Projects 1936 ford pickup hotrod
Discussion in 'Traditional Hot Rods' started by Ed95, Jul 8, 2025.
  1. Ed95
    Ed95
    im running speedways high flow water pumps... I've tried running with and without thermostats but did not add the washer... the thermostats are 160F. I have the stock ones still tho... just ***umed speedways would be better. It would really **** if radiator needs to change again haha. I was running a low boy one and got this high boy but maybe a bigger is better... I got the biggest I found but to be fair I did not look too long
    here you can see radiator better
    Worse comes to worst I still have the original br*** radiator... maybe I put it back just didn't wanna get involved cleaning that thing. looks pretty crummy
  2. Ed95
    Ed95
    Well i think i got this thing figured out…
    Turns out i’m just an idiot :D i wasnt using enough liquid. This time I filled the radiator to the brim with water. I ran the truck for around 35mins it idled for 15 then drove it. When i got home the temp wasn’t even at 130F. Before it would reach 220 in 10 mins… i will drain all the water and replace with coolant. And retest…
  3. Ed95
    Ed95
    So since radiator is working fine i’ll take it somewhere to weld some side tabs to attach to my grill easier. I also welded a bracket for shocks. It bounces pretty bad without them. So figured this would help. I compressed them about 50-60% and i think i have about a 20 degree angle. I have to finish the p***enger side but this is what i got going so far
  4. Ed95
    Ed95
    IMG_4447.jpeg Finished suspension
    Outback, Deutscher and Just Gary like this.
  5. 3blapcam
    3blapcam
    Heck yeah dude! It looks like it's coming along! TBH, that radiator looks plenty big. I ran a pretty small one on my 8ba powered Model A because it was channeled & low, and never had problems with it running hot in central Texas. It was also aluminum that I painted that Eastwood radiator black, I think it was called.
    Shocks are a game changer! You'll appreciate the work they do now! ;)
    Keep at it dude!
    3blap.
    Outback, Ed95 and Just Gary like this.
  6. Ed95
    Ed95
    Will do! I’m excited to drive it with shocks and no more overheating :)
    lothiandon1940 and Outback like this.
  7. Ed95
    Ed95
    Took my radiator to OJ at Clarke County speed shop in Berryville. I wanted to weld some aluminum tabs that I made to fit my grill easier.
    First of all wow what a great guy OJ is! He is as old school as they come. Had a blast checking out his shop and projects he’s working on! He said he didn’t like the welds he did lol something about personal pride and the radiator having some finish on or something.
    I’m very happy with his work! He was very quick and I found an old holley 94 carb that I picked up from him that he had rebuilt.
  8. 3blapcam
    3blapcam
    I like how you don't hesitate to get things done! Hurry up and mount the grille shell... and cover that radiator up!!! ;)
    It's always good to have back up carbs laying around! At least, in my opinion it is...
    3blap.
  9. Ed95
    Ed95
    I blame the ADHD lol
  10. Ed95
    Ed95
    Oh god i need to do better. Got good penetration but i grounded way too much metal got to thin around the hole. I was using a grinder. Its very hard to get into the small gaps here. So I ordered a dremel tool. I’ll rework this but just for kicks here’s the update on the grill
    i dont know why i decided to move the top hole up. I should have just gotten the aluminum tab welded at the same height of the grille hole. I wanted more rigidity, but it’s way more work.
    Outback and 3blapcam like this.
  11. Ed95
    Ed95
    The other side turned out much better!
    IMG_4478.jpeg The hood and grill are finished. I just need to redo my hood rods its off by around 1/8 inch so when hod opens it wants to jump out
  12. 3blapcam
    3blapcam
    Looks good with the hood & grille!
