Technical Need help to ID on this door
Discussion in 'The Hokey Ass Message Board' started by bustingear, Jan 7, 2026 at 8:25 AM.
  1. bustingear
    bustingear
    doort9.jpg doort8.jpg doort7.jpg doort6.jpg doort5.jpg . Solid metal both sides no wood. 20" tall 20" wide. Thanks in advance
  2. BJR
    BJR
    Dodge its always Dodge.
    2Blue2, hrm2k, 5window and 2 others like this.
  3. bustingear
    bustingear
    what model and years?
  4. 51504bat
    51504bat
    Early:cool:
  5. bustingear
    bustingear
    got that trying to pin it down
  6. gene-koning
    gene-koning
    Dodge always gets the blame, but in this case it may be correct.
    I'd say that door is from the late 19teens or early 1920s. There were only around 2,000 auto builders around the USA during that time frame, but many used wood as a framing structure, Dodge was mostly all steel construction for their car bodies from the beginning, in 1914. Their first (and only offering ) was a 4 door sedan with the rounded lower corners, it was built pretty much unchanged from Nov 1914 through the 1916 model year.
    Dodge was the # 3 auto producer in 1914-1915 (behind Ford and Willis/Overland), and was the #4 auto producer up beyond the death of the two Dodge Brothers in 1917. Walter P Chrysler bought the Dodge motor company in 1924 from the holding company that was still producing Dodge cars and trucks. According to the Standard Catalog of Chrysler, 1924-1990.
  7. 51504bat
    51504bat
    Sorry, just being a smart *** but FYI: contrary to what @VANDENPLAS says it's not always a Dodge:cool:
    It’s always a Dodge !
    Algoma56, Just Gary, hrm2k and 2 others like this.
  9. bustingear
    bustingear
    Back to reality ...anyone able to pin it down?
  10. 51504bat
    51504bat
    @squirrel must be on a road trip somewhere or we would have had an answer by now
  11. gene-koning
    gene-koning
    There used to be a website that you could look up a model year, and look at pictures of most of the major auto manufacturers for that specific year. Then, if you wanted, you could even break it down more by adding a brand name and look at many pictures of cars from that time frame for that specific brand, but that website no longer exists.
    You are looking for someone who may posses a door like you have that knows exactly what it came off of. That may take some time.
  12. squirrel
    The current web page that lets you look at detailed pictures of many cars is bringatrailer.com, which is an online auction. They usually have a whole bunch of pictures inside and out, underneath, etc. But they don't have too many early cars, so that will hamper things a bit.
    Things like the inside door handle will help you confirm if it's the same car or not...little details like that make all the difference.
    in this case, there's a 1917 dodge touring car on BAT, take a look at the door on it compared to the mystery door.
    Is it the same? Might be? Perhaps a different year?
  13. ronzmtrwrx
    ronzmtrwrx
    IMG_2189.jpeg This is supposed to be the left rear door on a 1916 Dodge touring car according to the web. It looks close.
    41 GMC K-18, Just Gary and 51504bat like this.
  14. Heres my 2 front and 2 rear Dodge Brothers doors and the 110 year old holes they have to fill. The latch and bulge look like a decent match.
    VANDENPLAS and 41 GMC K-18 like this.
  15. SS327
    SS327
    I say it’s a car or truck door. I know, I’m of no help.
    Flathead Dave likes this.
  16. bustingear
    bustingear
  17. bustingear
    bustingear
    find another site
    pecker head likes this.
  18. dwollam
    dwollam
    That is indeed a Dodge Brothers door. It is an early '22 and earlier DB Screenside door. They didn't have any upholstery on them like the cars did. Also, touring cars changed the doors in 1920 but the Screenside (Commercial Cars as Dodge called them) kept the early style doors thru early '22 and the roadster kept early doors thru '23 with the addition of outside handles on the roadsters starting in late '22 and '23 with all models changing to new bodies and frames in 1924.
    Dave
    spudshaft, 34 GAZ and squirrel like this.
  19. dwollam
    dwollam
    @34 GAZ Your touring body is a 1919 or earlier and your doors are '20-'22. Different doors, different hinges and won't fit that body. Sorry to be the bearer of bad news.
    Look at @squirrel 's door pics and notice the narrow forged hinge vs your wide stamped hinges. Also the top of the early doors are attached with wood screws whereas the later door tops are an integeral part of the door skin.
    Dave
    34 GAZ likes this.
  20. I have'nt touched this thing in the last 20 years :oops:. Now i remember why :rolleyes:. The big pallet became firewood and the castors went under engine stands.
    dwollam likes this.
