Projects The 48 hour coupe
Discussion in 'Traditional Hot Rods' started by redzula, Jun 12, 2023.
  1. Tim
    Tim
    from KCMO
    Awesome! I bet reving it in that garage had nothing to do with it being loud either haha
    redzula likes this.
  2. redzula
    redzula
    Haha oh course not
    Tim likes this.
  3. redzula
    redzula
    Got it out and drove it this morning. Still no video cause I can't seem to convince my 11 year old to come out and take the video and shes the only one home right now.
    Verdict.
    It's a handful lol. Its a bit squirrly, its still new to me actually driving it, I dont fit very well (I probably need to adjust the seat position some to address that. Its full sensory overload. But I got it out on the main road and scared some normies in their Toyotas and Kias lol.
    It still has a pretty nasty dead spot just off idle butbthe ignition timing I did last night helped shrink that a lot. Mostly a problem starting from stopped and if youre cruising with almost no pedal input in 2nd or 3rd. Definitely seems related to having the throttle almost closed and trying to open it up. I'll definitely be able to deal with it enough to try cars and coffee in January as long as the weather cooperates.
    Once you get past the deadline spot and open it up is revs up nicely. It wasn't just the garage making it loud as hell (@Tim ) lolol.
    It has a boat load of blow-by smoking out the breather and the road draft. Not sure where I need to go with that. I ***ume its worn or sticking piston rings, but it has good oil pressure, good steady vacuum, and other than the one spot i mentioned runs pretty well. I was kinda hoping driving it would loosen up the rings but it hasn't really gotten any better so far.
    I'll keep messing with it I guess. I do have what I think is a rebuildable 59a in my truck back in Iowa. That truck will be getting an olds when I get around to it so maybe I work on putting that flatty together on the side for this.
    RMcCulley, Thor1 and Tim like this.
  4. Tim
    Tim
    from KCMO
    Ya know, 11 year olds who don’t take videos of their dad acting like a 14 year old end up on Santa’s bad list. I’m just sayin. Lol
    Outback likes this.
  5. redzula
    redzula
    I tried that angle. Lol she read straight through my ******** haha
    I've since contracted the newly minted 14 yo (birthday was yesterday) to help me out sometime today cause she actually likes me lol.
    Outback and Tim like this.
  6. redzula
    redzula
    Update she doesnt like me as much as I thought cause I interrupted her game on roblox whatever that is.
    She paused the video while I was down the street and turning around so you miss the part where I got on it in second coming back just trying to build speed a little.
    https://youtube.com/shorts/kyFmXC2_SDM?si=iebFNLD_-02F-v6h
    And here's a short one from before I left trying to show just how much blow-by its pushing out.
    Not sure why the longer video wouldn't upload as anything but a short and the shorter one as a regular video.
    Outback and Thor1 like this.
  7. Tim
    Tim
    from KCMO
    Oh that’s not as bad as I expected! I bet our discussed options work. Car looks and sounds great!
    you have to film in landscape/ horizontal and preferably over 30 seconds long to get proper imbedding :)
    Outback likes this.
  8. redzula
    redzula
    Im going to get some seafoam like we talked about @Tim and see if that loosens up the rings some. That video was after it had already warmed up a bit. It smokes a ton especially if you choke to get it warmed up which brings up the idle speed it just pours our when its cold. It still smokes when its warm but it slows down a lot.
    As for drivability I am waiting for new jets and power valves since if I remember right I just used the same as I did on my last flathead when we lived in Iowa. About 1000' higher elevation. Wouldn't think it would make a huge difference. I also went with 5.5 powervalves. I currently have a plug in 1 and 5.5 in the other. Thinking with all that popping I was having way back maybe I blew the one out. And I got a second so I could try it with 2 - 5.5 and no plug. My vacuum at idle is steady at 20. Haven't convinced anyone to ride with me yet to check it at cruise. But 5.5 worked pretty well before. I am currently thinking my stumble is powervalve related though.
    Today as a side quest while I wait for parts. I tried my hand at painting and lettering my license plate i got when we first moved to South Carolina.
