Technical Are Clamptite style "clamps" traditional?
Discussion in 'Traditional Hot Rods' started by Darrian Wedding, Dec 26, 2025.
  1. Darrian Wedding
    Darrian Wedding
    I have tried searching and found nothing mentioning this specifically, the Clamp***e tie wire style clamps have been seen on industrial and aviation engines dating back to the 20s. Occasionally, they will be seen on high end performance engines like indy motors from that era, but does anyone know if they got used on actual hotrod engines and/or would they be considered TROG approved? IMO they certainly have the right look but cant find much one way or the other. [​IMG]
  2. Tim
    Tim
    from KCMO
    Somewhere between high end race car and farmers baling wire. I’d say it works on a hotrod to me. I don’t think anyone was being as **** as they are now about matchy matchy clamps and etc. but if they existed and weren't super expensive or rare I’m sure they showed up on hot rods.
    I would believe a car having Indy car clamps waaaaaay before believing anyone had a scot blown Ardun flathead with kinmont brakes and a pair of e&j headlights etc all in one car.
    Outback, alanp561, bschwoeble and 4 others like this.
  3. Blue Moon Garage
    Blue Moon Garage
    Check out Rodder's Journal #87, it may have just the info you are looking for.
    Outback likes this.
  4. For doing a forensic examination of fiddly bits, I think you should fit in around this place nicely. :cool:
    Outback, Driver50x, RodStRace and 3 others like this.
  5. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Actually they look a lot better than conventional hose clamps. If they were used in aviation during the 20s its a pretty good bet that people racing on the dry lakes used them and they trickled down to their street driven vehicles as well.May not find any actual do***entaion, but I doubt anyone could definitively say that hot rodders never used them.
    Driver50x and Just Gary like this.
  6. G-son
    G-son
    from Sweden
    The weight implies suitability for aviation and racing.
    Just Gary likes this.
  7. theHIGHLANDER
    theHIGHLANDER
    When you wanna to know if an application is appropriate just do the leg work. Find all the old photos you can. Looks like the stuff of old Euro racers to me.
  8. '29 Gizmo
    '29 Gizmo
    from UK
    Depends what you mean by traditional. The clamps may have been available in the 20s but rubber gas and oil lines were not invented untill much later
    Outback likes this.
  9. 49ratfink
    49ratfink
    yes, Jed Clamp***e is traditional.:)
    Outback, F-ONE, RodStRace and 5 others like this.
  10. Blue Moon Garage
    Blue Moon Garage
    As I said before, there is a great article in the latest Rodder's Journal called "The Devil is in the Details", an illustrated history of hot rod hardware, that covers many items such as clamps, pop rivets, AN fittings, etc. to help guys like you find the appropriate hardware for your chosen era. You don't have to guess; IMG_4264.JPG the author has done it for you.
    Outback and Just Gary like this.
  11. rpm56
    rpm56
    Do you have that issue of RJ?
    Outback and clem like this.
  12. banjorear
    banjorear
    As others mentioned, TROG qualifying doesn't get so finite that it comes down to what types of hose clamps you have. That said, I am one who appreciates this type of detail, so I'd say use them. Motorcycle chopper shops sell cloth covered modern rubber hose if you want to take it one step further in being "authentic".
    Outback likes this.
  13. Tim
    Tim
    from KCMO
    Not a lot of people have that issue so thanks for the screen shot :)
    Outback and justabeater37 like this.
  14. Can someone explain what the fuss is with this style br*** hoseclamp. They are on different vintage parts sites and allways described as "Enots hoseclamps" whatever that means :confused:o_O. Allways about 20 euro each. So €40 for a pair.
    Outback likes this.
  15. 325w
    325w
    We had those in the 60 at the car factory. I was thinking they need a hand held vice looking tool to hold the clamp while they tightened it. Then they went to a clamp that they used special pliers on. Used on gas torch hoses also.
    Outback likes this.
  16. KevKo
    KevKo
    from Motown
    As 325w said, check welding suppliers. One brand is Western Enterprises.
    Outback likes this.
  17. dirt t
    dirt t
    What's the difference. Go for it.
