Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Right? Ugh. I'm doing some homework and mentally preparing to take them on again.
    Hahaha it's soooo tempting.
    winduptoy, 41 GMC K-18 and Tim like this.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you so much! Even though I'm being methodical, I still feel like I'm going to be in the same camp as you. I just need to get it running and driving to establish a baseline. Thank you for your continued support!
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Here are a handful of snapshots from tonight's progress.
    First, we have my fuel gauge purchased from @fleetside66. I have an idea for some unconventional placement, but that will be later down the road.
    My main projects for the night were testing the electric fuel pump (it worked when I clicked a fresh fuse into the vintage panel) and routing my oil pressure line with the correct amount of coils. Too dark for pictures in the engine bay, so here's an overall garage scene instead. I really need to do something about those ugly crates behind the car. IMG_4648-1.jpg Where the line p***es through the firewall, I was happy to pull a grommet from my collection. (I ended up using a different one, but you get the idea.) Once I install the olives and drill a couple of holes for adel clamps, we'll be able to check that task off the list.
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    IMG_4634.jpg The other night, I started pulling apart the rear brake line to see if I could find anything glaringly wrong. Much to my surprise, there wasn't. I was planning to redo all the tubing, but I'm wondering if this same setup with a little bit of brake fluid resistant thread sealant is worth trying. Something to think about!
  5. Weedburner 40
    Weedburner 40
    Joey, if your brake lines are leaking at br*** fittings, check the fittings. The fittings we are getting now days are not very good. I just did a model A ch***is and several of the new br*** fittings needed to be replaced because they would leak.
  6. Thread sealant won’t do any good, if fluid is getting past the line flare it will just come out of the center hole in the nut. The threads are only there to hold the flare ends together. Plus it would look like hack work.
  7. RodStRace
    RodStRace
    Agreed. This is a mechanical seal for a safety system operating at high pressure. Sealant is not advised.
    This article, which isn't great does have a good graphic.
    https://garagespot.com/how-to-flare-brake-lines/
    The sealing surface is the end of the tubing to the fitting. The threads are only there to apply force to the connection, not seal. If the fluid is going past the end of the tubing, you already lost.
    All older brakes in the US used the double flare, but this shows many types.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you all for the advice. Looks like I'll be redoing my rear brake lines. I will say that I was very proud of my setup.
    Live and learn, I suppose?
    Tonight I was working on a fun publishing project that I'll share more about later. That means big productivity, but not on the roadster.
    Unrelated, but while sifting through files, I did find the origin of my car's switches. Neat to have marine-grade components in my Stewart-Warner "Mate" panel. That's all for tonight!
  9. Outback
    Outback
    from NE Vic, Oz
    When you dis***emble the lines, look for cracks in the flares or other issues that may cause a leak, it's just a mechanical thing
  10. Tim
    Tim
    from KCMO
    I also ***ume you loosened the fittings and re tightened them to see if that sealed them?
  11. The biggest mistake I see at work when the newer guys form a flare is that they go whole hog with flare tool when forming the second part of the double flare which risks cracks and fractures. I get it started into shape and let it form the rest of the way when it is installed. I have never done the loosening and retighten procedure though, the initial tightening of the fittings have been leak free in my own experience doing it that way
  12. Tim
    Tim
    from KCMO
    Yeah it is something that is so simple but does involve some feel/ finesse. Once you get the feel for it most rarely have a problem moving forward.
  13. Jeff34
    Jeff34
    @Tim I agree on the loosen/retighten trick. Worked great for me. The only leak I had when I plumbed my brakes was a bad bleed screw. After I replaced that, everything was tight!
  14. G_Don
    G_Don
    Maybe thats my problem. haha Does this also apply to the lever flare maker that you put in a vise? Best $200 I ever spent.
    Gordy
    It's Me Rz, winduptoy and Six Ball like this.
  15. Just form the double flare but don't squish it all of the way down with the tool. Let the fittings finish the form of the tube.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Upon further inspection, the flare that attaches to the wheel cylinder is definitely more crushed than the one that links to the junction block on the axle bell. No cracks or out-of-roundness.
    Figure I. The leaking one.
    Figure II. The non-leaking one.
    Any advice would be greatly appreciated. I’m going to do a tubing inventory and bend some more lines next week!
  17. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Apply a little oil or anti seize to the threads, be sure to use a good flare wrench and tighten the hell out of it. I noticed a little rounding over on one your flare nuts. I am lucky to be able to use my father’s flare wrenches, the ones he used from the fifties up until his p***ing. My old *** has to back it up with a cheater pipe to reach the desired torque. Give-R some UUUMPH.
    osage orange and Six Ball like this.