    Just FYI, ditch the 4.5" grinder for dressing welds. 4.5" grinders are for dressing welds on fences, gates and cattleguards. Go get a "90 degree die grinder" from Home Depot/Lowes, online, wherever, and get a Roloc setup. It's much easier to control and you can quickly switch between abrasives and finesse your welds and get a better outcome. They do require air (Bigger is better here), but it's totally worth the investment if you're going to continue with building hot rods! I have one like that Ingersoll on the left, and it has too much power. My favorite one ever was more like the middle cheapy one! They're not all created equal and it takes awhile to find one you like. In my opinion, don't waste your time with the ones that look like a scotchbrite pad, they clog up quickly and are rendered useless almost immediately. Thin cut off wheels & sandpaper discs work wonders on dressing metal work.
    https://www.empireabrasives.com/3-quick-change-ceramic-disc-25-pack/
    https://www.empireabrasives.com/2-roloc-roll-on-disc-pad-holder-1-4-shank/
    3blap.
  13. Ed95
    Ed95
    I’ll look into these… thanks! yeah the grinder really ****ed
  14. 3blapcam
    3blapcam
    Yeah, it's too rowdy for sheet metal.
    3blap.
    lothiandon1940 and Ed95 like this.
  15. redzula
    redzula
    Cool truck.
    Sent you a PM about your ignition switch.
    Some of my learned knowledge with 2 94s on flathead.
    Make sure both carbs match each other. There are a few different versions of the 94s whatever you're running they both need to be the same version. Match your Jets in both. Match your c linkages in both, for power valves I've had success with both 2 matching power valves as well as 1 PV and 1 plugged. (Honestly my old 59a I had 1 pv and 1 pvp and it seemed to getting better milage than my current 8ba with 2 Pv. but they both work pretty well) the point and shoot method works but there are also more scientific ways to get there by checking vacuum at cruising speed and halving etc.
    If you have the later 94s with the spark valve port plug that. Those really only work with 1 carb and the matching distributor or so I'm told. Never actually used one of those ones myself.
    You only need to choke 1 carb to get the desired effect for cold starts. Doesn't really matter which but you need to have the choke valve in even if you aren't using it. 94s, and I ***ume the strombergs are the same way, work better with the choke plates installed.
    As others have mentioned get a unisync tool. And sync each carb individually with the joining linkages disconnected. Once they're sync'd you can connect the linkages again.
    Idle mix is more important than the idle speed adjustment. You should not need to pump the carb to get it to fire off.
    If everything it adjusted correctly you should have no problem idling in the 600-750 range
    But every engine is a little different.
    I'm by no means an expert and I still get confused when working on my own **** understanding what its doing exactly and therefore what adjustments it needs to be fixed or run better.
    Ignition.
    When you're talking adjusting your advance and you mention chart d or chart f etc. Are you just looking at your mechanical advance inside the distributor or are you also setting the base timing with a timing light and spinning the distributor? If your off on your base timing the weights inside the distributor is just going to confuse things. Get your base right then mess with the weights IMO
    How big is the radiator when its in the shell stock they fill up a big chunk of the grill shell at least at the top. And one of the early pictures your posted of it without the shell it looked kind of short.
    Lastly im stealing that PVC flushing idea lol. That's pretty slick.
    Lastly not criticizing anything you're doing your trying and figuring it out as you go and its been fun to see you're vast improvements in such a short time.
    I think you upholstery looks great. Yeah it may look homemade but that's exactly how it would have been done in the past. And you get to say that you did it yourself. Keep up the good work.
    Edit: at some point I'll learn that not everything needs to be a novel lol.
  16. Ed95
    Ed95
    Thanks for the advice! my 2 94s are different. I'm trying to find a matching one but maybe that will take time. Which PVs worked for you? I got two 3.5 PVs and that seemed to make it run better... although maybe a bit lean? I hear loud popping when I hit the gas, but still trying to dial things in.
    When talking about the timing charts. I'm only changing the mechanical advance. Right now I have the chart D, with about 8 degrees base. Which feels wrong lol. I've been meaning to bring it closer to 4 degrees, but when I was setting that up it seemed like the engine liked this better? The truck is able to run now, but it does feel slow. Slower than I'd think (although never had a flatty before). I think I have 1 or 2 cylinders not doing their job. I found with a thermometer gun that my middle exhaust tube is about 120 degrees colder than the rest. So, either cylinders 6 or 7 or both are not firing correctly. I will do more testing once it gets a bit warmer. Been shoveling the past few days haha.
