Featured Projects Interior upholstery finally
Discussion in 'The Hokey Ass Message Board' started by Blue One, Jan 23, 2026.
  1. Blue One
    Blue One
    from Alberta
  2. krylon32
    krylon32
    from Nebraska
    Dam fine job, you can be proud to say I did it.
    hrm2k, porkshop, Six Ball and 6 others like this.
  3. RodStRace
    RodStRace
    Nice work! Is that the last big hurdle?
    hrm2k, porkshop, Six Ball and 4 others like this.
  4. Fortunateson
    Fortunateson
    Great work!!!
    I may be up in Edmonton in August. I’ll bring you the materials and you can do my 5W coupe for me! LOL
    hrm2k, porkshop, Six Ball and 5 others like this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Larry, that interior work looks great, you did a beautiful job. HRP
  6. Very nice Larry, top job.:cool::cool: JW
    hrm2k, porkshop, Six Ball and 3 others like this.
  7. Blue One
    Blue One
    from Alberta
    Yup the car is basically finished now if they ever really are finished.
    Since I have had it on the road now since 2020 and worked out a few bugs it’s proven to be a solid reliable driver.
    The Tim McMaster Y Block is running really well.
    Such a fun ride and the interior will make it better.
    hrm2k, -Brent-, porkshop and 13 others like this.
  8. Blue One
    Blue One
    from Alberta
    Thanks Danny not bad for my first attempt. I’m happy with it.
  9. lothiandon1940
    lothiandon1940
    WOW! Looks great.
  10. Deutscher
    Deutscher
    from Germany
    Beautiful, very well done.
    Regards, Harald
    hrm2k, porkshop, Six Ball and 2 others like this.
  11. A 2 B
    A 2 B
    from SW Ontario
    Great work! Very well executed and looks comfortable, maximizing the available interior space. I need to clear the clutter off of my Juki Lu 563 as well and learn how to use it properly. I can only hope to do as well as you. Enjoy!
  12. bubba55
    bubba55
    Wow - nothing slack about you but yer looks
    Well done Sir!
  13. Driver50x
    Driver50x
    Wow. Very well done! It looks great.
  14. @Blue One looks great,very nice colour combo....congrats!!
  15. MMM1693
    MMM1693
  16. ronzmtrwrx
    ronzmtrwrx
  17. dana barlow
    dana barlow
    from Miami Fla.
    Looks awesome. I do my own too,so know real nice when I see it" High Five" :D:cool:
    Way back I did a "How to at home upholstery"..it's been a few years..
  18. wicarnut
    wicarnut
    Nice job, just a thought, If you are looking for a side business or start up, there is a Huge shortage of upholstery shops for kustom work IMO. There's room for all levels of quality required, again I say this from my experience and guys I know. I was lucky years back to find a talented man, reasonable $$ and did the job on my 32, very happy and met the agreed delivery pretty close. Again your job Looks Good. An Official ATTABOY !
  19. RodStRace
    RodStRace
  20. mad mikey
    mad mikey
    Very well done, looks perfect and proper in your hot rod. I have done some upholstery on my coupe for the first time and found it to be kind of fun.
  21. RICH B
    RICH B
    Great job of t******* out the interior, and that shift/brake lever boot is just so neat.
  22. Blue One
    Blue One
    from Alberta
    The shift boot was challenging in the fact that the elongated portion of the Gennieshifter and the combined Lokar e brake were so close together that separate boots weren’t going to work.
    Along with that the neutral safety switch and wiring are right there in the middle between the two.
    The solution as you can see was to make a double boot with the cut out and sewed together center to make room for the switch and wiring.
    The base trim ring and the boot are held down by 10/32 nutserts and SS machine screws.
    In case you’re wondering about the carpets they are cut out of a set of Rubber backed 2007 Ford Fusion carpet floor mats that I had saved (new) from a car we had bought and installed Weathertech floor liners in.
    I cut the mats to fit the floor boards and then sewed binding around the edges.
    The Juki machine sewed through the cloth binding carpet , and stiff rubber backing with no problem.
    Previous to the cutting and binding I had used an 80 grit sanding disc on my grinder to remove the grid of hundreds of pointy rubber spikes designed to hold them in place on the cars base carpet.
    GordonC, hrm2k, The 39 guy and 15 others like this.
  23. guthriesmith
    guthriesmith
    Looks really good! That’s one thing I have never tried.
    hrm2k, porkshop and Blue One like this.
  24. Dave G in Gansevoort
    from Upstate NY
  25. 1971BB427
    1971BB427
    from Oregon
    Nice work! It looks great!
    hrm2k and Blue One like this.
  26. HOTRODPRIMER
    HOTRODPRIMER
    First attempt? That is amazing Larry, your a natural.
    My first attempt was in the model A pickup and all I did was the door panels, plywood,foam,vinyl and staples, no design work. HRP
  27. Damon777
    Damon777
    You have brought this guy hope. Great job!
  28. Bandit Billy
    Bandit Billy
    Very tidy! I think you are going to have a real nice summer!
    Blue One likes this.
  29. alchemy
    alchemy
    I’m working on a 26 touring and was considering a steering wheel quick disconnect like yours. I will be using a 17” wheel. Do you think it’s necessary for getting in the car?
    hrm2k likes this.
  30. Blue One
    Blue One
    from Alberta
    I am glad I put it in. It really helps when I have the Rod Tops soft top on. Without the top it’s not really needed. I like the top although I mostly run without the top.
