
    Second try on curving the 1/2" square tube. I put round rod inside this time to try and avoid the slip roller crushing it on the more severe curves. It worked pretty well but I had to cut it open in 2 places to remove the rod afterwards. I would have left it but small tweaks by hand were impossible. The slip roller wasn't real happy about doing it either...
  8. wetskier2000
    wetskier2000
    from NH
    Oh My goodness!!! If only I have a fraction of that talent.. Fortunately, while I do not possess his (or his friend's) skills, I am persistent! Pfaff's Imperial Speedster is truly a work of art. Thanks for pointing me there.. I REALLY like the chopped windshield too. I thought about venturing that direction, but fast approaching 70 it's probably best to not sign up for another 11 year build.
    https://hagerty-media-prod.imgix.ne...aled.jpg?auto=format,compress&ixlib=php-3.3.0
  9. You’re welcome. Glad I could help.
    JohnLewis likes this.
  10. Tim
    Tim
    from KCMO
    That front view is fantastic!
    With as sharp as your wheel well opening is, corner wise I think you are always going g to get some kinks. I think the best way to do it is likely cutting slices into all but one side and bending it to shape and then welding all those up and grinding g the welds away.
    Jordan bennet did a similar thing g when making the perimeter of the ****pit in his little racer. Did a great video on YouTube. I’ll see if I can find it for you Quick
  11. Tim
    Tim
    from KCMO
  12. wetskier2000
    wetskier2000
    from NH
    Nicely done.. Jordan's welding skills 10, mine 3 (on a good day)...
    Okie Pete and chryslerfan55 like this.
  13. Tim
    Tim
    from KCMO
    That’s what flap discs are for
    Lol
  14. wetskier2000
    wetskier2000
    from NH
    Got the right side pretty close...
  15. foolthrottle
    foolthrottle
  16. rustydusty
    rustydusty
    Wow! That is really cool. I couldn’t imagine why someone would want to change a ‘98 vette.
  17. Deutscher
    Deutscher
    from Germany
    Wow, that's the car the Black man with the guitar sings about.
    Regards, Harald
  18. wetskier2000
    wetskier2000
    from NH
    Yup, except I didn't get my parts for "free"...
    chryslerfan55 and Deutscher like this.
  19. wetskier2000
    wetskier2000
    from NH
    Had to move Boris to another bay, poser pic in the driveway... Boris_Driveway_Poser2.jpg Boris_Driveway_Poser1.jpg
  20. 57 Fargo
    57 Fargo
    It is so absurd it’s cool!
    guthriesmith and porkshop like this.
  21. Dave G in Gansevoort
    from Upstate NY
    Anthony would drive it…
  22. wetskier2000
    wetskier2000
    from NH
    Left side done less a little more finish work.. From rear to front... About 10" uncut original, up and over with 1/2" square tube, cut right angle flange off original and completed the last 6-7" up front. Fairly happy with it. I could have done a better job transitioning from the 10 incher to the 1/2 square.. maybe later...
  23. wetskier2000
    wetskier2000
    from NH
    Pulled the right fender off to knock out a dent near the grill and begin work on the hem. Unfortunately, the chisel idea that I REALLY liked won't work cuz some framing/inner structure is in the way. There is no room to put the chisel in there and support creating the hem as previously discussed.
    I am very leery of just making a mess trying to bend that 90 degree edge over into a hem. My wife who is pretty freakin smart about many automotive things says "Don't you have a junk fender you can try this out on?"... Yup...
    Also played with AI a little for a possible color scheme and different wheels...
    Boris_WinField_Fade_Green_with_Sparkly_Green_Fins_and_lower_body_at_lobster_boat_With_CRAGARS.png
  24. James D
    James D
    Just wondered if you could lower the front arches a little? It looks a bit 'cut in half' to my eye, at the front there. Just my 2c. Boris_WinField_Fade_Green_with_Sparkly_Green_Fins_and_lower_body_at_lobster_boat_With_CRAGARS.jpg
  25. wetskier2000
    wetskier2000
    from NH
    Ok, making some more progress... The Flange did not need to become a hem other than the more severe curve near the top of the fender. Here's the test cuts and hem then the almost finished product. Next up is media blasting.
    Also, the very badly cut out for what I think was an antenna will be filled back in. Someone decided it would be a good idea to make the hole with lots of drill holes. Curiously, the resulting "hanging chad" was still hanging inside the fender.
    Boris_Fener_work_23.jpg Boris_Fener_work_21.jpg Boris_Fener_work_22.jpg Boris_Fener_work_20.jpg
  26. wetskier2000
    wetskier2000
    from NH
    I wish I could but don't think I can... Its at about the minimum height while not rubbing the tires.
  27. gene-koning
    gene-koning
    This pic of the fender looks good to me.
  28. wetskier2000
    wetskier2000
    from NH
    Fenders dropped off at media blasting.... They were covered in either high build primer or a filler skim coat. I could not see myself sanding all that off...
  29. gene-koning
    gene-koning
    Hopefully, the fenders are OK below the surface level filler mess.
    Both front fenders on my 49 Dodge pickup were covered with a thick layer of filler. I was pretty concerned why someone applied a 1/2"- 3/4" thick filler covering.
    Once the old filler was removed, I was even more confused. There were two or three very shallow dips in the surface level where the p***enger fender bolt to the nose section, and one 3" long by 2" wide shallow depression across the top of the same fender but the other fender was clean. From the wheel arch up, both fenders were layered with anywhere from a 1/2" thick to 3/4" thick filler covering. Once I had removed the thick filler, I shot the area with a spray can primer because the truck would have to sit outside all winter.
    When i got back on the truck in the spring, I ended up moving the wheel arch 1 1/2" forward on both fenders in order to position the arch in the correct position on the "new" truck ch***is. The picture I'm posting shows the p***enger side fender laying on a saw horse, after the wheel arch has been welded into position. The picture is taken from above the fender, looking from the door edge towards where the nose bolts on. Those few dents you can see at the far left end of the top surface (showing vertical in the pic), was the worst damage on the fender that was hidden under all that filler. The entire area that has the old gray primer was covered with the thick filler.
    This pic is the same fender bolted in place, after the wheel arch move, during the build process. you can see the damaged area on the nose piece above the headlight hole.
    This picture is the driver side on the same day. The old gray primer is over bare steel. this fender was covered with that thick filler as well.
    You never know what is hiding under that old filler!
    Deutscher likes this.
  30. wetskier2000
    wetskier2000
    from NH
    I can't imagine why 1/2 - 3/4" of filler would be on any fenders... Making them the same height as other ill fitting parts, maybe?? I will confess that there is significant filler on my COE's roof. My limited talents could only get it so straight and flat, then mudd took over for the rest. I don't think any of it is 1/2-3/4 but the next owner (if there ever is one) may not agree.
    I didn't see any damage on the underside of Boris' fenders and all the stuff I chipped or ground away was barely a skim coat. I'm optimistic that they'll be respectable.
    Nice job raising the wheel arches!
