Hot Rods The (mis) Adventures of a Compulsive Tinkerer
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Apr 13, 2024.
  1. bchctybob
    bchctybob
    X-cpe, the 2x4 trick was on my list of things to try. The rough wood surface seems like the perfect “bite” and the pinch provided by a sawblade width seems equally perfect. But….
    We have a winner!! Budget36 had the idea that saved the day. Hole saw!
    SS327, Budget36 and Algoma56 like this.
  2. bchctybob
    bchctybob
    I got out my 3/4” hole saw and found a 1/2” OD X 1/4”ID x 2”L spacer that I could use for a pilot. I used the sleeve and two hose clamps to hold it and clamped that goofy mess in my drill press vise. I was surprised how nicely it cut. Following the 1/2”D pilot, it went straight through without a hint of slipping or grabbing. The 5/8” ID bushings pushed right in like they were made for them.
    Problem solved!! Thanks guys!
    wicarnut, enloe, porkshop and 13 others like this.
  3. bchctybob
    bchctybob
    I moved on to the rear suspension layout, what fits where, how much room, new rear crossmember, spring options. With the springs as far apart as the frame allows they’ll be about 35-36” apart, not bad. If I make a new rear crossmember the coils will fit behind the rear axle where I really want them and it looks like the Corvair springs will be the right length. I checked and Clark’s Corvairs has three different spring rates for the ‘65-‘69 rear so I’m sure to find something that works. I’ll start with what I have.
    I would really like adjustable upper spring buckets but I didn’t see them in the Speedway catalog. I suppose I can make my own….
    wicarnut, enloe, Thor1 and 3 others like this.
  4. Budget36
    Budget36
    I’ve no doubt you can make what you want/need.
    You’re like the guy who can build a vehicle around a radiator cap. :)
  5. X-cpe
    X-cpe
    Did you look for weight jackers? (stock car stuff)
  6. bchctybob
    bchctybob
    You might be right, I forget that Speedway is divided into Race, Street and Hot Rod. I normally just shop their Street Rod/HotRod stuff.
    Edit; I looked through the Speedway Race catalog but I didn’t see anything that I would use in my application. I also searched through other suppliers. I think I’ll make my own if I decide to go adjustable.
    Turns out I usually look at the Street Rod part of Speedway cause that’s where my bookmark takes me. I miss the old paper catalogs.
    enloe, X-cpe, Thor1 and 1 other person like this.
  7. bchctybob
    bchctybob
    I ordered steering parts so I can get the steering column and stuff worked out while the Buick is in place. It’s the tighter of the two engines with regards to the steering shaft with the starter being on the driver’s side.
    I also ordered some materials to make my own adjustable coil spring pockets.
    So once again, waiting on parts. Maybe I’ll start welding up holes…..
    wicarnut, enloe, porkshop and 5 others like this.
  8. bchctybob
    bchctybob
    I pulled out the steering column, I decided to shorten it. By taking 2 5/8” out of it the u-joint will be above the starter/solenoid and (I hope) the shaft will p*** by with room to spare.
    Easy to cut the mast and the shaft, not as easy to make a spacer for the lower bushing without a lathe. But with a piece of 1/2” aluminum plate, a hole saw and a belt sander I finally arrived at one. I had a bronze bushing, I made the aluminum spacer a press fit in the mast.
    I kinda like this old Ford column, the guy sold me four for $20 (various versions) as he was packing up his swap meet space. One I traded for a clean, low mileage 110hp Corvair motor. This one I think he said was from a ‘41 pickup. IDK, don’t care really. I kinda got ahead of myself making a column drop. It all seems to fit ok, I won’t know for sure until I get some kind of seats in there. I have the column shift stuff too, I’m hoping to maybe make it work with the TH400.
    Sorry, ****py picture….
    wicarnut, Stock Racer, enloe and 8 others like this.
  9. bchctybob
    bchctybob
    I put the steering column back in and it’s close but it should be ok. I still have a few tricks left if it proves to be a problem once the new u-joint and shaft arrive.
    Now it’s on to some hole filling….
    wicarnut, enloe, porkshop and 2 others like this.
  10. bchctybob
    bchctybob
    This thread is about compulsive tinkering after all….