  18. RodStRace
    RodStRace
    I think of it like this, look at factory flares on premade line. They have to supply product to end users and eat any returns, so they take that into consideration when turning out thousands of lines. Newbies to pros. Match their shape. That's what you want to copy.
    Second, I only tighten as much as needed. Yes, it takes some oomph. It should form the end of the line to the fitting. But it also is an area of what, a quarter of an inch by a 16th? The same formulas apply. Pounds Per Square Inch. The area is a fraction of an inch so it doesn't need 100 pounds applied. The thread torque doesn't directly apply to the force at the flare, but you are trying to final form the line to the fitting, not squish the end to half it's' thickness.
    I think your pictures show a good example of good (#2) and deformed (#1).
    J.Ukrop, Deutscher, Six Ball and 2 others like this.
  19. pprather
    pprather
  20. denis4x4
    denis4x4
    from Colorado
    Back up to post 5228. West Marine is an excellent source for switches, panels, fuse blocks and instruments used in the construction of hot rods. While costing more, quality makes them a bargain in the long run.Too, the universal fit applications makes them easy to adapt to automotive use.
  21. Weedburner 40
    Weedburner 40
    Another consideration is that the flare has to seat against the cone, not the edge. If the flare is too long, the outside rim will seat against the bottom of the fitting and not on the cone, and it will never seal.
    HemiDeuce, dwollam, Outback and 8 others like this.
  22. chicken
    chicken
    from Kansas
    Outback likes this.
  23. winduptoy
    winduptoy
    Joey,
    you need to also be looking at and inspecting the end of the tubing or the 'face' of the flare....and your photos don't show that view
    my suggestion at this point in time....
    compare the finished diameter of flare #1 to flare #2
    flare #1 appears to be larger and disfigured from tightening the nut up against it.... see @Weedburner 40 post
    flare #1 looks wonky suspect
    practice some flares on some 's****' tubing and get them all to look like #2....
    pay attention to the protruding length of the tube from the flare block....too long and your flare will look like #2 and it can be a nats *** difference between good and bad
    good luck....
    dwollam, 41 GMC K-18 and Outback like this.
  24. nochop
    nochop
    from norcal
    Yup top one is nfg
    Outback likes this.
  25. nochop
    nochop
    from norcal
    I got in the habit of inspecting my flairs with a magnifier before installing, adding just a touch of lube, never seize or 3n1 to the male fitting. Had good luck on my lines
    winduptoy, Outback and Tim like this.
  26. It's Me Rz
    It's Me Rz
    i have one of those, did my entire ranger in one day master to abs controller to all 4 corners, nary a leak to be had. like you said, best $200 ever spent. never fear a flare again!
  27. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone for the detailed flare info. This project is about learning, and I’m learning how to make brake lines that look clean and function correctly. That means this weekend, I’m breaking out the Eastwood, NiCopp, and sparkling water (for hydration) and getting down to business.
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last night after work, I drilled two holes in the firewall and finished plumbing my oil pressure gauge with adequate coils and a firewall grommet. This weekend I’m going to spin the engine over and see if I can 1) get oil pressure and 2) check for leaks. (I’ll also source a battery tender, because for some reason I gave mine away in the move.)
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    That’s about all for now. Here’s what I have on the horizon:
    • Wire Hobbs meter
    • Bolt down seat
    • Remove old brake line on rear axle (two pieces) and replace
    • Grease all zerks
    • Dis***emble and re***emble both front brakes.
    • Then, in February, bleed brakes and attempt fire-up.
    I’m in a list kind of mood this morning, but these all seem doable. The bus is almost at my office, so I’m signing off. Stay tuned for updates as time allows.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Lots going on off thread with family, work, and the world, but I wanted to hop on here with a couple of updates and some questions.
    First, it was Art Week in San Francisco. On Thursday night, I made my way over to the Minnesota Street Project and checked out the opening party. There was lots to like, but I was captivated by these risograph-printed 'zines. I'm planning on doing a little one of these about my car. Would anyone be interested?
    On Friday at lunch, I rolled the machine partially out of the garage to crank this thing over and see if I could get oil pressure. Well crank I did, and I ultimately got 10lbs. I reported my findings to David, who said that the gauge may not have been reading correctly.
    The following day, I bled the line and got 20lbs. After switching back to the SW gauge that came with the engine, we were at 38. Big relief. David said we can hit the other gauge with compressed air next time I'm at the shop.
    So, with that, the car should be ready to fire up.
