Hot Rods My 1935 Ford , sedan to 5 window conversion
Discussion in 'The Hokey Ass Message Board' started by aw1950, Sep 19, 2023.
  1. You are determined to make it work, starting with rusty, crusty sheet metal. Good for you.
    aw1950 likes this.
  2. aw1950
    aw1950
    More updates , fender was cut in half and stretched to fit correct .
    BigRRR, dwollam, tb33anda3rd and 3 others like this.
  3. aw1950
    aw1950
    Update for those following along . She’s staring to get a fat *** . Also starting to tie in p***enger side inner wheel well . Stay tuned more to come
    BigRRR, dwollam, Copper Top and 4 others like this.
  4. Squablow
    Squablow
    I love **** like this, I'm surprised I haven't seen it until now. Love it so far, looking forward to seeing more.
    BigRRR and aw1950 like this.
  5. Keep going you almost got yourself a five-window coupe.
    aw1950 likes this.
  6. manyolcars
    manyolcars
    awesome
    aw1950 likes this.
  7. aw1950
    aw1950
    Some more progress . First few pictures are of the quarter panel tie in along with the front part of wheel arch . Hard to tell what you’re looking at I know but look long enough you’ll figure it out LOL Next pics are of the rear bulkhead framework . I installed the rear parcel shelf , welded in the main centre section of the bulkhead and temporarily installed the left and right panels . Have a look !
    BigRRR, dwollam, Copper Top and 3 others like this.
  8. aw1950
    aw1950
  9. aw1950
    aw1950
    So here I am in the thick of it now . This rear right fender must be off a 37-40 ford as it don’t fit for s**t . Very fast arc to the profile . So cut,cut,cut it all apart and s***ch it all back together .
    Copper Top, Hot Rod Ron and Squablow like this.
  10. aw1950
    aw1950
    IMG_1636.jpeg 9F8D5DD9-ECCB-4069-B9EF-AFB0C545E99B.jpeg IMG_1653.jpeg IMG_1654.jpeg IMG_1656.jpeg IMG_1657.jpeg IMG_1658.jpeg IMG_1659.jpeg IMG_1660.jpeg
    built a wire form buck on fender and wheeled up new panels to better fit the wheel . Coming along nicely !
    guthriesmith, vtx1800, BigRRR and 3 others like this.
  11. tubman
    tubman
    I agree. This sort of thing is the main reason I'm on here every day.
    aw1950, BigRRR and Squablow like this.
  12. Hot Rods Ta Hell
    Hot Rods Ta Hell
    My favorite type of HAMB build as well. Don't know how I previously missed it! Lookin good. I'll look forward to following along.
    Your gut determination is admirable. You're making good use of that long Canadian Winter. Any idea how many hours you have into it?
    aw1950 likes this.
  13. TorqueMonster1
    TorqueMonster1
    Incredible Build Thread!! You’re doing an awesome job! Keep the updates coming. Mark
    aw1950 likes this.
  14. aw1950
    aw1950
  15. aw1950
    aw1950
    A little something something , starting to see it ! More to come
  16. aw1950
    aw1950
    guthriesmith, BigRRR and Squablow like this.
  17. aw1950
    aw1950
    Getting the rust off , starting to look like something
    BigRRR likes this.
  18. aw1950
    aw1950
    Had to remove and repair some of the door skin . To thin to weld to . Also had to split the door skin remove a small wedge and weld back together for alignment. Must be done when you chop a roof . IMG_1944.jpeg IMG_1945.jpeg IMG_1946.jpeg IMG_1947.jpeg IMG_1948.jpeg IMG_1949.jpeg IMG_1950.jpeg
  19. aw1950
    aw1950
    Previously welded in the roof insert using a 1951 Chevy coupe roof section fully welded it in and then leaded the seams View attachment 6607979 IMG_2003.jpeg IMG_2002.jpeg IMG_2004.jpeg IMG_2005.jpeg
  20. aw1950
    aw1950
    The doorbell line to quarter panel belt line body profile was off by 3/16 of an inch had to cut it out. Make a new piece to get the alignment corrected IMG_2006.jpeg IMG_2007.jpeg IMG_2008.jpeg IMG_2009.jpeg IMG_2012.jpeg
    BigRRR likes this.
  21. aw1950
    aw1950
    Put a lot of the main body into primer just for motivational purposes it always looks a lot better in one colour don’t you think IMG_2034.jpeg IMG_2035.jpeg IMG_2036.jpeg IMG_2037.jpeg IMG_2038.jpeg IMG_2040.jpeg IMG_2034.jpeg IMG_2035.jpeg IMG_2036.jpeg IMG_2037.jpeg IMG_2038.jpeg IMG_2040.jpeg
  22. aw1950
    aw1950
    IMG_2042.jpeg IMG_2043.jpeg IMG_2044.jpeg IMG_2045.jpeg IMG_2046.jpeg IMG_2047.jpeg IMG_2048.jpeg IMG_2049.jpeg
    pretty obvious on this one , frame rot has to go .
  23. aw1950
    aw1950
    Pretty much up-to-date now frame has been repaired boxed,
    vtx1800 likes this.
  24. Squablow
    Squablow
    I like the dedication to this project, lots of metalwork coming together.
    But FYI, posting your MII front suspension pictures is going to get your build kicked off of the main page.
  25. aw1950
    aw1950
    So I guess I need to delete em! Thanks for the positive comments on the work , stay tuned Squablo
    guthriesmith and Squablow like this.
  26. Squablow
    Squablow
    I'll definitely be watching as it comes together. The primered areas really do look like they came together well. And neat to see some lead bodywork being done, that's one thing I've always wanted to try but never have yet.
  27. aw1950
    aw1950
    Funny you would mention the lead work . I to always wondered about trying it . This was my first attempt at it. I have 6 pounds of lead left and I will be doing more on the body as time moves forward.
    Squablow likes this.
