Hot Rods The (mis) Adventures of a Compulsive Tinkerer
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Apr 13, 2024.
  1. wicarnut
    wicarnut
    Reading your thread this AM and I admire your ambition, I'm impressed with the projects/progress. You have inspired me, like you my mind is always thinking, but life has slowed me to a stop temporally, not too long I hope. I've been down sizing as I have too much "Stuff" and do have one project left to finish, just keeping up with home, car hobby, no longer building, just maintaining and enjoying cruising, local shows keeps me busy. I enjoyed your thread, it's nice to see pictures, Thank You, Have a Great day !
    Thor1, Algoma56 and bchctybob like this.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice progress.
    RE: The br*** pipe connected to the oil pressure gauge. That's OK for start-up and engine break-in, but I had a similar br*** pipe connecting an oil pressure sender. It failed from engine vibrations! It cracked at the root of the threads and started leaking oil. Fortunately I noticed it before it broke off completely and drained the sump.
    I would use a stainless - or braided - connector there.
    An oil filled gauge to dampen harmful vibrations will also add life to the gauge.
    My Olds engine experience: Many decades ago I bought a clapped out A sedan with an Olds engine wearing a 6-deuce log intake with Ford 94 carbs on it. I junked the Olds, kept the intake around for a while until my wife and I got invited to a party where we had to bring a gag gift.
    Yup - I wrapped up the intake.
    I can still picture that intake sitting out by somebody's curb on trash day. I hope somebody that could use it ended up with it and it isn't in a landfill.
    Carry on.
    SS327, bchctybob and rod1 like this.
  3. wicarnut
    wicarnut
    HAMB , wakes up memories, way back in the day 1964, my first car (avatar) I installed 3 panel with oil pressure gauge under dash with copper tubing/fittings and had the line crack at gauge inside car. A little a mess as I wrapped it with electrical tape after pinching line with pliers to get it home. just being a kid I was advised at the speed shop to use copper not plastic line, my first experience dealing with an "Expert"
    bchctybob likes this.
  4. bchctybob
    bchctybob
    Thanks Wicarnut - I’ve slowed down a bunch over the last few years with some down time to reconsider whether I should be doing this stuff still or if I should just hire an auction company to liquidate it all and buy one finished car to drive to the finish line. But I live for accomplishments, big or small they keep me getting up each morning. And I do what interests me at the moment, whether it’s a home maintenance or car stuff or yard stuff. I try to just get something done. Taking pictures and writing posts helps me to not feel like such a hermit out here.
    Frenchtown - I know exactly what you mean! I’ve had fittings fail at the root of a pipe thread too so I’m careful not to stress them or cantilever them. This setup is just for startup/break-in on the dolly, Installed in my Stude pickup it has a remote oil filter due to the Mopar torsion bars. .
    wicarnut, enloe, porkshop and 4 others like this.
  5. bchctybob
    bchctybob
    With it being so close, the engine angle becomes more critical as well as the height. I just dropped it in last night and went in for dinner. I’ll tinker with it today and see what I can do. I don’t mind working the firewall to gain some extra clearance. I kinda like my engines a little higher than current thinking usually places them. I run mechanical fans, so where the fan is in respect to the radiator core is a big factor to me. Plus, I like the way it looks.
    enloe, porkshop, loudbang and 2 others like this.
  6. bchctybob
    bchctybob
    Thanks. Hopefully I won’t have to bash it in…:D
    enloe and porkshop like this.
  7. bchctybob
    bchctybob
    Yeah, what about that? IDK. I’m hoping enough remains to provide some additional protection but myself, I would have everything ready to go, do a last minute oil pump prime, drop in the distributor and go. There should be fresh break-in oil everywhere at a minimum.
