Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Beanscoot
    Beanscoot
    It's winter in the Pacific Northwest, I see brine and salt on the roads near me.
    Sharpone, Okie Pete and Paul like this.
  2. Paul
    Paul
    Editor
    pictures are what it looks like now.
    there is still plenty of work left to make it road ready.
    the plan is to sleeve the through frame bolt holes, which means pulling the engine to weld them in.
    not looking forward to that
    there may also be clearance issues with the upper bars that will have to be addressed.
    All in due time
  3. Roothawg
    Roothawg
    I forget….it was 84 here yesterday.
    sko_ford and Sharpone like this.
  4. Okie Pete
    Okie Pete
    And wind chill of 13 in the morning
    Roothawg and Sharpone like this.
  5. silent rick
    silent rick
    you do nice work
    Sharpone and Paul like this.
  6. Snicklefritz65
    Snicklefritz65
    from Mass.
    yes that is some nice work.
  7. Roothawg
    Roothawg
    What is this piece you have chucked up in the drill press? I glanced at it the other day and ***umed it was a tapered reamer, but then upon a second look, I didn't see any flutes.
  8. RICH B
    RICH B
    I was wondering about the bar geometry when you built them; but just thought that the set-up would cause a change in caster during suspension movement. How did you determine they were binding resulting in the harsh ride?
  9. Paul
    Paul
    Editor
    it's spinning
    Roothawg likes this.
  10. Roothawg
    Roothawg
    Ahhhhh…..makes sense.
  11. Paul
    Paul
    Editor
    it wouldn't be as much of an issue with a beam axle but with the rigid tube axle the bars act much like a split wishbone or hairpins,
    when one wheel rises it will try to lift the other wheel.
    ie: bind
    that bind is absorbed by the bars.
    it's evident by watching the bars flex when one wheel is jacked up.
    if one wheel is jacked up the other will follow, not 100%, the bars will flex first but if I jack more than about 4 inches the other will start to lift.
    the bind causes the harsh ride and of course fatigue in the weakest link, the bars.
    I knew all this going in and I don't think it's about to fail, but it's definitely not optimal
    in terms of ride quality or longevity of parts.
    bchctybob, bct, RICH B and 2 others like this.
  12. RICH B
    RICH B
    Thanks for the follow up.
    Good explanation; the rigidity of the tube axle didn't register in my head.
    Paul likes this.
  13. Paul
    Paul
    Editor
    one side coming together
    enough for a test fit anyway
    bchctybob, Tim, dana barlow and 4 others like this.
  14. Paul
    Paul
    Editor
    how I tapped the rod ends after shortening,
    chop two inches off a tapped rod end
    cut the rod to length
    drilled a piece of hard wood, rock hard maple here
    exact size as OD of tube
    slice the wood to allow compression
    stick both tapped stub and untapped rod in the wood block and clamp in vise.
    using plenty of cutting oil run the tap into the tubes using the tapped stub to align with the untapped rod
    after enough thread has been cut into new rod remove the stub and continue tapping the rod.
    gives a nicely centered and aligned thread to the new shorter rod.
    bchctybob, torpedo jones, Tim and 7 others like this.
  15. Dave G in Gansevoort
    from Upstate NY
    Nice, Paul. Having the 4 bars parallel eliminates any twist, as long as they are essentially the same length for all 4. Being basically lazy, and having access to a pipe threading machine in the past, and not a lathe, I have used one for tapping 4 bars and tie rods and drag links. Just thought I’d share this in case anyone else is doing the same thing. I’m keeping my eyes open for one as my lathe isn’t big enough or powerful enough for threading long and large pieces.
    bchctybob likes this.
  16. Paul
    Paul
    Editor
    thanks Dave,
    yes it would be nice to have all the tools a fully equipped shop would have but when we don't we try to make do.
    my little old lathe is too small too.
    the through hole on the SB 9A is only 3/4"
    these tie rods are 7/8" OD
    bchctybob, Tim, dana barlow and 2 others like this.
  17. Dave G in Gansevoort
    from Upstate NY
    And why is it that we never have enough room for the toys? Your shop looks just as crowded as mine…
    Paul likes this.
  18. Paul
    Paul
    Editor
    it's full
    paths are clear but if something needs to come in something has to go out first.
    making progress
    PXL_20260107_213839632.jpg PXL_20260107_220929168.jpg PXL_20260107_220916954.jpg
    bchctybob, Tim, The 39 guy and 5 others like this.
  19. Paul
    Paul
    Editor
    I managed to put together a tie rod kit over the years.
    11/16"-18 right and left taps and dies
    and left and right threaded stubs
    it's come in quite handy too.
    bchctybob, Tim, RICH B and 5 others like this.
  20. Paul
    Paul
    Editor
    p***enger welded bracket removed.
    apparently I never expected to have to, because they made me work for it.
    now ready for dis***embly and paint.
    'jacked one wheel up about 6" and the other stayed on the ground. the old setup couldn't do that.
    looking forward to seeing how it rides.
    bchctybob, AndersF, warbird1 and 5 others like this.
  21. RodStRace
    RodStRace
    T-Bucket articulation, what a concept!
    Now I'm going to have to try that on mine! :)
    bchctybob and Paul like this.
  22. twenty8
    twenty8
    The new version looks like it will work much better. 4 bars should be set up as a parallelogram so they eliminate bind.
    Paul likes this.
  23. RodStRace
    RodStRace
    Here's a calculator for finding the angles. I am too far removed from high school geometry to figure this out, but maybe someone like @Tim_with_a_T can get to info that's useful. I'd guess most have 3 inch up, 3 inch down travel at the most at the axle. So a total of 6 inches along a length of at least 2 feet, probably closer to 3 feet. I'd guess the caster change isn't too much.
    https://www.calculatorsoup.com/calculators/geometry-plane/parallelogram.php
  24. Paul
    Paul
    Editor
    yes and with the drag link p***ing through the rear upper bar joint pivot point bump steer should be negligible even with the divergent 4 bar/drag link angles
  25. twenty8
    twenty8
    If the bars are a true parallelogram there will be NO change to caster at all.
  26. RICH B
    RICH B
    That is a slick way to tap tubes; I used a different approach and took a piece of tube bored to just clear a tap and it welded to an angle; clamp the "tool" on the tube and the tap goes in nice and straight. Made one for 11/16" Ford ends and another for 5/8" clevises used when building hairpins or ladder bars. Now we power tap on my kid's lathe.
    Really like the articulation you gained on the front; has to ride better. Makes you wonder how the "famous" hot rods with un-parallel 4 bars really worked.
  27. Beanscoot
    Beanscoot
    For those lucky enough to have a lathe, you don't need a tap (or dies), you can single point cut the threads.
  28. JReece
    JReece
    @Paul just subbed you on YouTube, good stuff! Mine is HiRevz Media.
    Paul likes this.
  29. Paul
    Paul
    Editor
    wet paint ***embly
    bchctybob, Stogy, RodStRace and 6 others like this.
  30. Paul
    Paul
    Editor
    all together now
    just back from first time "around the block"
    much less harsh, especially when one wheel hits minor road changes, manhole covers, filled pot holes, pavement breaks...
    but also a little less flat in the corners,
    more like a normal car where before it was more like a slot car.
    all in all I think it was a good move.
    PXL_20260110_204533476.jpg PXL_20260110_204547969.jpg PXL_20260110_204605821.jpg
