Projects flathead 471 blower/supercharger
Discussion in 'Traditional Hot Rods' started by Ed95, Jan 22, 2026.
  1. Flatrod17
    Flatrod17
    Refer back to my earlier picture, it was done to clear the water manifolds.
  2. oj
    oj
    Lt me clarify one thing, the above math is correct for calculating your CFM, but where they show engine cubic inches it is misleading because what they show is 720degrees of crank rotation, to figure your CFM you want 360degress (1 rotation) since you feed only 4 cylinders per revolution.
    I have all of Szabos' books and he is quite clear that you need to base all your calculations on 1 revolution, ie a 350ci motor is 175ci when you do the math.
    The concept is simple, you calculate cubic feet of air per revolution (then convert to pounds to calculate how much fuel you'll need) and to get CFM multiply it by whatever RPM you'll run at. btw, the numbers will be very small.
    Outback, mad mikey and 19Eddy30 like this.
  3. AccurateMike
    AccurateMike
    Volumetric Efficiency ? A flathead at 40-50% has to be different than an 80-100% OHV engine.
    Outback likes this.
  4. 19Eddy30
    19Eddy30
    from VA
    I know there is more technical math for sufficient power & fueling @ the level of tunning you are @ , including your leave of tunning over me, we know It can be leaned.
    The information I posted is just for beginner average person installing a
    blower /supercharger force induction..
    We both know there is more involved.
    You can explain way better than I can,
    The average person calls up & purchase a bolt on Kit is not going to get all the
    Information as you mention,
    I am not claiming I know all thats in Szabos book's , I know if I need a better under standing or direction Bob is a phone call away
    Outback likes this.
  5. NJ Don
    NJ Don
    Saw this at Rodtoberfest in NY last year:
    1pickup, 1952henry, Ziggster and 8 others like this.
  6. gimpyshotrods
    gimpyshotrods
    Pruning is primarily done for clearance, but sometime done for a cleaner look.
    On a flathead, the mounting flange would collide with the radiator hoses.
    I recently pruned a 4-71 that went on top of a Dodge 270 Red Ram Hemi. That one was for looks.
    It cleared just fine. In the context of the vehicle that it went on, it just appeared to be too much m*** on top of the engine. It was purely an aesthetic choice. It looked too bulky.
    I am currently doing up another Dodge 270 Red Ram Hemi, that also has a 4-71. This one is in a full-bodied vehicle, with fenders. In this case, since there is "more vehicle" surrounding the engine, it has a better visual balance.
  7. Bandit Billy
    Bandit Billy
    Cleaner look definitely. Less strong? I doubt it. 6 bolts instead of 4. Intake is Navarro from the Mikes at H&H. On an 8BA (Any 49 and up FH) you could run one not pruned as the T-stat housings are ahead of the blower case. On an earlier FH it can get tight in the center.
  8. oj
    oj
    Sorry, not my intention to be critical of your post and we really aren't tuning here anyway, just working out the CFM. You are right, Bob or his daughter are very approachable and have the gift of explaining things in a way that we all lack.
    3ARDUN2 likes this.
  9. 19Eddy30
    19Eddy30
    from VA
    @oj
    No problem , most hear maybe do not know how knowledgeable you are
    & what you are into / do ,,
    My self trying to explain things is difficult for most to understand unless you have my personal Cryptid
    decoder ringo_O
    Ed95 and Outback like this.
  10. Ed95
    Ed95
    Hey OJ! Great to see u in my thread haha. You just welded my radiator tabs last week! I also got one of your rebuilt 94 carbs…
    You work on superchargers too? I got this 471 blower and will most likely need a ton of help to set it up! Would love to pick your mind! IMG_4503.jpeg
    Here’s my little truck! Just finished ***embling grill and hood thanks to u! :D
    1pickup, Ziggster, Outback and 2 others like this.
  11. oj
    oj
    Ah, yes! My mind is similar to the local dump: very well picked over, but I'll be happy to help if I can.
    Outback and patsurf like this.
  12. oj
    oj
    I was pondering that '3456' theorem in the calculations and it occured to me that it is actually 1728 (the amount of cubic inches in a cubic foot) X 2 - so the calculations provided by 19Eddy30 would work fine, the answer would be the same, just a different way of getting there, my bad.
    Outback likes this.
  13. Heres some ideas
    Outback and Ed95 like this.