    What I started with 2 years ago.
    That got a citric acid bath and etch primer back when I first got it.
    Google just said white background with black digits but no specific color code or anything. So thats what I did.
    It'll need some touch ups but I'm going to let it fully dry before I do that.
    Both colors are just semi gloss spray paint. For the lettering I sprayed black into a cup and used a cheap set of artist brushes.
  9. Tim
    Tim
    from KCMO
    That aught work!
    You could see if your carbs have an option for a throttle rod on the other side of the carb. Then you have a foot feed and a hand throttle, I have a few that way so I can idle it up with out choking it. I think in the mid 30’s ford did this so you could get the car to charge while parked.
    Plate should look perfect on the car :)
    Outback likes this.
  10. redzula
    redzula
    My 47 had the hand throttle. Id have to rework my current linkage to make that work. It currently has pedal attached to rear carb on the p***enger side. Then the 2 carbs are linked together via linkage on the drivers side.
    If I remember right with the 47 the hand throttle attached to the drivers side (choke handle was p***enger side) so I'd have to move the syncing linkage to the other side.
  11. redzula
    redzula
    Well I was wrong about what I ordered for power valves. I ended up getting 2 #6.5s to replace the 1 #5.5 and 1 PV Plug. And 4 new .051 jets.
    Put tore down the carbs and installed all that last night. Too late to fire it up when I finished. To today I got it all back running. Amd adjusted. Still need to verify the carb sync but its running way better now. There's almost no stumble not and it runs pretty good. I still dont have a videographer so I tried multi tasking while driving to get you guys what you've been waiting for.
    https://youtube.com/shorts/B3YCpiss2js?si=xC8GqFl1JWnIDZjk
    https://youtube.com/shorts/meVRard_UzI?si=VtyD2Tb3nBUoKtQ6
    Exhaust is still loud but when I don't have to drive it like I stole it just to go anywhere it ain't too bad.
    Stumble is all but gone like i mentioned.
    To dos:
    quick and easy:
    -Replied the brakes. Taking a pump or 2 sometimes to get comfortable pressure.
    -Clutch pedal rod needs a little more adjustment. It is dragging a little.
    More involved:
    -Trans sounds mad in deceleration probably need to go through that at some point
    -Rear end. Is leaking a little i havent investigated yet so not sure where. Also want to swap the 4.11s for something a little taller..
    Bodywork stuff.
    I have all the roof pieces to except for the front header and visor but I think ill be able to reuse those pretty easily.
    But for now a few days off because were heading to Iowa tonight.
  12. redzula
    redzula
    Neighborhood cruise in was still canceled for last Saturday but the weather wasnt too bad so I got thebcar out a little. Made a grocery store run and promptly ran out of gas on the way home lol. The wife wasnt too thrilled with that phone call lol. I've been using a chunknof old model a brake rod I had as a "tank stick" to check fuel level. But being a cylinder when you get to the bottom its deceptive how much is actually in the tank. An inch mid tank could be a gallon or more. But an inch at the bottom could only be a half gallon or less. (Funny enough this exact same thing is true in gas station underground storage tanks but on a larger scale. Which I deal with at work somewhat so there really is no excuse for me forgetting that)
    Anyway she brought me the empty gas can I had at the house i put gal in and marked my tank stick at 5 gal. When I have a little more time ill drain it fully and put in a gal at a time and mark the stick and repeat ext. So I'll know where I'm at with a little more accuracy.
    It was also drizzly out and I learned that it is nearly impossible to see out of the windshield at night with mist covering the gl***. Noted for next time.
    Sunday I was finally able to make it to my first cars and coffee with the coupe. Ive been a few times but I was always that **** who had to say "well back at the house I have this" and this time I finally got to be a cool kid lol. And of course I took zero picture of that. Coupe got a lot of attention though. There were a bunch if guys asking questions and really looking it over. It was the oldest car there by almost 30 years. Most of the younger guys are in OT European and modern muscle cars but there's usually a few older guys in hamb ish era cars.
