Projects Dirt Cheap Dart
Discussion in 'The Hokey Ass Message Board' started by Sharpone, Jan 18, 2026.
  1. Phillips
    Phillips
    This is going to be great, love the early A-Bodies.
    '66 Dart was pretty successful in year one of the Trans-Am series, I know you already have plans, but just sayin'! 66-Dart-esses-by-Pete-Luongo-1024x535.jpg 1966-Dart-at-Green-Valley-by-Jerry-Melton-1024x684.jpg 1966-Sebring-Tullius-in-Dart-1024x571 (1).jpg 1966-VIR-Dart-Mustang-Trans-Am-by-Roger-Blanchard.jpg
    flyin-t, A 2 B, Tow Truck Tom and 8 others like this.
  2. twenty8
    twenty8
    How nice of them to provide a burnout/launch test pad right outside your place.:D:D:D
  3. Sharpone
    Sharpone
    Got engine running on stand set idle, timing at 3000RPM etc. I have the exhaust pointed at the floor so it sound funky IMO
    Dan
  4. Sharpone
    Sharpone
    Next I purchased new brake parts Master Cylinder , wheel cylinders, brake shoes, Nickel Cooper brake line, hoses, and hardware kits the drums had been turned already and good the go.
    A 2 B, Stock Racer, Ziggster and 15 others like this.
  5. Sharpone
    Sharpone
    I did start filling in trim mounting holes before I worked on the brakes. The p***enger side has some mud filling a dent, I’ll grind it all out and go from there.
    Dan
    dwollam, flyin-t, Baumi and 20 others like this.
  6. Sharpone
    Sharpone
    I should mention I’ll have a few posts before I get to the current state of the build.
    I put the engine about where I thought it should be. After some consideration I decided to buy some motor mounts vs building some. I decided to purchase the Schumacher motor mounts, pricey but the reviews are good.
    The engine bay is very tight to say the least, not much room for error.
    Dan
  7. Sharpone
    Sharpone
    IMG_3372.jpeg IMG_3373.jpeg IMG_3374.jpeg IMG_3376.jpeg IMG_3377.jpeg Next I cleaned up and did some painting on the engine bay. I cut the top radiator support out to help with the engine/transmission install, remove, install etc. I had the engine in and out a couple times before I got it positioned where I wanted it.
    dwollam, flyin-t, A 2 B and 12 others like this.
  8. Rodsports
    Rodsports
    Love the little motors, they can go very well for (almost) cheap.
  9. Phillips
    Phillips
    Man that car looks solid. Clearly not from around here!
    A 2 B, osage orange, Squablow and 3 others like this.
  10. RodStRace
    RodStRace
    If the engine is still out, I'd consider fabbing up a heat shield for the master.
  11. Anthony, Anthony, Anthony, we are all keenly aware that you’d drive almost anything.
  12. 57 Fargo
    57 Fargo
    No need for a heat shield but an early a body left exhaust manifold makes life easier. I put a 318 in a ‘65 Valiant when I was young and used the center dump manifolds on both sides but it was tight on the left and I built the mounts.
    dwollam, A 2 B, Okie Pete and 3 others like this.
  13. Rickybop
    Rickybop
    Hey, what's goin' on over here?
    Mopar stuff? Alright!
    @Sharpone ? Yay Dan!
  14. RodStRace
    RodStRace
    He and I have discussed exhaust in an early A.
    Even with manifolds, city driving during the summer heat soaks underhood pretty bad and the master is pretty close and above. This one has a OT master, but shows the layout.
    It can be skipped, but now is the time to do it while there is so much room.
  15. RodStRace
    RodStRace
    The manifold he shows in the video is going to be an issue.
  16. @Sharpone good stuff Dan! I've always had a soft spot for darts.I've talked to a local guy here about selling his.He's gave me a price but not sure if he really wants to sell it.We'll see in the Spring. Here's a pic.Keep up the good work on yours bud! 1765664749338.jpg
    dwollam, A 2 B, osage orange and 4 others like this.
  17. Saweeet:cool:!!
  18. 57 Fargo
    57 Fargo
    That’s the same setup in mine and I don’t have problems with brakes at all.
    Bugguts, A 2 B, osage orange and 3 others like this.
  19. RodStRace
    RodStRace
    I didn't in my OT dart fastback with headers, but a friend here had a 65 with a 5.2 for his wife. She would when doing the errands during the summer (hi elevation, hi temps, slow speed, lots of stops).
    I also saw more than a few with fenderwells that had shields. Yes, different animal.
    Not saying it will be needed, just a heads up it might be.
  20. Sharpone
    Sharpone
    Texas car I bought it from @Lone Star Mopar, pretty clean and very solid. Two rust repairs I’ve done p***enger side floor and a small spot in the trunk.
    Dan
  21. Sharpone
    Sharpone
    Rod I have the engine in I think that there is enough space to keep the MC cool it’s a single pot for now. Eventually I’ll install a dual reservoir when I install disk brakes up front. Not sure witch avenue I’ll go yet. I can source parts from a later model Dart I believe or buy a kit. The kits I’ve look at with good reviews have the correct spindle, ball joints, MC, calipers pads and hose for around $800.00
    Dan
    Tickety Boo, dwollam, A 2 B and 3 others like this.
  22. Sharpone
    Sharpone
    Nice car, hope mine turns out that good.
    Dan
  23. Sharpone
    Sharpone
    dwollam, A 2 B, osage orange and 5 others like this.
  24. Sharpone
    Sharpone
    IMG_3469.jpeg IMG_3378.jpeg IMG_3380.jpeg IMG_3379.jpeg IMG_3496.jpeg IMG_3498.jpeg IMG_3497.jpeg
  25. Sharpone
    Sharpone
    Had to a little grinding on the head and manifold to get the manifold to head seal.
    Dan
  26. Sharpone
    Sharpone
    As I stated in a post above there is common theme on my build. Fellow HAMB members providing me guidance along the way.
    Thank you for help on my exhaust manifold/steering shaft conundrum
    @RodStRace, @gene-koning ,@squirrel ,@Nailhead Jason, @Moriarity and and a person or few I missed.
    Dan
  27. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Great choice, just fell in here.
    I now understand the fruit fly thing.:D:D:D
    You Rock
  28. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    To be clear,,, This thread grew 3 pages in 3 days :):D:cool::rolleyes:
    A 2 B, osage orange, Rickybop and 3 others like this.
  29. wicarnut
    wicarnut
    Please take the time for the dual brake reservoir, I did the same thing, did not take the time with my wife's restored 51 Buick Roadmaster, I redid the brakes, new everything but the dual master AND sure enough a line/flare cracked at the wheel cylinder, purchased very expensive custom bent SS lines for the car. She was driving and went to slow down and No brakes, she did not panic, on highway 39, 65 mph, I talked her through it, got on shoulder, off gas and we coasted for a long time as everyone blasted by at 65-70 blasting horn at us, when slowed down, crawled to an off ramp used E- brake to stop, glad I had adjusted that up. So we limp to a gas station and the counter lady had a business card for a flatbed service. $500 later we were home safe. That's one of those deals, could have been a Disaster. My guardian Angel watched over me/us again. I see you're a Wi, guy, free advice from one cheese head to another. LOL
    A 2 B, osage orange, Sharpone and 2 others like this.