    I got my other Hemi heads back from the machine shop the other day, race ready. The block is also finished now but balancing the rotating ***embly came to a screeching halt. Willy and I unwrapped the crankshaft and started to inspect it. Something was terribly wrong. It’s beautiful, polished, knife-edged, nitrided and the rod journals are hard chromed. I figured it had been given the full blown alcohol treatment at Velasco’s as I had requested. BUT, the rod journals are SBC size, the mains are 1/4” too small, and the snout looked kinda small. Huh? We contacted our local crankshaft guru and read him the forging number. “That’s a Studebaker crank you’ve got there guys.” Holy ****…..
    Months ago I retrieved this engine from my friend’s garage where he had kindly offered to store it when the machine shop I was using in LA abruptly shut down. Thankfully, he was good friends with the owner and lived nearby. He gathered up all of my Hemi stuff and took it to his place. He also ported the heads and got the guides installed. A few years later I was settled in my new digs in NorCal and went to pick up my Hemi parts.
    Now, it made sense, my buddy is a big Studebaker guy. I guess he dragged out the wrong crankshaft when I came to pick it all up! I’m hoping that mine is still in his shop. I need to go down to LA and swap em. In the meantime I’m prepping the block and heads for storage with good old Gibbs, some heavy duty plastic bags and some desiccant. Where I’m gonna put ‘em, I have no idea….
    wicarnut, Stock Racer, enloe and 12 others like this.
  11. mohr hp
    mohr hp
    from Georgia
    Crankshaft for the wrong engine, this is a first, right?!
    enloe, Budget36 and bchctybob like this.
  12. bchctybob
    bchctybob
    Yeah that was quite a surprise and a bit of a disappointment. Here’s this beautifully done crank but it’s not mine! I really hope that when I do get down to LA and get mine: #1, I hope it’s there! And #2, I hope it’s finished like this one.
    This 392 was supposed to go into the ‘41 Willy’s pickup that I built in the 90s to go nostalgia racing. It was going to be a solid old style blown alcohol motor. But, that didn’t happen mostly due to work commitments and the work load at my own shop and I eventually sold the Willys pu as a roller when I got my Austin. While I had pretty much everything to build it, the machine work wasn’t complete. The only thing left is the rocker arm ***emblies. And maybe a crank? Hope not….
    wicarnut, Budget36, SS327 and 2 others like this.
  13. bchctybob
    bchctybob
    On the road today.
    I responded to an ad on Marketplace for a pair of new fibergl*** ‘33-‘34 pickup fenders. Only an hour and a half away…
    Well, they are new, from PolyForm but I don’t think they are ‘33-‘34, maybe later? Anyway, they will work for me.
    Anyone recognize this decorative reveal? My ‘33 fenders look more squared off, like a Model A fender.
    Ekimneirbo mentioned rotating the fender forward to get the effect of a “bobbed” fender. These should do nicely.
    B463CE56-EE9D-4297-B25B-63E92A79A4A2.jpeg 235E6B98-8201-492E-80D2-FD1FEB8DD9CE.jpeg
    Anyway, glad to have them.
    wicarnut, enloe, porkshop and 9 others like this.
  14. bchctybob
    bchctybob
    While I was out, the carrier pidgeons delivered these hunks of metal I ordered to make adjustable spring sockets. They are a little heavy but that’s the only size I could get with the right ID. Nothing available locally. I just need some 1” all-thread and some nuts.
    I had some 1/4”x 5 3/8” diameter discs that I made for something at one time, they’ll work perfectly.
    wicarnut, enloe, X-cpe and 2 others like this.
  15. bchctybob
    bchctybob
    I forgot to mention that a couple weeks back I was looking for a 3rd member for the new 9” rear end but holy moly those things are expensive now days! So I looked around and found a set of brand new in the box Richmond Gear 3.50:1 gears for $75, an hour away. Just what I was looking for. When I got home, I poured a cup of coffee, sat down and found a brand new set of Motion 4.30s for $100 just a couple miles away. Went and got them too. So now I have 3.50s, 3.70s and 4.30s. I cleaned, inspected, oiled and repackaged everything till I need them.
    37AD61A9-A05B-45C5-A954-7B05F7ACA144.jpeg 723A2CE6-47EE-44B2-A7AC-203460EA0399.jpeg
    Both sets had been sitting on a shelf in a garage and they just wanted to get rid of them.