    While at the show I heard about another gathering later that afternoon at a local offload and custom cars shop that is also pretty close to the house so I hit that too. Again didnt take any pictures but one of my friends from the neighborhood was there and got this one.
    Again it got a lot of attention. Im sure mostly because I havent had it out ever so it was something different than the usual stuff that is at every event.
    Later that night we ordered pizza and the youngest decided she would only go with me to pick it up if we took the Model A. So naturally I obliged.
    All in all put about 35-40 miles on the car. No major squeaks or rattles except for those produced by the ****py roads here.
    Car still smokes a lot. Seems to be worse off idle (so while driving) a week or so ago I tried some seafoam in the gas, in the crankcase, and some down the carbs while running. Hasn't really seemed to make much difference.
    Tonight I checked the plugs for the first time since I got it going 7 of them looked like this
    #6 looked like this
    I also changed the gaps from 31 to 28 but It didnt seem to do anything good so I might go back.
    Back to the smoking, its only coming from the breather and the road draft tube which would ***ume its blowby and there is a one or more piston rings sticking. Without fully tearing down the motor anybody got any tips or tricks to unstick rings? I say without tearing the motor down because I prefer the 59a flatheads and if I'm pulling the motor I think I'd rather build the 59 I have back in Iowa and put that in the car.
    Deutscher, Outback and Thor1 like this.
  13. Nice progress and a good read. No one will be able to say you didn’t make it your own. You ticked by a bunch of hamb worthy milestones- it made you dirty, it marked its’ spot, it made you buy tools, it made you bleed. Great that you made a stir at cars and coffee, keep banging on.
    redzula, Outback, Thor1 and 1 other person like this.
  14. redzula
    redzula
    Thank you sir.
    For today's adventure.
    Back when I cleaned the fuel tank is was never able to get the filler in the body lined up right with the spout in the tank. They were close but offset by about 3/4" (about half the opening diameter). Honestly I dont knownif i just never noticed it before or if I just didn't get it back in line well enough. Regardless the tank is pretty well centered in the trunk, the fill is mounted in the body, but I couldn't get the tank to slide anymore in the bracket.
    The tank is tight to the roll bar and the supply line is basically up against the tank mount bracket. If i were to move the tank so the supply was on the other side of the bracket it would likely be too far and I'd be in the same boat...
    This misalignment is annoying because it means I cant get a gas nozzle in the hole to fill up so I had to use and keep a funnel with me. In order for the funnel to fit it had to be a long skinny one and then I couldn't just pull the nozzle on or it would overflow the funnel and spill into the trunk. I've only actually taken the car to a gas station once but as you can tell it was bugging me. Haha
    So today I moved the fill port in the body.
    Pretty straight forward.
    -I started by pulling it apart and covering the opening in the tank.
    -Then I made a filler piece for the center hole and tig welded that in so there werent any sparks close to the tank.
    -Welded up the bolt holes
    -Hammer and dolly
    -Redrill new holes offset by 3/4"
    -Bolt the filler back in place
    -tighten it too much and break off the studs welded into the filler
    -drill out the broken bolts
    -find new bolts, grind the heads, and shorten them, and weld back into the filler.
    -try to burn my hands off picking up the filler immediately after welding (leather gloves weren't enough)
    -paint and reinstall
    -Fin
    Hard to see but you can just make out the edge of the riser pipe from the tank centered in the opening g of the fill in the body
    Filler piece
    Filler and one bolt hole welded
    New bolts holes drilled
    Lines up pretty well now. The distortion in tape I used over the hole in the tank.
    Painted. I thought id used semi gloss when I painted over the white body lined before but I guess it was flat. Probably leave it for now until it bugs me again.
    Also of note for when I eventually do something with the fixing the paint job the paint under the black is a silver/grey. And when I was sanding it for welding prep it sure seemed like latex house paint so that will be fun if I do a full repaint.
    Deutscher, simplestone and Thor1 like this.
  15. atch
    atch
    Good job man.
    If you ever bring that thing down to Tim's please let me know; I'd love to see it.
    redzula likes this.
