Technical 32 Roadster Windshield Rake
Discussion in 'Traditional Hot Rods' started by Bill Sario, Jan 14, 2026.
  1. Bill Sario
    Bill Sario
    Need help on my 32 Roadster Windshield. Apparently the holes in the cowl are way wrong so I need to start over. What is the stock angle say relative the bump-trim on the side of the body? What do most hot rod guys rake them down to? Thanks
    lothiandon1940 likes this.
  2. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Bill: Study a few roadsters for their windshield rake. If your not doing a resto a degree or 2 means nothing. Are you going to do a top? I've done quite a few roadsters thru the years and I just eyeball the rake so it looks good. Right or wrong?
    vtx1800 and lothiandon1940 like this.
  3. lothiandon1940
    lothiandon1940
    Might be a tad difficult to see in this image but, the windshield on my Roadster (the closest one) is raked back a few degrees more that those of my 3 friends. I have always liked it and feel it makes it a bit different. I didn't build the car so I can't say exactly how it was done. Shouldn't be too difficult during the build process. Like @krylon32 says, rake it 'til it looks right.:D Fireworks With 32s on July 4th.jpg 20180816_104629.jpg 1024151020 (1).jpg
  4. NJ Don
    NJ Don
  5. lothiandon1940
    lothiandon1940
    .......Thank you, Sir.
  6. Bill Sario
    Bill Sario
    That helps a bunch, thanks. Beautiful cars. I have never built a "Hot Rod" before. I see why they are all so different.
  7. Bill Sario
    Bill Sario
    I am thinking around here: IMG_6778(1).JPG
    RICH B, akoutlaw, pprather and 3 others like this.
  8. DDDenny
  9. lothiandon1940
    lothiandon1940
  10. Bill Sario
    Bill Sario
    Another quick question if I may? Does the bottom of the windshield rest on the little bump out, over it, or does rest in front of the windshield as a stop? Thanks again
  11. lothiandon1940
    lothiandon1940
    ....In front of the bump. The bump acts as the stop to keep the windshield from blowing inwards at speed.
  12. woodiewagon46
    woodiewagon46
    from New York
    Bill, Krylon brings up an excellent point. If you are thinking about a top on your roadster, your windshield stanchion top's need to "socket" into the holes on each side of the front header. The last thing you want to happen is when you close your top, the holes are too far forward or back. Now what?
