Technical Early Hemi #2 (354 Hemi build thread)
Discussion in 'The Hokey Ass Message Board' started by 57 Fargo, Dec 29, 2023.
  1. 57 Fargo
    57 Fargo
    George, Yes! This will absolutely be part of the process.
    Sharpone likes this.
  2. 57 Fargo
    57 Fargo
    Deck the halls….sort of….
    Can easily see the first p*** the deck is not square. Compared to the last rough cut.
    taking 0.040”. I think I should end up somewhere around 9.75:1 without actually measuring.
    fauj and Sharpone like this.
  3. 57 Fargo
    57 Fargo
    Forgot to take after pictures but the block is done, tomorrow is I’ll be clean, clean and clean some more than cam bearings and ***embly can begin
    427 sleeper, SS327 and Sharpone like this.
  4. George
    George
    Take a piece of uncoated welding rod and drop it down the head oiling holes to verify the cam bearing are in right.
  5. 57 Fargo
    57 Fargo
    Haven’t updated this in a bit, shortblock is together. Spent a few hours today getting rocker arm ***emblies ready to go!
    Didn’t take any other pictures but I pulled them apart, cleaned out the inside, put new cup plugs in the ends. Polished up the shafts in the lathe and gave the rockers a quick p*** with the hone. One side had some galling, obviously had starved for oil.
    I also reground the rocker tips where they ride on the valve. Now I can put the heads on when I get some time.
    Sharpone, 427 sleeper and HemiDeuce like this.
  6. Beanscoot
    Beanscoot
    I use a small drill in a pin vise to clean the oil p***ages in the rocker arms. I don't recall the size, but seem to remember there's two sizes, at least on my Desoto it was a stepped hole.
    Sharpone and 427 sleeper like this.
  7. 57 Fargo
    57 Fargo
    Yup cleaned everything well. The went through the ultrasonic cleaner then scrubbed out with a brush.
  8. 57 Fargo
    57 Fargo
    Progress. IMG_6203.jpeg IMG_6202.jpeg IMG_6201.jpeg Waiting for the cam and lifters for final ***embly.
    dwollam, Wanderlust, Sharpone and 5 others like this.
  9. 57 Fargo
    57 Fargo
    When it comes time to put it in the truck the oil pan will get modified, I have Chrysler Power script valve covers that will go on it and four bolt truck exhaust manifolds.
    Sharpone, AndersF and SS327 like this.
  10. Beanscoot
    Beanscoot
    You might have mentioned it, but are you getting a new cam and lifters, or reground?
  11. Ebbsspeed
    Ebbsspeed
    WOW!! Grimshaw, Alberta, CA Home of the worlds biggest early hemi!!
    V = π X R² X Stroke
    V = 3.14 X 4 X 6.625
    Cylinder volume is 83.21 cubic inches
    83.21 X 8 Cylinders is 665.68 cubic inches.
    ( I think there was a typo in your post)
    SS327 and 57 Fargo like this.
  12. Sharpone
    Sharpone
    Looking good
    Dan
    57 Fargo likes this.
  13. 57 Fargo
    57 Fargo
    Reground, it’s at Interior Cam in Salmon Arm, BC
  14. 57 Fargo
    57 Fargo
    Oops! It’s stock stroke 4” bore!!
