Projects Interior upholstery finally
Discussion in 'The Hokey Ass Message Board' started by Blue One, Jan 23, 2026.
  1. nochop
    nochop
    from norcal
    I like it. After bailing out of body shop jail, I’m going to have to do mine. You inspire me
    hrm2k, porkshop and Blue One like this.
  2. Blue One
    Blue One
    from Alberta
    The Armrests were another area of concern. If you followed my build thread back when you could see that I had made them from wood and shaped them to look nice.
    I almost gave up trying to cover them with the same Upholstery fabric because no matter what I tried the cloth backed vinyl was too thick to wrap smoothly around small compound curved sections.
    Finally I decided screw it ! Only the tops needed to be padded so I made a couple of small flat 1/8 “ ABS plastic pieces that would snap down on the top into two pieces of metal with holes for the same spring clips that I had used on the side panels. Two clips for each top pad.
    I then sanded and painted the armrests and discovered that they were too glossy.
    Took a trip to the automotive parts department and found some vinyl matt black wrap that came in 6” wide strips that were perfect match for the rest of the interior.
    Once the armrests were wrapped I covered the top pads with the upholstery vinyl and 1/2” foam. (All the door panels were done with 1/4” sew foam.)
    You might notice that the edge of the top armrest pads are trimmed with small black polyester cloth welting cord which matches the black binding on the carpets.
    IMG_3218.jpeg IMG_3217.jpeg IMG_3216.jpeg IMG_3219.jpeg IMG_3220.jpeg IMG_3228.jpeg IMG_3229.jpeg IMG_3224.jpeg IMG_3223.jpeg IMG_3227.jpeg
  3. Tim
    Tim
    from KCMO
    Looks great man
  4. Very nice,looks professionally done:cool:!!
    hrm2k, Six Ball and Blue One like this.
  5. 57 Fargo
    57 Fargo
    Looks good Larry! Not surprising given the quality of the rest of your build!
    hrm2k, Driver50x and Blue One like this.
  6. hotrodA
    hotrodA
    VERY NICE!
    hrm2k, TomT and Blue One like this.
  7. Looks real good. Thanks for the disclosure o the arm rests, and use of OEM floor mats. We often convert to weather fighting type floor mats right away, and have brand new originals kicking round.
    hrm2k, 05snopro440 and Blue One like this.
  8. Hellfish
    Hellfish
    nice!
    hrm2k and Blue One like this.
  9. Groovy
    Groovy
    Looking great Larry... I'll bring over my Rod so you can finish my interior ;)
    hrm2k likes this.
  10. 05snopro440
    05snopro440
    Looks great! Hope I get to see it in person this year.
  11. 325w
    325w
    How did you attach the arm rest to the inner body panel? Maybe you attached the arm rest to the door panel before you installed the pad? Very well done!
    hrm2k likes this.
  12. Six Ball
    Six Ball
    from Nevada
    Man. You are the real deal!
    hrm2k, TerrytheK and Blue One like this.
  13. Blue One
    Blue One
    from Alberta
    I’ll be out to the Sherwood park Tuesday gathering a few times I think.
    hrm2k and 05snopro440 like this.
  14. Holy smoke, is there no end to your talent?? :)
    I think I can count on one or two fingers the folks I know who have done their own interior.
    Superb work on those armrests too!
  15. Blue One
    Blue One
    from Alberta
    The armrests are secured with screws from inside the panel. The top pads are snapped down into place and I attached them before popping the panel in for the final time.
    Details on how I made the panels and the armrests are here in my build thread.
    https://www.jalopyjournal.com/forum/threads/26-t-roadster-pick-up-build-thread.460009/page-29
    hrm2k, TomT and Six Ball like this.
  16. 05snopro440
    05snopro440
    I did see it there probably 4 or 5 years ago. It's a beautiful hot rod. Hope to run across you this year there too.
  17. Bandit Billy
    Bandit Billy
    Excellent work as always. I like the shifter boot and trim. Nice touch.
  18. bchctybob
    bchctybob
    Great finishing touch to a beautiful little car. Nice work….. again.
  19. Fortunateson
    Fortunateson
    Hey, get in line!!!
  20. Blue One
    Blue One
    from Alberta
    :D
    This is one upholstery shop that isn’t having a grand opening :D
    Sorry guys.
    I’m retired and I’m not looking to start another career.
    Deutscher, hrm2k and RodStRace like this.
  21. TomT
    TomT
    Just a stellar job! Congrats!
    lothiandon1940, hrm2k and Blue One like this.
  22. RodStRace
    RodStRace
    @Blue One I agree that you have done a fine job, especially for your first.
    I'll mention something that you are probably fine with, because of the car and the design.
    Most arm rests also act as a handle to close the door but not here. You have a nice door top to grab.
    If anyone is copying this for their car, realize OEs continue to have fasteners going from the handle area into the door inner structure so the force is spread and the door card isn't constantly pulled on.
    You see all these single piece molded door cards from the 70s up to now and they still have the screws where they get pulled on.
    Try to include this rather than just attach the feature to the card if you are going to be pulling on it. Notice this has no 'cup' to grab.
    Deutscher, hrm2k and down-the-road like this.
  23. -Brent-
    -Brent-
    Awesome!
  24. hrm2k
    hrm2k
    Damn nice Larry !!!!
    lothiandon1940 and Blue One like this.
  25. Blue One
    Blue One
    from Alberta
    So a little side note, as they say if you’re not making any mistakes then you aren’t doing anything.
    After doing my upholstery and having the panels popped into place I kept looking at one spot that just didn’t look to be seated properly with the clip.
    Now these spring clips are great they really hold well however you really need to be sure that both of the points are aligned into the mounting hole before giving each of them a smack with your closed fist to pop them into place.
    So I removed the drivers side seat today and popped the rear side panel partially off and sure enough the clip circled had folded over and not snapped into place.
    Now as strong as these spring steel clips are they don’t take to being straightened once they’re bent they typically snap off.
    So off came the panel and a new clip was installed.
    The whole thing took less than 2 hours and it’s all good now the lesson learned was make sure to line the holes up with the clips started in each hole.
  26. RockyMtnWay
    RockyMtnWay
    Any chance you entered the car in the Calgary world of wheels show at the end of this month? Would be nice to see it in person.:)
  27. Blue One
    Blue One
    from Alberta
    No I didn’t, never really considered doing that.
    Maybe I’ll do that in the future.
    I’ve only taken it to local shows and cruises stuff like that.
    I did haul it out to Vancouver island in 2020 to take my father for a ride when I first got it on the road.
    Glad I did because dad p***ed away the following year.
    I’ve mostly just been enjoying driving it myself.
    HemiDeuce and RICH B like this.