  16. redzula
    redzula
    Would be cool. I either need a bigger set of cajones or a job relocation somewhere closer. I picked up that trunk lid from Tim while we were in Iowa. But wasn't going to be able to claim that as my carry on for the flight home so it be riding down with dad next time he comes this spring
  17. atch
    atch
    Airlines get persnickety about that sort of thing...
    Thor1, Outback and redzula like this.
  18. redzula
    redzula
    Had an incident the other day. I was working from home and decided to take the coupe to the parts store and then to lunch last Friday. It was near 80* out and I ended up sitting at a long stop light long enough for it to start getting pretty hot. North of the 180* it had previously never crossed and was coming up on 220 on the gadget. Probably in the 210-215 range before the light finally turned green. Not terrible but you could tell. Stopped at the parts store no issue. Started right up but when I got to the lunch spot it was puking what looked su****iously like a milk shake onto the ground out the overflow tube.
    So I did what anyone would do. I went and ate and stared at it out the windows lol. Then drove it home with no more issues.
    When I got home I checked the oil.... no water on the stick. It's possible that the water is sitting on the bottom of the pan I suppose but won't be able to tell until my next oil change or it gets more water in it.
    That said I've started figuring out how to convince my dad to pull the 59a out of the '36 pickup I have back in Iowa and getting that down here as a spare/replacement.
    In other news I tried again to have AI generate something I can use to put a logo on thebdash at something. Before I'd only tried the grok version of Ai before and wasn't thrilled with what it was coming up with. Tried ChatGPT this time and it's better. All ears if someone wanted to take the idea and come up with their own or make suggestions for an AI prompt to try.
    Basically thinking of a anthropomorphic hour gl*** character thats running like roadrunner. Let me hear it good bad and ugly opinions.
    RMcCulley, Ed95, patsurf and 4 others like this.
  19. redzula
    redzula
    Well it hasn't been too warm and I've been smarter with when and where I going the coupe so I've been making short trips just to get it out. Still smokes out the breathes. Hasn't puked anymore milkshake. Haven't looked at either.
    Instead I had my neighbor take a video of me driving by yesterday so you could head how it sounds from outside the car and with a steadier hand.
    https://youtube.com/shorts/VkIhhNsoWek?si=ZBauC6hTc84s56-o
    And then I got artsy today after taking it to get lunch again (that's turning into a bit of a Friday thing apparently since I'm usually working from home on Fridays lol)
    The B roll
    Other than that
    I was offered a homemade trunk lid that's metal @Tim courtesy of @atch giving it to him and then forgetting that and actually sent me a DM offering it to me as well without realizing tim still had it and already had talked to me about it. So when we were back in Iowa over new years I ran down to visit tim in KC and picked up the lid. And then dad built a box and mailed it to me. Since TSA wouldn't let me carry it on the flight for some reason. Anyway, that will replace the fibergl*** one that came with the car that has been off for a while now. It's a little long for the opening but being homemade it shouldn't be too difficult to fix that.
    With that in hand I decided I wanted to try and build a similar framework for the hood that came with the car so I had the option to run that too if I wanted. Same deal as the trunk lid the, I'm making the frame out of 1/2" x 1/8" strips and then I'll rivit the aluminum skin to the frame. I'll trim back the shape a bit because as far as I can tell the skin is nothing more than a 4'x4' sheet of aluminum bent to shape. It was never trimmed to match grill being narrower than the cowl so the front wrapped down further in the front than the back and I want to fix that.
    Outback, Thor1 and Deutscher like this.
  20. redzula
    redzula
    Started on the hood like I mentioned last post.
    Formed 1/8" x 1/2" x36 strap to match the cowl. (Had to weld 2 together to span the whole cowl)
    Did the same for the grill then made pieces to span and connect the grill to the cowl
    Went to fit the skin and realized that my frame was too long on the sides. I had made it to line up with the separation line between cowl side and cowl top but the skin wouldn't reach both sides at the cowl. I liked the idea of using the skin that came with the car instead of buying a new sheet so I welded in new side bars on the frame. And then cut off the longer ones.