    Truth is, I never worried about such things as a young stud with a hot rod. I just put ***embly lube on everything during ***embly, added my favorite oil and fired it up whenever I got the engine in and ready. Never had a failure. Well, that’s not entirely true. My big stroker Olds died a gruesome death but the local machine shop built it and it was caused by water in some cylinders. And my 396 Chevy spun some rod bearings but it was a low mileage factory engine that I just dropped in and started beating on. My conscience is clear…
    wicarnut, enloe, porkshop and 6 others like this.
  8. bchctybob
    bchctybob
    I did some fiddling with the Buick engine position and no major changes are needed. 5/8” worth of spacers in front and scooting the engine as far forward as possible make everything clear ok and the angle good. I will give the firewall a little whack dead center just for good measure and I’ll probably add a little strut to control any tendency for the engine to slide back since the mounts are slotted.
    Note that the bolt is tilted. There’s room to elongate the slot to make everything good. The bolt on the other side is centered in the slot.
    Oh yeah, and I’ll make nice spacers.
    There’s about 3/8” of clearance between the firewall and the distributor but both the body and the engine can be moved fore and aft during ***embly so I’d like a little more clearance. 1/2” would be ok - 3/4” would be better.
    wicarnut, enloe, porkshop and 8 others like this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    If you move the engine any further forward will there still be enough room to slip a V-belt between the front pulley and the crossmember U-bolts?
    bchctybob and Thor1 like this.
  10. Budget36
    Budget36
    Heck, I’ll go along with your thought!
    ekimneirbo, bchctybob and 427 sleeper like this.
  11. bchctybob
    bchctybob
    There’s about 5/8”-3/4”, should be enough. The camera angle makes it look smaller. Wouldn’t be the first time that I’ve had a car where I had to take the pulley off to install a belt though, lol.
    enloe, THE FRENCHTOWN FLYER and Thor1 like this.
  12. bchctybob
    bchctybob
    I woke up with gout in my big toe/foot so I was a little slow today. Must have been all of the rich holiday food. My wife says it’s from standing on the cold concrete floor for hours.
    I “adjusted” the fit of the p***enger side motor mount a little. I elongated both the holes on the block side and the slot for the main bolt just enough to make everything fit properly.
    Now I’m going to step back and think a little before I pull the Buick out and move on to welding.
    wicarnut, Stock Racer, enloe and 4 others like this.
  13. AmishMike
    AmishMike
    You wrote word “gout” & my toes starting hurting. Not rich food - check on line foods to avoid. Good luck, had in index finger once was killing me
  14. bchctybob
    bchctybob
    I decided to lay out the rear end components and do some thinkin’….
    There’s always the temptation to just buy someone’s kit and be done with it. This setup is simple, different, and stout enough to take some horsepower. It’s a nod to good old Tex Smith….
    I have coilovers, quarter elliptics and parallel leafs in stock. Also the Corvair coils as shown (the other one is taking a bath in citric acid). I won’t do a transverse leaf. Mainly because I don’t have one.
    I bought the ‘49-‘50 Olds trailing arms several years ago, they are in great condition. I bought a bunch of spring seats from Speedway, mostly from their “Garage Sale” area for cheap. The gold ones cost me a whopping $1.04 each! Strange number - who’s arguing? Not me. I’ve got the Corvair (rear) springs, cones, bump stops and isolators from a ‘65 Corsa. Speedway has lots of choices for coil spring lengths and rates if I use theirs. Using the Corvair springs would mean ordering special new springs if these should prove to be too soft. But I like that they can be bolted to the back of the trailing arms with cups and bolts, like a Chevy truck.
    wicarnut, Stock Racer, enloe and 9 others like this.
  15. bchctybob
    bchctybob
    Here’s where I need a little help. My trailing arms didn’t have bushings. My first search for Olds trailing arm bushings came up with only late model stuff. After a while I gave up hope of finding ’49-‘50 Olds parts. I had some Chevy Nova bushings left over from a job I did in my shop years ago. They were too long and slightly smaller than the ones that the Olds arms use but I made some sleeves to make them fit.
