Rotten Datsun
Discussion in 'Off Topic Hot Rods & Customs' started by hillbilly4008, May 21, 2025.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Redneck mathematics shows the weight of the engine, trans, clip, and radiator should drop the suspension about 4"
    simplestone likes this.
  2. hillbilly4008
    hillbilly4008
    from Rome NY
    Wish there was more time in the day
  3. gene-koning
    gene-koning
    I have lots of hours building inner fenders on my truck. They are not pretty, but you can not see them under the fenders they are attached to unless you remove them and set them on the floor. Mine are completely removable from the fenders, with the fenders bolted in place. They do what they are suppose to do.
    I suggest you install everything you need to have installed before you concern your self with the inner fenders. Make it run and drive first! Then, after everything else is done, cardboard (beverage containers) will be your best friend to patch together the inner fenders. You can cut, tape, and staple a pattern together then transfer the refined cardboard pattern onto pieces of steel you can weld together, and hold in place with screws. The purpose of the inner fenders is to keep the engine compartment free from road trash. They are hidden under the body, pretty is not what is important, function is.
    Deutscher and TrailerTrashToo like this.
  4. hillbilly4008
    hillbilly4008
    from Rome NY
  5. hillbilly4008
    hillbilly4008
    from Rome NY
    Onto the spine.
    20251230_134917.jpg 20251230_134924.jpg 20251230_134940.jpg I will have to lengthen the torque arm 10 inches.
    Deutscher likes this.
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    Also obviously need to lengthen the prop shaft 10". Makes total sense because the trucks wheelbase is 10" longer than the miata.
    I lost the heater box and most of the duct work. The coils will need to be relocated from the back of the engine to the firewall. And the heater hoses on the engine need to be re routed, I think there is a coolant reroute upgrade kit available that may solve my issue there.
  7. hillbilly4008
    hillbilly4008
    from Rome NY
    Some more t******* and prettying up needs to be done in this area yet.
  8. hillbilly4008
    hillbilly4008
    from Rome NY
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    FINALLY STARTING TO LOOK LIKE SOMETHING!! I love this part when it makes it from my head to reality.
    20251230_145626.jpg 20251230_145641.jpg 20251230_145716.jpg 20251230_145752.jpg 20251230_145909.jpg
  10. hillbilly4008
    hillbilly4008
    from Rome NY
  11. gene-koning
    gene-koning
    Looking pretty good there. Bet its going to be a fun truck.
    TrailerTrashToo likes this.
  12. hillbilly4008
    hillbilly4008
    from Rome NY
    Been a while since I did anything.
    Back bone needs to be stretched exactly 10 5/8".
    I found this bent piece of aluminum laying around. The same thickness, and the bend radius is pretty close. I'll be able to make it work, but I have to do it in pieces. ****'ll be fine.