  14. Ed95
    Ed95
    So i got the blower delivered…
    IMG_4531.jpeg IMG_4535.jpeg spins easy but the guy i got it from said its got new rotors new bearings seals and gasketsand that it will need to be timed. Its missing the rear and front plates and I’ll need a top plate for my dual 94s.(I may do 3 holley 94s). Here’s what I’m thinking so far… i found most things available from mooneyham website and the carb adapter from ebay IMG_4532.jpeg IMG_4533.jpeg IMG_4534.jpeg
    I think these are very standard parts but I’m not very well versed. Anything jumps out or things I’m missing or should think ahead of? I still don’t know about the snout.. also found munro intake available from $800 and my engine won’t require the blower to be pruned so it should be an easy bolt on IMG_4536.jpeg
    NJ Don, akoutlaw and AccurateMike like this.
  15. Another option on the blower manifold (if you want a trimmed case) is to buy the one from H&H - it has two pop-off valves (which is a good idea). Personally, I like a pruned case - just looks better on a flathead and makes it easier to run center water outlet heads. On the upper carb manifold, you might see what Nystrom Performance is cooking up. He is making a 3-carb cast manifold that looks pretty cool.
    gimpyshotrods, Ed95 and 3blapcam like this.
  16. Ed95
    Ed95
    I do like that look better but i don’t understand how it attaches. When you prune the blower you get rid of the screw holes no?
  17. gimpyshotrods
    gimpyshotrods
    You drill and tap the bottom of the blower.
    The bolts go through the manifold flange, into those new holes.
    This is one of my manifolds. You can see the socket head cap screws.
  18. 19Eddy30
    19Eddy30
    from VA
    @Ed95
    Timed ? & spin's freely .
    Sounds timed now ..
    If you R& R rotors mark left & right .
    With end plate on case make also .
    Timing is done on gears ,
    Some have shims under gears to bearing or you take material off the snout to bearing the faces the rotors.
    Then you check Rotor to case .
    Need long feeler gages like 10-16 inch long .
    Do you know when punned mount you need to pull one of end plates off with rotors to attach or remove from intake .
    Mounting bolts in side case & care in torque , on outer Flang mount case
    Bolts are torqued 7/16 to 10-12 ft pounds , on a flat surface.
    If not flat & even torqued rotors will / can scrub .
    @gimpyshotrods what's the torque when Punned mounted & bolt size?
    Ed95 likes this.
  19. Why would I need to pull the rotors to bolt up the pruned case?
  20. 19Eddy30
    19Eddy30
    from VA
    Mounting Bolt are on inside ,@ least one's I seen .
    ,No longer on out side flange mount
  21. I would think they are on the perimeter of the opening - just like the top and you'd bolt through the manifold flange into the drilled/tapped areas of the 6 or so perimeter locations. Essentially, the bottom would be very similar to the top, except for maybe 2 more bolt locations.
  22. gimpyshotrods
    gimpyshotrods
    I use Grade 8, 3/8-24 bolts, torqued to 30lb.-ft.
    19Eddy30 likes this.
  23. You tapped it for fine thread? I would have thought you'd have used a NC thread in cast aluminum.
  24. DDDenny
    More thread engagement using fine thread.
  25. 19Eddy30
    19Eddy30
    from VA
    But co**** deeper threads.
    No engineer , just off top of head
    Wonder if .250 of fine tread equals
    .125 of co**** thread because of deeper
    Engagement ?
    It you tap something when to know use
    Co**** or fine ?
    Like .500 of threads in 7/16 to 1/4 hole size .
    Is there a rule of thumb ?
  26. Flatrod17
    Flatrod17
    I always thought co**** thread in soft materials, aluminum, cast iron, plastic....
  27. Ed95
    Ed95
    So i can prune this thing (i like that look better) but need to drill holes to attach studs? Or do i drill thru the blower and do bolts from inside to outside? Doesn’t that mess with boost? Or let air out or anything like that?
  28. DDDenny
    Do you have or know someone that has a drill press or milling machine?
  29. Flatrod17
    Flatrod17
    20260201_174238.jpg Picture of thr bottom side of what I did. I used 6 5/16 studs. They do not go through into the rotors. Manifold has a flange the studs go through. 20260201_173251.jpg
    Bandit Billy, 3blapcam and Ed95 like this.
  30. patsurf
    patsurf
    always been my leaning as well!