    I looked around my shop and dug up a 31 spline carrier that I didn’t remember having. I spread everything out and it all looks great so all I need now is bearing and seal kit. I have several cases. So for a couple hundred bucks I’ll have my 3.50s and I’ll watch for a deal on a posi for the 4.30s.
    wicarnut, enloe, porkshop and 10 others like this.
  16. Budget36
    Budget36
    Re:The rear fenders. 35-7 don’t have that little design on the rear of them. I could be a manufacturer “design” or maybe not for Fords? I can get a pic of the backs of my ‘36 fenders on Sunday or Monday for you to see what I mean.
    Of course I may have memory loss as well;)
    enloe, bchctybob and loudbang like this.
  17. slowmotion
    slowmotion
    Extra points for the ABB CD at the top of the pile!
    Algoma56, enloe, loudbang and 2 others like this.
  18. bchctybob
    bchctybob
    Yeah, one of my all time favorite bands. A go-to when I’m working in the shop. Reminds me of working on my HDs late at night in the good old days.
    wicarnut, enloe, Thor1 and 2 others like this.
  19. bchctybob
    bchctybob
    A little update….
    My steering u-joint and shaft came and everything looks good. I like the Sweet Eng. u-joints from Speedway.
    I decided to do a little casting flash removal and cleanup on the Buick 2x4 intake manifold. It cleaned up nicely and it’s ready to go to the powder coater if I decide to go that way. No pictures??
    While grinding on the Buick intake I remembered that the Chrysler water crossover needed some attention too. So, as long as I’m covered in grinding dust…
    I cut off the big generator boss on the driver’s side and shortened the upper attachment bolt boss. On the other end I cut off the byp*** hose ****** drilled it out and tapped it for 1/2” pipe. I’ll put the mechanical temperature gauge there. I shortened the attachment bolt boss on that end too and re-spotfaced them.
    I didn’t notice the little “wing” on each end until I bolted it on. They serve no purpose so I’ll grind them off too. The whole thing needs a final going over. Oh yeah, I got my real aluminum water pump came.
    I drilled and tapped the backside boss for 1/2”pipe too. I think it’s going to be my byp*** to/from the top of the water pump instead of the front boss.
    wicarnut, Stock Racer, 5w Jen and 5 others like this.
  20. bchctybob
    bchctybob
    My most recent front end mock-up found that the tie rod hits the bat wings before full turn. ?? It seems that the Speedway steering arms that I had in stock don’t play well with SoCal hairpins and batwings. It’s not missing much turn radius, I was just a little surprised, I thought most of those parts were sort of standardized by now. (It turns more than it looks in the pictures)
  21. bchctybob
    bchctybob
    From the “use what ya got” or “ think outside the box “ or maybe “don’t eat leftover shrimp scampi before going to bed” file…
    I ran across the quarter elliptic springs that I made up for my Willys pickup years ago. I built the Willys ch***is to use either quarter elliptic leafs like the old days, or coil overs. I made ballast boxes that bolted on in place of the leafs if coil overs were being used.
    So I wondered if I could use them with the trailing arms on this truck. The brackets would weld to the boxed area on the inside of the frame about 18” forward of the rear axle centerline. The back end could ride on plates welded to the top of the trailing arms. Pretty simple. Much easier than the coil springs, and adjustable for height and stiffness. Any opinions??
  22. mohr hp
    mohr hp
    from Georgia
    Can't tell without a side view, but won't that bind? 2 different arc paths?
    chryslerfan55, enloe and porkshop like this.
  23. rod1
    rod1
    @Marty Strode ?
  24. bchctybob
    bchctybob
    My thought was to weld a pad on top of the trailing arm and just let the spring ride along the top, not mechanically connected. Maybe a Teflon or nylon pad to ride on. The springs are free to lengthen and shorten as they move up and down.
    A long Panhard bar will keep it the housing centered with help from the triangulation of the trailing arms and the shocks dampen everything and limit the drop when jacked up.
    Maybe something like this could be used but I don’t think it’s necessary, the springs just support the vertical load. These are from Calvert.
    wicarnut, chryslerfan55, rod1 and 5 others like this.
