Technical 324 Olds in a 32 Ford with a stock hood?
Discussion in 'The Hokey Ass Message Board' started by Royalshifter, Dec 30, 2025.
  1. Royalshifter
    Royalshifter
    Moderator
    I am probably beating a dead horse but does anyone have any info, references, and or photos of a Olds Rocket engine in a 1932 Ford with a full hood?
    What to do and not what to do.
    Asking for a friend thank you.
  2. 302GMC
    302GMC
    from Idaho
    Neal East's 5w coupe, Jan (?) '58 HRM
    bchctybob, Deuces and LOU WELLS like this.
  3. Royalshifter
    Royalshifter
    Moderator
    Just looked April 58 HRM thank you.
    302GMC and Deuces like this.
  4. guthriesmith
    guthriesmith
    Not sure if @nochop is planning to run a hood on his after paint? I know he had a hood on it before it ended up with the Olds and a paint job.
    49ratfink, bchctybob and Deuces like this.
  5. Here’s a measurement.
    Roughly 28” tip of fan to back of head
    bchctybob likes this.
  6. DDDenny
  7. Royalshifter
    Royalshifter
    Moderator
    @anthony myrick there is an engine.
    Thank you for the measurement in "length" (no pun intended) it would be more the width or in our mindset "girth" because of the hood side clearance.
    bchctybob, hrm2k and anthony myrick like this.
  8. Here’s one with a side shot
    akoutlaw and bchctybob like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    pretty sure that generator will have to be mounted up on top like I did with the Cad in my 40 3.JPG 4.JPG
    akoutlaw, bchctybob, 302GMC and 2 others like this.
  10. Royalshifter
    Royalshifter
    Moderator
    Alternator moved check.
  11. nochop
    nochop
    from norcal
    I plan on running a hood on mine but haven’t got it on yet . Soon and I can get it mocked up and post some pictures if you like. I’m using a Denso alternator mounted low on the p***enger side. Also have a spin on oil filter. IMG_7874.jpeg IMG_7881.jpeg IMG_4950.jpeg IMG_5059.jpeg
  12. nochop
    nochop
    from norcal
    You may have issues with the road draft tube. Even with my recessed IMG_7630.jpeg IMG_7010.jpeg IMG_7287.jpeg fire wall I couldn’t get the stock tube to fit
    bchctybob and guthriesmith like this.
  13. Royalshifter
    Royalshifter
    Moderator
    @nochop thank you man, by the way I like the un-chopped car very nice.
    bchctybob and nochop like this.
  14. BJR
    BJR
    Loose the road draft tube and put a PCV on it.
    Dak Rat likes this.
  15. Tim
    Tim
    from KCMO
    Think they’ve got you covered but for the sake of broadening your photo research an early
    Olds is very close dimensionally to an early Cadillac or Studebaker.
    I’ve got a Stude under a stock hood in my model A and the only thing that absolutely wasn’t going to clear was the generator so the charging system will get moved down and tucked tight.
    I’ve seen a few have tight clearance at the front exhaust primaries that required a little blister to clear the manifold/tube but I think if you wanted to run a smooth hood that moving the engine back even and inch would gain you quite a bit of room.
    With these wider engines it just becomes a game of how far back are you ok shoving it to keep a smooth hood side.
    - Stude/Caddy/ Olds size reference based on sitting my 394 next to the Stude and measuring them side to side/ front to back. And the stude and caddy just being an ***umtion