    Once that was fixed I started drilling giles for clecos and eventually rivets. Started in the center and worked my way out measuring 2" between each. Once I made it to the side bars I was able to trace the frame and trim back the skin. As I mentioned last post the skin was just a square piece so it angled down towards the front since the grill is obviously narrower than the cowl.
    That was all.last weekend then out of town for work this week. Back at it tonight amidst a rare snow storm in Myrtle Beach. I finished clecoing the p***enger side front and rear bars and trimmed back the skin on that side.
    The hood was now way less floppy that when I first got it. But I wanted a little more so I added 2 stringers on the top flanking the carbs on both sides. Got those fit and welded in and holes drilled.
    I briefly debated not adding clecos into the patched area. But ultimately drilled those one in too.
    After that I added connecting pieces to join the 2 center bars and from the center bar to the edge bar on both sides.
    And this is what it looks like currently with the skin off.
    RMcCulley, Outback, Thor1 and 2 others like this.
  21. redzula
    redzula
    Like I mentioned before I've been trying to take more little trips with the car to get seat time and feel each other out.
    Last weekend I swapped tires on rims for my neighbors golf carts and needed to take thebold tires to the dump... perfect job for the hot rod.
    Got a bunch of smiles and thumbs up at the dump. And some non car people probably wondered which dumpster the car was going to go in lol.
    Also took a break tonight to test out the coupes snow shoes. With the aforementioned rare snow event we're currently receiving. That was a fun detour from the hood.
    No video cause I still don't have any friends lol.
    RMcCulley, Outback, Thor1 and 3 others like this.
  22. redzula
    redzula
    Last time I left off I had the frame pretty much done and cleco'd the 2 center bars and the front and rear archs. I intentionally waited to drill and cleco the 2 side bars just incase anything shifted a little after I started bucking rivets.
    I also needed to decide how I wanted to mount it to the car. Previously with just the skin it was a bolt with a hole in it turned up and then clipped on. Now with the frame I wanted something more solid than a clip and washer on sheet aluminum. I started by adding some metal into the lower corners at the front of the frame. And a simple rivnut in the flange of the grill for a bolt. Not sure I love the idea of an actual bolt holding the hood on but I like the position and I could always run a modified bolt from inside out and go back to the pin method utilizing the stronger frame now. At the rear the cowl flange isn't consistent side to side so I opted to add the metal where the center bars join the rear arch. I then added some mounting tabs at the cowl making sure to keep them pretty tight to the cowl so they don't stand out too much with the hood off.
    After I had that all sorted I painted the frame so it wouldn't get all rusty and gross underneath and between the skin.
    Now all that was left was to joing the frame and skin together.
    I got the rivets last week but the only bucking bit I had was a way too big one i had left over from my school bus mechanic days in college. Haven't used it since naturally. So I went to Amazon and found a set that had a few different sizes and that showed up today. So obviously after work I went out to the garage and started attaching skin to frame permanently.
    Started with the center couple on the front and rear then the center bars again starting in the centers and working my way out. Although the skin has definitely seen better days I still wanted to be careful not to "trap" any metal and cause it to oil can when I was all finished.
    Once I had the center bars all done I went back to the front and rear arches working back and forth until I got those the sides. Once I got to the last couple on the ends of each arch I was ready to clamp, drill, cleco and eventually rivets the sides. 20260203_175308.jpg
    In all it 76 rivets to complete the entire hood. It is way more solid now than before and bolted on it looks well enough to match the rest of the car. Ill get overall pics of the car with the hood next time I take it out. But the sun had gone down and the temps dropped so that wasn't happening tonight. I am curious though how much of that red light on the engine you'll be able to see with the hood on at night. When I redid the wiring i wired that light to be on with the ignition instead of on a switch like it was before.
    Edit:
    Don't have to be outside in the cold to to check that light lol my phone had a night photo mode where captures the photo over a couple seconds to let more light in. You can see the light but its definitely not as bright as it looks in the pictures lol
    Thor1, J.Ukrop, RMcCulley and 3 others like this.