    Glad you like the seat! I'll eventually do the door panels and maybe a headliner of some kind, just trying to focus on the engine for now
    lothiandon1940 and Just Gary like this.
  17. Ed95
    Ed95
    Took the truck out today to get some pics in the snow. You can really see the difference from stock…
    RenderedImage.jpeg IMG_4504.jpeg I think its about 8-9 inch lower in the front
  18. redzula
    redzula
    I did 2 #6.5 but I think I may drop down to a #5.5 and possibly go back to 1 pv and 1 pv plug. Cause it seems to use use a lot more fuel than my old 47 did with a 59a and the 5.5/plug setup
    Also using. 051 jets. Not sure your elevation but I'm pretty much right at sea level (between 0-100' here in Myrtle Beach)
    Cool seeing the before and after truck looks good.
  19. Ed95
    Ed95
    Thanks! I'm still playing with it I may wanna channel it a bit, but I want to make sure a 471 blower will fit in there with the hood on. Also plan to shorten the bed a bit.
    I currently have two 3.5PVs but I just ordered 2 extra 4.5 PVs. Will try that instead, maybe I'm running lean? plugs seem real clean lol
    Just Gary and Outback like this.
  20. Just Gary
    Just Gary
    The stance looks great!:cool:
    Ed95, lothiandon1940 and 3blapcam like this.
  21. lothiandon1940
    lothiandon1940
    Proud of you @Ed95 ..You've been thrashing away on your truck hard and heavy, not backing away from any challenge that it has thrown at you. That is often what has to happen to make a dream come true. Keep at it. You are making us old hot rodders wish we were young'ns again......Don.
    Ed95, redzula, 3blapcam and 1 other person like this.
  22. Ed95
    Ed95
    Thanks fellas!
    It finally was warm enough to be in the garage without risking losing my limbs so I started on the exhaust…
    The flanges were about .5 in bigger than my exhaust. I went with 2 in exhaust and got some gl*** packs from summit racing. Will do a full dual exhaust
    I wanted to clarify maybe someone more knowledgeable can give advice. I am gonna add a 471 blower. I think flatheads use traditionally a 1.75in exhaust, but since i’ll have the blower i thought a 2in would be perfect
  23. 3blapcam
    3blapcam
    2" will be fine with the blower. It may restrict it a hair, but it won't be much. It's not like you're shooting for 9 second ETs and that's what's holding you back. If so, open the headers! ;)
    Uhmm, on another note, you should seriously consider adding at least 1 more bolt to the tie rod plate, in the center down low to create a triangle. It kinda looks prepped for welding, but I'm not sure I would rely on just that at this point. In fact, I'd even consider gusseting it on the backside/bottom of the rail. The amount of leverage going on there is somewhat concerning.
    3blap.
  24. Ed95
    Ed95
    You’re talking about the split wishbone right? I wanted to finish the exhaust to finish the positioning but i think i might leave it where it is. I will add another bolt and was thinking i was gonna weld the plate actually…
  25. Ed95
    Ed95
    I finished the first portion of the exhaust on the driver side. I’m gonna make a bracket so that it can attach the rear of the gl***pack to the end of the exhaust.
    Seems like i got about 5in to the ground on the lowest spot. That’s the same as my oil pan
    Just Gary likes this.
  26. 3blapcam
    3blapcam
    Yes. Welding is fine, if you're getting enough juice into & out of the welder!
    3blap.
  27. Ed95
    Ed95
    IMG_4653.jpeg IMG_4654.jpeg Got the 4.5 power valves installed and carbs retuned for the exhaust… feels stronger and i think i’m not misfiring anymore. Took the truck out for gas. I still need to finish the rear exhaust pipes, but couldn’t wait we had some good weather so I had to!
    also ordered the speedway kit for the t5 trans! I kinda hate the 3 speed
    redzula and Just Gary like this.
  28. Ed95
    Ed95
    Got some coffee! Need to get the interior sorted. I’ll probably work on gauges I’ll probably stick to the originals… i checked the speed on google maps and looks like it runs fast enough on 3rd made it to 54mph
    James D, CSPIDY, Budget36 and 2 others like this.
  29. Just Gary
    Just Gary
