Technical 1932 ford roadster juice to bendix or disc
Discussion in 'Traditional Hot Rods' started by Sdsurfer01, Nov 4, 2025.
  1. RICH B
    RICH B
    Dumb question; but I just saw another example of incorrect ***embly in a PM.
    Are your shoes on your Lockheed brakes orientated correctly? Long linings go to the front and short to the rear.
    Opposite of the Bendix style that most people are familiar with now-a-days.
  2. Sdsurfer01
    Sdsurfer01
    I will have to check the orientation. I want
    to say they are the same length lining but I could have swapped and don e 2 longs on one wheel and 2 shorts on the other wheel…
    also thank you SDS, I’ll check that build.
    First task is I checked the underside of the drums and both wheel cylinders are leaking…
    I remember reading or watching a video somewhere that said the new springs have to much tension and pull the caps behind the rubber and they leak. That would kindof make sense with what I’ve been seeing. Originally my driver side leaked but p***enger didn’t. Then I noticed my p***enger side had the old spring where driver had knee spring. Swapped in new spring on p***enger and now they both leak.
    I got the springs from Dennis carpenter. I’m sure they source from all the same factories over seas but has anyone found springs that work better than others?
  3. RICH B
    RICH B
    Most if not all the current China made front wheel cylinders* are made wrong. The drilling is such that the lip of the cup in the large bore is uncovered when retracted fully.
    We found that by milling the slot in the piston about 5/32" deeper it eliminates the problem.
    Some people cut back the ear on the shoe to achieve the same thing. Personally don't like that idea even if it achieves the same thing.
    Some people say they are able to turn the adjuster cam out during ***emble to preclude the piston traveling in far enough to uncover the lip; tried that a few times with new shoes; either was to far out to fit drum and leaked when un-adjusted to get drum on.
    Can't really believe the "spring is too strong" story; hard to fathom the pistons retracting so fast they damage the cup. Makes no sense if you think about it.
    *Likely the wheel cylinders all come from the same factory across the Pacific. We had NAPA, Raybestos, plain bagged wheel cylinders from some Early Ford vendor, can't remember the brand from AutoZone, and when compared; they were exactly the same! drilled the same, leaked the same.
    HemiDeuce, 3blapcam and alchemy like this.
  4. glennpm
    glennpm
    I have a couple of cheap brake pliers and they don't function well on hooking and releasing the spring. I bought a used Craftsman and they are excellent
  5. alchemy
    alchemy
    Yeah, your leak is probably caused by the poorly machined new cylinders, which I explained way back on page 2. As Rich B says, the springs can only pull the shoes in as far as the cams will allow. The strongest, or weakest, spring in the world won’t make a difference in reducing the leak.
    RICH B and 3blapcam like this.
  6. SDS
    SDS
    Well, I'll be damned...
    Do I have my shoes on the wrong feet?
    RICH B likes this.
  7. alchemy
    alchemy
    SDS, the Bendix (Lincoln) style like you have require the long shoe on the back.
    The Lockheed style like 39-48 Fords require the long shoes on the front.
    1oldtimer, SDS, Kiwi 4d and 1 other person like this.
  8. Sdsurfer01
    Sdsurfer01
    @RICH B and @alchemy im having a hard time conceptualizing the problem. So when the brake is in a neutral non engaged position the large cap sits so far back it is behind the inlet fluid hole? Or the end of the large cap where it catches the brake shoe is so far back it sits behind the rubber sleeve?
    Once I understand that maybe I can understand the milling.
    I get cutting the end connectors of the shoes but not sure how far to cut and would like to understand the problem fully first
  9. alchemy
    alchemy
    The fluid inlet hole through the side of the cylinder is drilled at an angle. I’ve found new cylinders where the inside of that hole is a bit too close to the end of the cylinder. The inner cup lip will p*** over the hole, letting fluid leak past, and to the outside.
    If the new cylinders had come with inner cup spreader springs like they used to in the old days, you might be ok. But if you push the cups in as you are ***embling the brakes, there’s nothing to push them back out before you put the fluid in (and let it leak through). That’s why we were saying to ***emble them with the cams cranked out and adjust the cams so the drums just barely fit over, BEFORE you start bleeding the brakes.
    RICH B likes this.
  10. alchemy
    alchemy
    If you have original cylinders and shoes, you can get them rebuilt and relined by Brake Warehouse in the twin cities. They can arc the new linings to each individual drum for a perfect fit from the first press of the pedal. It’s worth the extra cost.
    RICH B likes this.
  11. Sdsurfer01
    Sdsurfer01
    Ok so update. Finally back to roadster while paint dries on my truck hood.
    got new, old lot made in USA front wheel cylinders. I should have paid more attention but don’t notice till I went to install brake hose that they rears… so going to return.
    Put my old (new manufactured) wheel cylinder back on and then remember, after I had put one wheel back on, to check the shoe sizes. Sure enough I somehow got them all mixed up. Had two large shoes on one wheel and two short shoes on the other wheel.. so got them swapped and put the big shoes towards the front and small towards the back.
    hopefully I’ll have time to bleed today but I’ll keep you all posted
    3blapcam and RICH B like this.
  12. Sdsurfer01
    Sdsurfer01
    Cool yeah I’ll give that a watch.
    I also forgot to mention the spring was annoying me. Something seems off on it. So I ordered another 2 from Bob Drake (I can’t remember where I bought the ones I’ve been using for about a year). And sure enough, they are different than the ones I’ve been running for about a year. Similar enough but new ones match the old ones that my grandpa had that were over stretched. In image right is new ones and left is the ones I bought a year ago.
    I also bled front and rear brakes from: p***enger rear, driver rear, front p*** and front driver. No air and I’ll see if I see any leaks tomorrow morning. Feels firm.
    Would a proportioning valve for the rear lines help them engage more. I feel like I’m not getting good stopping from them but maybe in my head
  13. 3blapcam
    3blapcam
    Hmmm,
    I don't think you need a proportioning valve. Would it balance your braking system? Yes. But that car is so light it really doesn't matter. Do you have residual brake check valves in your system? They're used when your MC is at level or lower than your WCs? They look like this:
    The red (10psi) is for drum brakes and blue (2psi) for discs.
    3blap.
  14. V8 Bob
    V8 Bob
    Drum brake residuals are really needed for older (pre-mid '70s or so) brakes without cup expanders, regardless of master cylinder location, whereas disc brakes located above the master may require them, but only 2 lb for discs, and 10 lb for drums. With the above residuals, Red for drums, Blue for discs.
  15. 3blapcam
    3blapcam
    Excellent! Thank you Bob! I think I usually have to look them up everytime before ordering them since I have not committed that to memory!
    3blap.
