57 Chevy BelAir Gasser Build
Discussion in 'The Hokey Ass Message Board' started by KrucksGarage, Jan 9, 2023.
  1. KrucksGarage
    KrucksGarage
    Working the front frame section. Narrowed up the new front end for the new axle. Stepping away from the '56 Chevy truck axle and going to run with a straight tube axle setup. Still running Chevy spindles and steering but going to run 49-54 car spindles vs truck stuff. Narrowing up the frame section allowed me to tuck the rails to the inner side of the factory frame, so grafting was more on the outside only vs both inner and outer. I'll get the axle mocked up and design leaf spring hangers next and get this to a rolling ch***is.
    PXL_20260117_215218511.jpg PXL_20260117_015833704.jpg PXL_20260117_215225620.jpg PXL_20260117_231456574.jpg PXL_20260117_231502542.MP.jpg PXL_20260117_231511323.MP.jpg PXL_20260118_215630070.jpg PXL_20260118_002724859.jpg PXL_20260118_002736631.jpg PXL_20260118_002712240.jpg PXL_20260119_220056678.jpg PXL_20260119_222709269.jpg PXL_20260119_223017283.jpg PXL_20260119_223513233.MP.jpg PXL_20260119_232930003.jpg PXL_20260119_233846500.jpg PXL_20260121_015339872.jpg PXL_20260121_015346002.jpg
  2. Jacksmith
    Jacksmith
    from Aridzona
  3. AHotRod
    AHotRod
  4. KrucksGarage
    KrucksGarage
    The outside fish plates are not the finished product. I cut the holes for better weld area directly to the frame rail. I'll come back in and fab up a 3-sided angled piece on the brake to come in at the body mount and head forward to the frame to triangulate that a little bit and clean everything up. I put that filter piece between the body mount and frame just to make things nice and solid. I've got a little forming to do on the outside and probably will cut holes for weld there as well. So far everything is nice and solid and dimensionally still spot on. I had some nice X-bracing that I didn't think to take photos of during most of the welding.
    Also not shown is I heated and formed the top of the existing frame section to mold tightly to the new frame then welded those together before actually installing the fish plates. I forgot to take pics of a few things.
  5. chevy57dude
    chevy57dude
    That is a super sturdy looking job! Good looking work also.
  6. KrucksGarage
    KrucksGarage
    Thanks
    lothiandon1940 and Sharpone like this.
  7. KrucksGarage
    KrucksGarage
    Outer graft plate idea...
    PXL_20260125_190938314.jpg PXL_20260125_194623084.jpg PXL_20260125_195803795.jpg PXL_20260125_195819665.jpg PXL_20260125_195919887.jpg PXL_20260125_195924913.jpg PXL_20260125_201301572.MP.jpg PXL_20260125_201306916.jpg PXL_20260125_201310773.jpg
  8. KrucksGarage
    KrucksGarage
    Calling this good for now until I get the axle mocked up and start building spring hangers. Welded up and faired in the outer plates tonight.
    PXL_20260126_035929859.jpg PXL_20260126_035936150.jpg PXL_20260126_035944404.jpg PXL_20260126_035951670.jpg
  9. rusty1
    rusty1
    ...nice work
    KrucksGarage likes this.
  10. Jacksmith
    Jacksmith
    from Aridzona
    Good job... better than most!
  11. KrucksGarage
    KrucksGarage
  12. saltflats
    saltflats
    from Missouri
    Nice work.
  13. Glad to see you are still working on it
    KrucksGarage and lothiandon1940 like this.
