Projects 270 Poly engine is finally rebuilt
Discussion in 'The Hokey Ass Message Board' started by Koob, Jun 20, 2013.
  1. NWRustyJunk
    NWRustyJunk
    Very cool! I have a 56 Dodge 270 Poly sitting on a cart in my shop. As someone said before, I always thought it would look sweet in an exposed engine car. Where did you get the adapter for the 700r4?
  2. jack_pine
    jack_pine
    from Motor City
    Any 1st-gen Hemi trans adapter works on this block so I used a readily-available Hemi-to-GM adapter.
    Also, don't forget to check in with the legendary 73RR...he is in your area; Bend, OR. He built me this as a long block and shipped to me in Detroit via Fastenal. We are now fitting up the bits and pieces to run it on the stand. If I were located closer to Gary, I would have some cool engine projects going before he got around to the Restraining Order. [emoji12] [emoji12] [emoji13] [emoji3]
    Sent from my SM-G892A using The H.A.M.B. mobile app
    Deuces and NWRustyJunk like this.
  3. George
    George
    73RR is QEC, Others potentially are Hot Heads, Wil-Cap, T R Waters
    NWRustyJunk likes this.
  4. NWRustyJunk
    NWRustyJunk
    Good deal. Thanks guys. I'll keep them in mind if I end up dropping the 270 in something.
  5. 73RR
    73RR
    I only make the adapter for the Mopar units...no gm stuff around here.
    jack_pine likes this.
  6. Brand209
    Brand209
    sorry to dig up an old post but jack what headers are you using on that 270?? I'm getting a 56 Plymouth with a 270 in it and it needs a new exhaust
  7. jack_pine
    jack_pine
    from Motor City
    These are Sanderson headers for a Dodge hemi, modified by Sanderson to accept poly flanges I sent them.
    Don't make the same mistake I did and not specify a position for the header tubes. They stick way out from the block so far they don't the "block hugger" headers they started out as :(
    Sent from my SM-G986U using The H.A.M.B. mobile app
  8. AndyDIY
    AndyDIY
    I know this is an old thread, but saw your awesome engine and I have the same one that I'm rebuilding, but can't find a camshaft anywhere. Do you have any sources for a new camshaft, as mine is in poor condition.
  9. Budget36
    Budget36
    He’s not been around since 2016, might be best to make a new thread, let folks know what you’re working on and what you want to have in the end.
  10. Sharpone
    Sharpone
    Budget36 likes this.
  11. Sharpone
    Sharpone
  12. DDDenny
    This may be a question for @earlymopar.
    Sharpone likes this.
  13. caprockfabshop
    caprockfabshop
    I had Egge just do a cam for my 1954 270 Poly this year, I've had Racer Brown do a couple in the past as well as Isky. They all can spray weld yours back and then grind to the new specs.
    Sharpone and Chucky like this.
  14. caprockfabshop
    caprockfabshop
    Also get with Bob Walker at Hot Heads if you need parts, he's one of the only folks around who has the camshaft bearings reproduced for the 241-270 Dodge engines, I had to wait 6months because they were between production runs. Limited quan***ies produced for these engines.
    Sharpone and osage orange like this.
  15. earlymopar
    earlymopar
    For my later generation (mid-60s) Poly, I had a low mileage original camshaft in really good shape. I selected a Schnieder pattern # and sent those specs along with my original camshaft to Oregon Cams who then ground to the Schneider profile. No need to build up the original.
    Did the 270 and other early polys have problems with premature camshaft wear? I had not heard this before.
    jimmy six and Sharpone like this.