    My problem: They take 1/2” bolts. I’d like to use at least 9/16” bolts with sleeves, preferably 5/8 bolts with sleeves. 5/8” is a typical size bolt for a performance ladder bar, sometimes 3/4”. My attempts at trying to enlarge the bolt hole in the rubber bushings were, well, futile. So I bought some urethane bushings, same result. How do I “bore out” the rubber (or the urethane) bushings to 3/4” ID. I was sure that a sharp reamer would do it but it doesn’t.
    Any suggestions?
    I would prefer to use the rubber bushings because they are more compliant. But I’m good with either one. As you can see, I have to make a choice because the distance required between the mounting brackets is different depending on which one I choose. Help!
    enloe, porkshop, Thor1 and 2 others like this.
  16. AmishMike
    AmishMike
    For bushings look up local “ Fleet Pride “ truck parts & explain size you want. Tons of choices
    enloe, Budget36 and bchctybob like this.
  17. A 2 B
    A 2 B
    from SW Ontario
    Rubber is much easier to cut/drill after being frozen. A light coating of a fast evaporating lubricant will help as well.
    enloe, bchctybob, rod1 and 2 others like this.
  18. Doesn't really apply here(or maybe it does), but I could cut conveyor belting with a utility knife and lube, WD-40, where you couldn't cut it dry. Won a couple friendly bets on the job site with that one.
    bchctybob, rod1, SS327 and 1 other person like this.
  19. mohr hp
    mohr hp
    from Georgia
    I think you've got it figured out, just being out there moving is the key. I can't imagine just polishing a finished car and not having something to wrap my brain around. I'm with you, Bob!
  20. bchctybob
    bchctybob
    While lying in bed last night I had an idea that I might try.
    Sharpen the end of a piece of thin wall 3/4” round tubing, chuck it in my drill press. Take the rubber bushing and sleeve and put two hose clamps around the sleeve and align it under the tube in the drill vise and secure the vice to the table. Heat the tube with my Oxy-acetylene torch and with the drill press spinning on the lowest speed push it through the bushing. Kind of a circular hot knife.
    I haven’t been able to hold the bushing securely in previous attempts, even taking the smallest bites, it’ll grab and yank the rubber bushing out of the chuck. I’m thinking that my split sleeve might provide more surface friction while the hose clamps squeeze the full cir***ference and provide an obstacle to prevent the sleeve from spinning in the vice. I might have to glue the sleeve to the bushing.
    I might try it cold with WD-40 first, like Algoma56 suggested. Depends on how good of an edge I can get on the 3/4” tube.
    I won’t get to try it until later, we have appointments today and I need to drop off some connecting rods at the machine shop while we’re out and about.
    wicarnut, enloe, SS327 and 1 other person like this.
  21. bchctybob
    bchctybob
    I kinda tried that. But the rubber just seems to move out of the way and when you increase the cut and finally get a bite, it pulls the bushing out of position in the chuck. I guess the cutter needs to be like a thin blade but a blade is hard to control. Or the bushing needs to be held more securely.
    I tried a reamer but it doesn’t bite the rubber either, the rubber just kinda moved out of the way. I haven’t tried that with the urethane bushings. I think I’ll take them to the machine shop today and see if Willy has any suggestions. Maybe he’ll do it, he loves a challenge…..
    wicarnut, enloe and ekimneirbo like this.
  22. A 2 B
    A 2 B
    from SW Ontario
    Dry ice, liquid nitrogen or just tossing rubber parts in the freezer will harden the rubber to some extent, enabling the material to harden enough for more effective machining. The colder the better. I have seen some dramatic results from the extreeme cold provided by Mother Nature as well, such as the rubber soles on boots simply cracking in half, unable to bend, or breaking a cast iron stove into a fragmented pile with a few blows from a ball pein hammer.
