Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    I have one of the Mr Gasket inline for my top loader going in my g***er project.
  2. chevy57dude
    chevy57dude
    Bill, that's the Ram Rod, like in my '57.
    The tall handle on that M21 in the other post may not be the one I use! It is a big letter stick, so an older one. I had to put it on there for fun!
    enloe, Stock Racer, porkshop and 10 others like this.
  3. rusty_bits
    rusty_bits
    Maxwest_Astro_8R_12212025_133834.jpg got my motor and transmission in.
  4. HOTRODNORSKIE
    HOTRODNORSKIE
    It's Christmas so were am I messing around at the shop. Got the rocket painted and decided to mock it up. 20251225_115311.jpg 20251225_115334.jpg
    alanp561, enloe, Blues4U and 28 others like this.
  5. chevy57dude
    chevy57dude
    A gold Olds, super cl***y!
  6. Black_Sheep
    Black_Sheep
    My current project is upholstering the back of the cab so it’s ready when I swap the bench for buckets. Making nice corner radiuses has been a challenge because the top and bottom contours need to have a different arc. Tomorrow I’m going to try making a plywood buck to thermo form some 1/8” ABS plastic sheeting. I’m thinking that making the corners slightly oversized and t******* to fit is probably the best approach. Any tips would be much appreciated…
    alanp561, enloe, swade41 and 10 others like this.
  7. choptop4
    choptop4
    20251222_135229.jpg 20251222_123608.jpg finished intakes for the compressor.
    alanp561, ERguitar, enloe and 13 others like this.
  8. rusty1
    rusty1
    this was my latest automotive project,...a 31 Chevy timing cover ...so it's still keeping time...
  9. TheSteamDocII
    TheSteamDocII
    Sadly, nothing HAMB approved. I'll own something old enough again
  10. BJR
    BJR
    What are you putting that Olds engine in? I have a J2 in my 50 Olds.
    Sharpone likes this.
  11. HOTRODNORSKIE
    HOTRODNORSKIE
    Engine is going into my 35 olds 2 door slant back sedan I turned into a delivery I chopped and channeled .
  12. patsurf
    patsurf
    let's see!
    Sharpone, saltflats and firstinsteele like this.
  13. HOTRODNORSKIE
    HOTRODNORSKIE
    Ok here it is unfinished. 20220226_123406.jpg 20220226_123256.jpg 20250315_113601.jpg 20250315_113523.jpg 20250908_125847.jpg 20251229_105951.jpg 20251229_110009.jpg
  14. BJR
    BJR
    Those door panels and dash are the coolest things I have seen in a long time.
  15. HOTRODNORSKIE
    HOTRODNORSKIE
    The gold 303 rocket I have been building on this thread backed by a M21 is going into it.
  16. patsurf
    patsurf
    Sharpone and HOTRODNORSKIE like this.
  17. Unloaded the trailer just to get more junk
  18. Blues4U
    Blues4U
    from So Cal
    Well, I finally installed the Torque Thrust wheels on the front of my Model A pickup. I had been running mismatched wheels with Torque Thrusts on the back axle but chrome smoothies on the front. The front tires had so much tread left when I installed the rears that I wasn't ready to take them off just yet. But they finally wore to the point that I needed to change them out, so I ordered some front runners from Towell City to match the cheaters I got from them on the back. When I went to install the wheels I found the studs were too short, so I had to change them out. And while I had the hubs off to change the studs I went ahead and cleaned all the old grease out of the bearing and repacked them. So no more mismatched wheels. I liked the old look, but I like this better. And it handles very nicely now. 20251212_144401.jpg
  19. Blues4U
    Blues4U
    from So Cal
    So I got a wild hair up my **** today and decided to get started installing the 32 grill shell I picked up at LARS swap in 24. Got the shell installed, then took it back off to do some straightening and then I'll put some paint on it. Will be ready to go for GNRS. Resized_Resized_20251229_150639.jpeg
  20. Blues4U
    Blues4U
    from So Cal
    After some minor straightening with hammer and dolly I got the shell sanded down and uncovered more damage that was hidden under some filler. Did my best to get that straightened out, put a skim coat of filler where needed, then today I got a break in the weather and got some primer on it. Tomorrow I can start sanding it down again in prep for some color. 20260101_161715b.jpg 20260101_161754b.jpg
  21. Black_Sheep
    Black_Sheep
    Got the buck for the cab corners ***embled and attempted to form an ABS panel, the first try was an abject failure. On the second attempt it turned out great, but I only had enough material left to do one side. More ABS will be here Monday…
  22. Sandcrab
    Sandcrab
    I'm putting together a 215 Buick with a 300 crank and have not been able to find an externally balanced flywheel so I picked up a Craigslist SBC example. I turned a 156 tooth ring gear to fit in place of the 153 tooth and then heated it to mount. I also had to move one hole since it was for an internally balance engine. Then by balancing the 300 flex plate on the tire balancer determined the counterweight needed. A piece of bar stock that matched the bolts weight and distance from the center was cut and mounted. Final mounting will be countersunk flat head screws.
    20260102_141216.jpg 20260102_141617.jpg 20260102_142728.jpg 20260102_150027.jpg 20260102_174700.jpg
  23. Greg Rogers
    Greg Rogers
    I may be way wrong, but doesn't a " balanced" flywheel "balance" out the "imbalance" of the rotating ***embly? It seems to me balancing the flywheel on a tire balancer would not work? I hope I am wrong and it works well for you.
    Bill's Auto Works likes this.
  24. Sandcrab
    Sandcrab
    Here is my take.
    Look at the flex plate. The two cutouts make this piece out of balance to correct the imbalance that could not or was not done with the counterweights on the crank. Also, there is the fact that one mounting hole is offset by about 0.125" so it could only be mounted one way. The weight was about 7 ounces at 3" from the centerline.
    I am new to the small Buicks but this also came up when I put a Mcleod flyweel on the 215 crank.
    Sharpone and Bill's Auto Works like this.
  25. patsurf
    patsurf
    i am going on record--AFTER eugene's reply---to say this mad scientist fella can pretty much do anything and it will work--if you met him you'd understand!-of course i was surprised as anyone at his method!
  26. Sandcrab
    Sandcrab
    Thanks patsurf. I got interested in balancing when I built my smallblock. Similar models typically hopped around the tables when they were run at shows. So I built a balance fixture that was driven by a sewing machine motor. I matched the rod big end and little end weights and cast lead bob weights based on the V8 formula of 50% reciprocating and 100% of rotating m***. The holes I drilled in the counterweights matched the full size crank I had copied. It hangs dead nuts still through a range of RPM in the fixture and the engine runs with minimal vibration.
    BigRRR, enloe, chevy57dude and 9 others like this.
  27. swade41
    swade41
    from Buffalo,NY
    I'm making a mess stripping funk, gunk and something that smells like a sunk, off the frame of the 57
    BigRRR, enloe, chevy57dude and 18 others like this.
  28. Greg Rogers
    Greg Rogers
    Ah, I read back and now see what you are doing Sandcrab- pretty clever, seems like it will work. OOPs carry on....
    Bill's Auto Works and Sharpone like this.
  29. Almostdone
    Almostdone
