Projects The "Red '34". 1934 Ford 5 window project.
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Dec 1, 2024.
  1. Tim
    Tim
    from KCMO
  2. RMcCulley
    RMcCulley
    Looks great
  3. flamedabone
    flamedabone
    Pretty short and not terribly thrilling update. Last you saw, the body is painted so that leaves the complete mocked up ch***is.
    Peeled it down to the bare rails and made all the boxing plates.
    I also tried to decode all the little notes I made when I was putting this pile together.
    I like to weld all the crossmembers to the outer frame rail then...
    Weld them to the boxing plates also. Does it make it better? Hell if I know, but I like to do it that way.
    FINALLY!!!! the frame is a real color. Not sure what that yellow primer **** was, but it is nice for it to be finally gone.
    Next is painting some ch***is bits and making this frame a roller again.
    See ya, -Abone.
  4. Tim
    Tim
    from KCMO
    Big kid Lego after Christmas! Perfect!
  5. flamedabone
    flamedabone
    Now officially a roller.
    Before you stuff the engine and trans together, you have to center the bellhousing. Bolt up the bellhousing and stick your mag base dial indicator on the crank. Crank that ****er around a few times and note the concentricity of the hole in relation to the crank.
    Then you install offset dowels for however many degrees it looks like you need.
    This is the point where you have two choices. You can use your dial indicator and math out your hole until it is dead nuts. Or, you can spend 180 bucks on a bellhousing indicator tool from Browell. These things are a life changing event for us dudes who like three pedals. The ball bat looking part centers on the crankshaft register.
    Then you install the bellhousing and try to install the doughnut ring.
    Shine a flashlight inside the housing and it will tell you which way to rotate your offset dowels.
    In my case I needed to go down and to the right about 7 degrees. Adjust the dowels until the doughnut ring slides right on dead nuts. When it moves in and out of the register freely, you are ready to go.
    Hey, look. The little Chevvie motor still fits.
    And, there you go. Ch***is is ready for a bit of brake and fuel plumbing then the body goes on for the last time.
    See ya, -Abone.
  6. Tim
    Tim
    from KCMO
    That’s slick!
  7. Just Gary
    Just Gary
    *****in' build!:cool:
  8. Chief 64
    Chief 64
    Thanks for the “tech session” on bell housing alignment!! That was good information!
    bschwoeble, chiro, Woogeroo and 3 others like this.
  9. Corn Fed
    Corn Fed
    I like that tool. I'll have to get one. Thanks for sharing how you use it.
  10. flamedabone
    flamedabone
    Time to fire this little engine. She is a "recently rebuilt" 327 that came out of my buddies '67 Chevvie pick up. He put a godam L* in his truck, so this little skinny block came to my house. I have built an *** load of SB Chevvies in my time, but this is only the second one I have actually owned. She sat the whole time I was building that car, so she gets a little prime job before cranking her up.
    She fired right up as these little Chevvies often do. 9.5 to 1 mild cam, nothing crazy. I'm not smart enought to embed videos correctly, so you have to click on this red34t
    One more try for the video.
    red34 - YouTube
    Time to stick the body on for the last time.
    You might remember, I dropped one of these once...
    Oh my god and holy ****, it's on there for the very last time. No drama, no carnage, just fell right on there.
    Rear.
    And, a rare p***engers side shot.
    'Nuther.
    There you have it. Got a few more knick-knacks to do then I'll see you right here for gl*** and wiring.
    -Abone.
    RMcCulley, drdave, Sharpone and 36 others like this.
  11. willymakeit
    willymakeit
    Nice build
    Sharpone likes this.
  12. Johnny99
    Johnny99
    Standard operating procedure for you. *****in!
  13. Tim
    Tim
    from KCMO
    Awesome!
    If your video isn’t filmed in landscape ( horizontal) and is under 30 seconds long it doesn’t imbed and just puts the link how you have it.
    looks like you had it horizontal so just make the next clip longer and it should work fine.
    Sharpone and Just Gary like this.
  14. Just checking in on the progress. You will be driving it in no time.
  15. lo c dan
    lo c dan
    Love it when a plan comes together . . Expectations met and exceeded, well done sir. Keepin this one or another love'm n leave'm story?
  16. flamedabone
    flamedabone
    Knocking out all the knick-knack **** that needs done on a hot rod. Not terribly ***y, just stuff.
    PCV and carb linkage.
    Fuel lines
    Radiator shroud.
    Dash wiring.
    Dash ready to bolt on for the last time. Oooo...shiny...
    And you know **** is getting serious when you install the cowl vent HAMB decal.
    That's it for now. Next is finish wiring and an illegal test drive.
    -Abone.
  17. lo c dan
    lo c dan
    lookin great
  18. rusty1
    rusty1
    Wowza!...very nice lookin coupe.
  19. To some people, this is ***y!
  20. Tim
    Tim
    from KCMO
    Nice!
  21. Robdski
    Robdski
    Excellent
  22. RICH B
    RICH B
    Wiring on back of the dash looking good, nice and neat. Curious what the unwired switch is intended for.
    panhead_pete likes this.
  23. RMcCulley
    RMcCulley
    Nice and Clean. Way cool.
    I like what you did for the PCV (and everything else) . Curious, did you put a baffle on the inside of the valve cover?
    I might have to borrow what you did
  24. flamedabone
    flamedabone
    Here is today. Most of the main wiring is done and it starts with a key.
    Got the dash and tach wired.
    And it lights up...
    It starts with a key, so that can mean only one thing... illegal test drive. All the way to the Quickie Mart with no issues. Cop didn't see it, I didn't do it.
    And, I'll the way home too.
    Just a few little things to finish on the wiring, then it is gl***, front sheet metal then wrap this ***** up.
    See ya, -Abone.
  25. panhead_pete
    panhead_pete
  26. MMM1693
    MMM1693
    X2 on the outstanding!
  27. Tim
    Tim
    from KCMO
  28. MMM1693
    MMM1693
    Very tasty! What size and brand are those rear tires?
  29. panhead_pete
    panhead_pete
    @flamedabone . Years back did you build a similar car and photograph it outside the same house? Was in a For Sale post? Looks eerily similar to one I recall?
  30. flamedabone
    flamedabone
    Hey, Pete. I have done a pretty good run of '34 Fords and my house has been in the background of a few of 'em. The car you are talking about went to a cool HAMBer in Oklahoma some years ago. Good little car, not sure if he still has it.
    -Abone.
    Shadow Creek, Thor1, lo c dan and 4 others like this.
