I've been busy with some small jobs, adjusted the toes with a string, screwed on the rear fenders and running boards – so many screws! Then I cut a new floorboard out of plywood, drilled screw holes in it, and painted it black. That's it for now. Now comes the Christmas season. If I'm really lucky, I might even get my engine block back from the shop before Christmas – that would be something! Regards Harald
Happy New Year! I was able to pick up my engine from the rebuilder, where it was bored to .020 oversize, new valve guides and valve seats were installed, and then it was converted to insert bearings. The connecting rods are new; they're included in the conversion kit. I also did one small thing: I installed new mirrors, which are from the café racer section and are easily adjustable. It's currently only 2°C (about 35° Fahrenheit) in our workshop, too cold to work on it. We're waiting for warmer temperatures. Regards, Harald
Nice job Harald. I like your installation. I've been thinking about much bigger mirrors on my 29 sedan. Like the ones on small pickups, maybe 6 inches tall and 10 inches wide on some sort of tapered dovetail bracket so I can quickly remove them when I park and just slip them back in the brackets still adjusted when I'm ready to drive again. Being generally the slowest car on the road, I'm pretty interested in what's going on behind me. The tiny little motorcycle mirrors that I welded to the top of the hinge pins don't give me much field of view.
Cafe Racer Cruiser Custom Round Bar End Mirrors Rearview Mirrors Chrome https://share.google/E8bo1XqXEGnF3yHqu They're not dovetail joints, but you could adapt them to fit. Regards, Harald
Thanks Harald, but not much gain in size and they would need to be adjusted each time they are installed. I have finally acquired a vertical mill, eventually I'll build something.
Nice work, we have been 46°c here lately, also not much fun to work.... Nice to see the machine work is done
Ouch, you're right, we've had a real winter for a week now, and it's supposed to drop to -12°C again on Sunday. I can definitely take a break. Regards Harald
I was able to install it quite easily; the parts are cleanly manufactured. There seem to be further improvements since then, such as a different output bearing and a different mounting on the output shaft. I've described my installation in my installation report. Regards, Harald
I just couldn't resist, so I used a Hand milling machine to modify the intake and exhaust ports a bit. It turned out pretty well; I didn't want to overdo it since there wasn't that much material to work with, and I didn't want to break through anywhere – that would be disastrous. Then I cleaned the whole block, lapped the valves, and installed the tappets and camshaft. I pre-set the valve clearance without the springs. Regards, Harald
Today I continued working on it, finished ***embling the valve train, checked and adjusted the valve clearance again. I installed the crankshaft and checked it with Plastigage – everything's fine. Then I cleaned and oiled everything and re***embled it. The crankshaft turns smoothly; I'm satisfied. Regards, Harald
Hello neighbor, nice Ford. Where will we see him? in race 61? or on Headbanging Finsterwalde? I will also install a Volvo gearbox in my Ford, it is a very good solution. Can you tell me where I can buy this conversion kit in Germany? Lukasz
Hi, greetings back. The conversion kit is available via: ADAPTER VOLVO M40/41TRANSMISSION | Piston Knockers https://share.google/vyBHLP3zNZ6pcUjba Hindenberg Dirt Track and the Airfield Club Race in Finofurt are definitely on the calendar; I'm not sure about Race61 yet. Regards, Harald
