Projects 1930 Coupe traditional build
Discussion in 'Traditional Hot Rods' started by ECMFab, Oct 22, 2023.
  1. ECMFab
    ECMFab
    Damn that ****s! Good thing Oceanside isn’t as strict as OC. Funny enough, we actually have an HOA here but I’m so friendly and help with everyone in my neighborhood that I think they let me get away with more stuff here haha
  2. God they're basically trying to turn my entire town into an HOA lol
  3. 1946caddy
    1946caddy
    from washington
    Welding on grade 8 nuts and bolts makes them brittle.
    Not recommended
    Welding on Grade 8 nuts and bolts is generally not recommended due to the potential for mechanical property degradation and embrittlement. The heat from welding can alter the microstructure of the steel, reducing its strength and toughness. Additionally, the yellow chromate coating on Grade 8 bolts can release toxic fumes when heated, and it may interfere with the weld quality. It is crucial to ensure that the fasteners are made from weldable steel and that any heat addition will not adversely affect their strength and safety.
  4. ECMFab
    ECMFab
    That’s interesting, thanks for the info! I was wondering about that. My buddy has been doing it a long time on the driveshaft on these old fords, and has never had an issue, once. He’s been building cars over 30 years. I’m hoping also in my case the HAF is on the head far outside what part I would need which is the shaft to hold as a shear pin IF the collar somehow came off or spun on the driveshaft itself. I think it would be impossible, but we will see. I’m sure I didn’t even need to put a pin in the coupler at all.
  5. ECMFab
    ECMFab
    Running this setup to get my caster angle correct. How have yall done it? I have to be out of my buddies shop today so they can make money tomorrow. image.jpg image.jpg image.jpg
  6. ECMFab
    ECMFab
    Got the wishbones tacked, then raised the car and got small beads on them so they wouldn’t move, then lowered and checked angle of axle and I ended up around 7.8 degrees. I think the car should drive nice. We will see. Took the bones out, bench tig welded, took outside and painted them. Installing now.
    Was also able to install the splash apron and hardware. Tightened the body down today with some additional shims trying to get the hood aligned. Not easy!
    Cotter pinned the front end, adjusted brakes, and torqued wheels, then installed hub caps.
    simplestone, Outback and Deutscher like this.
  7. Grumpy ole A
    Grumpy ole A
    It’s looking good. You will soon be driving it all around, burning up the roads.
    Outback likes this.
  8. ECMFab
    ECMFab
    Gosh I sure hope so. Thank you for the compliment and following along! It’s been a journey for sure and finally feel like the light is at the end of the tunnel. Definitely underestimated how long it would take to learn everything and how much time it would take for each step.
    Outback likes this.
  9. ECMFab
    ECMFab
    Here’s how she looks when I got her off the rack! Time to take to a muffler shop to bend up the exhaust and work on getting my Smithy’s mufflers installed. IMG_7547.jpeg
    AHotRod, simplestone, Bugguts and 6 others like this.
  10. Outback
    Outback
    from NE Vic, Oz
    Looking good!
    ECMFab likes this.
  11. AHotRod
    AHotRod
  12. ECMFab
    ECMFab
    Yesterday I got the car into a shop I used to do exhausts at. Haven’t bent exhaust in about 16 years. Crazy how time flies. I’m def rusty, as I was gun shy about my degree bends. I’d look at something and think, that’s a 10,10 full shoe offset to kick over and I’d only go 5 degrees to start, then 7, then 10. I would say to myself, “see?” I still have the eye but I guess was reluctant to overbend and mess up a stick. Also, I wish the route was a little more symmetrical but between the steering box, starter, different elevations on the k member, then accounting for the master, I did the best I could with the time away from the bender, and with just the 5 hours to work on the car before having to load back on trailer. Fairly happy with it, may bend it again sometime. I didn’t like the flanges he had with universal holes so I’ll blast some new ones out on my CNC plasma table after I draw them and swap them out. I left with the pipes just tacked in place. The tails I also couldn’t weld in cuz it seemed the body needs a tiny bit more adjusting to deal with the hood gap so I bent the tails and left driver side long. I ended up a little more narrow than I had envisioned too. Either way, it’s still exciting that another step was taken on the car. Starting to feel like actually driving this thing is getting closer and closer! IMG_7620 Large.jpeg IMG_7617 Large.jpeg IMG_7613 Large.jpeg IMG_7615 Large.jpeg IMG_7614 Large.jpeg IMG_7618 Large.jpeg
  13. Grumpy ole A
    Grumpy ole A
    Those pipes are looking good, can hardly wait to see them complete.
    ECMFab likes this.
  14. ECMFab
    ECMFab
    Swapping out the hinge pins. This is what the “restorers” used many years ago. Pretty sweet. Hoping to get the doors to close as good as I’d like. image.jpg
    AHotRod likes this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the last pic. when posting pics always select "full image" before posting
    Outback and ECMFab like this.