    Works wonders the other way too by warming rubber to make it more flexible, such as installing rubber gaskets for auto gl***. Just a matter of using temperature to our advantage.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That's what I was thinking - some 4x4 and off roader aftermarket suspension suppliers
  24. bchctybob
    bchctybob
    That’s where I found the urethane bushings - off road supplier. I looked at Fleet Pride and they do indeed have a ton of stuff but their website didn’t seem to offer any dimensional information and quite a few have no picture.
    I dropped off the urethane bushings and some dimensions to my friend and he’s going modify them for me. I will try to modify the rubber ones myself, if it works, new ones are available if I need them.
    wicarnut likes this.
  25. Budget36
    Budget36
    Would a holesaw work on your rubber bushing?
    I’ve bored urethane bushing and changed the OD in my small late. I don’t recall issues doing it.
    bchctybob and SS327 like this.
  26. bchctybob
    bchctybob
    It’s been quite a while since I tried boring the rubber bushings. No doubt I could have modified the urethane bushings but I have since disconnected my big ol’ lathe and used the power circuit for my mini-splits. My intention was to rearrange my shop and move my lathe over to where my mill used to be, but that’s a helluva lot to ask of one old man. Hard to believe that I moved it out of my SoCal shop, onto a flatbed trailer, schlepped it 400 miles north, unloaded it from the trailer and positioned it in my new shop - all my myself! But that’s was 15 years ago when I was a strapping young 60 year old, lol.
    I had to run some parts up to Baechler Machine anyway so I took them along. He said no problem, I’ll get them back next year….. In the meantime, I’ll set up my drill press and maybe try a hole saw on the rubber ones. Again, the hard part is holding the bushing from turning without deforming it too much.
  27. Budget36
    Budget36
    I’ve a goofy idea on holding the bushings, but not sure if it would/could affect the integrity of the rubber.
    Take a sleeve that will slide over the OD and fit snuggly
    drill a series of hole in the sleeve.
    Wel a few tabs on the bottom of the sleeve.
    Put the bushing in the sleeve.
    Use some short wood screws through the holes that are in the sleeve.
    Clamp the tabs down to the drill press table.
    Just thought over morning coffee.
  28. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, BcB;
    You & a couple other guys figured it out. The sharpened tube will work(& is actually available/reco'd for cutting conveyor belting holes), as should a new(read:sharp!) hi-quality holesaw, when the rubber is frozen(freezers are good for somewhere south of 0* to maybe -20*, or just outside in MN...). Just gotta be kinda quick. The CO2 idea is pretty good to keep the chill going. You can turn up the holesaw speed abit if it's really frozen hard. Take light plunge cuts to disperse the rubber "shreds". I don't remember iffen the saw will give real smooth cut-edges like a sharpened tube, but iirc, it's not bad, as long as it's not rammed thru. The sharpened-edge tube probably doesn't need the rubber frozen super hard, I did it at Minnesota summer-temps. Thin oils like WD40, Kroil, etc will work - sorta, but they're *really* messy. I found water to work well to lubricate the blade-edge. Was mostly hand-knife cutting, but did some holesaw & other blades(circle saw & drillbits - they **** large) also. Water is also abit messy, not as bad as oils because it evaporates, eventually. Seems to keep the rubber-dust & itty-bitty "balls" from getting too bad. Be careful around electrickery, though...
    FWIW.
    Marcus...
    Thor1 and bchctybob like this.
  29. Well, there's always a rat-tail file and the tedious hand work that eventually gets the job done.
    bchctybob and Budget36 like this.
  30. X-cpe
    X-cpe
    To hold the bushing, you might try boring a hole in a s**** of 2x4, then cut the 2x4 in half vertically through the hole. With the material lost to cutting it in half and a couple of drywall screws (or bolts) it should hold the bushing with pretty even pressure all around. You may want to pre drill for the screws or bolts to maintain alignment.
    For a cutter you could grind the teeth off of a hole saw and sharpen the resulting edge to the outside like a one sided knife blade. The hole saw should hold an edge better than tubing.