  25. bchctybob
    bchctybob
    I’ve decided that I like the wishbones more than the hairpins (hairpins seem too short), so I put them back on along with the steering arms and stuff. Everything seems to work like it should, I was concerned about the tie rod hitting the damper with all of the weight on but the tie rod falls between the damper and the pan and there’s tons of clearance anyway. So I’ll tack weld the tabs for the wishbones after I square everything up. Right now the jack stands are in the way so I need to reposition them. While doing that, I also want to set it on the ground to check the height.
    Hmm, going to need front wheels and tires for that…. I went upstairs and scrounged up some lug nuts that would work with the Halibrands. Then I got out the new Speedway rotors I got for it. No bearings. I got out the new disc brake kit, only inside bearings. Dang. Apparently, I don’t have any outer wheel bearings for these rotors. On to Plan B. Back upstairs….
    I have a set of spindle mount Eric Vaughn Real Wheels with new Michelin tires that I bought for my Willys and never used. I can stick those on.
    They didn’t go on without some drama, the temporary steering arm bolts wouldn’t let the wheel go on all the way so I had to make some special short Allen headed bolts. Then everything fit together fine.
    I’m starting to like the looks of this thing…. Starting to get that old excitement. We’ll see how it looks on the ground tomorrow, too late to fire up the compressor and air up the tires tonight.
    X-cpe, wicarnut, Fordors and 14 others like this.
  26. bchctybob
    bchctybob
    It’s on the ground!! Well at least the front is…. The Model A crossmember did what I hoped it would and put it down nice n low.
  27. bchctybob
    bchctybob
    Now I’ve got to get the rear end figured out. So I laid out some lines on the floor to help figure what goes where and so I could make some saddles for the housing. A little time with my Sawzall and a sidewinder and I’ve got the saddles roughed out. A wish I had a huge welding table so I could lay it all out and clamp it so I could tack it together. I’ll have to think up something.
    IMG_7299.jpeg IMG_7302.jpeg I tried using common leaf spring pads but they seem too short. They work fine for leaf springs? But they just didn’t seem right, so I cut up some 2x3 rectangular tube. I like that better. I’ll pretty them up after I know how I’m going to mount them and stuff.
  28. 69fury
    69fury
    from Topeka
    Those are leaf spring sliders for the eyebolt ends. I've got a set i'm putting on the front axle of my falcon.
    You may want Ladder Bar floaters, that go between the axle tube and the center pin of the leaf spring. Ladder bar floaters allow for 2 different arc paths like sliders would. I'm not sure if one is better than the other for your situation.
    I've not seen them fitted to quarter elipticals, but i'm sure it's doable.
    Technical - ladder bars with leafs sliders on the springs or not? | The H.A.M.B.
    Technical - Pics of your leaf spring Floaters (fitted) | The H.A.M.B.
    -rick
    porkshop, bchctybob, Thor1 and 2 others like this.
  29. bchctybob
    bchctybob
    At my age working on the floor is the last resort. Several years ago I gave my ch***is jig to a buddy of mine thinking that I wouldn’t need it anymore and he needed it to build his Model A frame. He said it would be in his back building when he finished his frame, just come get it when you need it. Well his unfinished ch***is was still on the jig last time I checked so….
    I pulled out my precision saw horses, found a suitable area and leveled them up.
    Turned out that the sawhorse was not long enough for the spread of the back of the trailing arms. So I went out back to see what I had to extend it. Recognize the two yellow pieces? It’s the side plates from my old dead floor jack - worked perfect.
    Everything on the ’horses ready to make it all work together.
  30. bchctybob
    bchctybob
    With the trailing arms in place I final-fit the saddles and trimmed them to look a little prettier. I might box them in as much as I can leaving wrench access. I had strung a centerline to work from so I centered the housing and initially started with the front of the arms close, 4” gap between them.
    I found a cardboard tube to simulate the driveshaft and made a saddle to hold the rear of it in approximately the place where the rear yoke will be. It’s an offset pinion rear end so I wanted to see what the driveshaft relationship was with the arms. The front of the arms were too close to the driveshaft so I spread them to 7”, then eventually to 8”. Originally, I had offset the Buick engine 1” to clear the steering shaft, so I spread the arms to accommodate the offset at the tailshaft but I remeasured the engine and it’s centered (I forgot that I had inched it back after I got the steering shaft in place and it fit with everything centered in the ch***is)
