Featured Technical x
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Nov 24, 2025.
  1. ekimneirbo
    ekimneirbo
  2. M C Empson
    M C Empson
    I have to ***ume these are cap screw rods and not a bolt and nut. I if this is true you won't need to resize the rod as it doesn't have an interference fit that causes distortion.
  3. RodStRace
    RodStRace
    I would contact the company. Explain your concerns and see what they say. If this is a rod bolt pressed into the rod, I'd ask the proper procedure they use and if honing will be needed and if they cover that.
    I think that they should have covered all of this when you ordered the second set, but give them another chance to make this right. Seems like they need a bit of work on communication skills.
    Oh, and have the ends properly torqued and measured before use as normal!
  4. Mr48chev
    First step is to check the ARP catalog and see if they list different rod bolts for that application to see if you just got old a bill of goods. Some times it is a case of "if you have this combination you have to reun these bolts for clearance" though.
    Still for your current peace of mine it is ***emble the rods with the bolts and either measure the diameter of the end with a snap gauge and micrometer or load them up and head to a local machine shop that has a Sunnen rod hone with the gauge on it that you/they can check the rods and make sure that the ends are round.
    Not that it can't happen but I have never seen a case of where the rod big end was distorted by swapping for upgrade rod bolts. I haven't resized a rod since trade school but the normal method is to clamp the rod in a fixture and grind a few thousandths off the mating surfaces of the rod and the cap and then put them back together and torque them and hone them back to where they are round and the ID is on spec. That is +/- a very thin RCH over on the 4th didget of the .0001 scale.
  5. squirrel
    I got to resize the rods for my 327 a couple years ago, it was fun to get back into it.
    Yeah, we really need to know if there are rod nuts involved, to be able to answer the question.
  6. RodStRace
    RodStRace
    Glad to hear it, @ekimneirbo . Make sure you have that first cup of coffee and a checklist handy when you start ***embly. :D
  7. I only trust a dial bore gauge for measuring, As I remember (iffy at best) rods measure slightly larger at the parting line so as to not break the hydrodynamic wedge. If it's round everywhere except the parting line and within spec, I would run them. :) I should add that many modern rod bearings are a little wide at the parting line to do the same thing.
  8. twenty8
    twenty8
    What's with the going back through your previous threads and posts and deleting stuff???
    I know you got some things explained to you in the last thread you started, and that got shut down, but why do you feel the need to ruin a lot of other informative threads? Let it go, man. A tantrum doesn't help.
    You could find yourself locked out so as to protect previous threads/info from your deleting, and that would be a shame.
  9. Kerrynzl
    Kerrynzl
  10. DDDenny
  11. hotrodjack33
    hotrodjack33
    X-member?
    X-marks the spot?
    X-****?
    To be honest, I was rooting for ****...;)
  12. twenty8
    twenty8
    Dude seems to be going back through past posts and threads deleting stuff and replacing it with X's.
    This will make a lot of threads wonky and the info in them hard to follow.
    I hope he stops, OR IS STOPPED, before he causes too much ****.
    @Moriarity ???
    5window, Outback, deadbeat and 7 others like this.
  13. 57 Fargo
    57 Fargo
    Imagine being a grown *** man pouting about pictures getting deleted….sad
  14. 41 GMC K-18
    41 GMC K-18
  15. twenty8
    twenty8
    The problem seems to have been dealt with. His profile page now comes up as "ERROR" so it looks like he has been sidelined. I don't get why some people find it so hard to just stand down and save their own ****.
  16. Royalshifter
    Royalshifter
    Moderator
    Some folks forget we are guests to this site and they decide to start problems, be the problem solver for the m***es.
    Keep it real and by the rules, you will succeed.
    Traditional Hot Rods and Custom cars it is very simple.
    I have been here for 20 years and see folks come and go, the majority of you great folks keep helping others and trust me it is observed, but if bad decisions effect others it has to be taken care of and sometimes its an unfortunate end.
    NoSurf, Sharpone, silent rick and 5 others like this.
  17. Ebbsspeed
    Ebbsspeed
    I'm not sure "grown *** man" is an accurate description, given the boy's recent activity.
    hotrodjack33, Sharpone and 57 Fargo like this.
  18. oldiron 440
    oldiron 440
    I thought X marks the spot and ** is a Tshirt/sweat shirt size.
  19. J. A. Miller
    J. A. Miller
    from Central NY
    And **X are naughty movies... Or so I'm told.:rolleyes::eek:
    hotrodjack33 and oldiron 440 like this.
  20. RodStRace
    RodStRace
    Movies made in the 2000s? :rolleyes:
    hotrodjack33 likes this.
  21. '29 Gizmo
    '29 Gizmo
    from UK
    Thought Musk had joined
    Sharpone, hotrodjack33 and twenty8 like this.
  22. 1971BB427
    1971BB427
    from Oregon
    This is usually a signal that somebody's been rude or attacked the person, and they've had enough. So they're deleting their responses wherever they can find them.
    19Eddy30, Sharpone and Royalshifter like this.
  23. silent rick
    silent rick
    aka, take their ball and go home
    twenty8, Sharpone and 5window like this.
  24. 5window
    5window
    The OP gentleman should read his own signature: "It takes considerable knowledge to realize the extent of your own ignorance."
    Fordors and Sharpone like this.
  25. oldiron 440
    oldiron 440
    Well I don’t know why I didn’t think of this before but a lot of us have an X wife but my second wife is now my ** wife and when we got divorced she was an **X large but I saw her the other day and she is up to an **** large now.
  26. Sharpone
    Sharpone
    If I looked at it correctly there is like 11,000 people on today. One less isn’t going to make or break the site.
    The rules here are pretty simple.
    I get breaking the rules in essence that is what Hot Rodding and Customs is all about.
    If getting pinched by the man makes ya quit you never were a true hotrod hoodlum.
    Dan
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
  28. DDDenny
    I'll get over it........nevermind!
    twenty8 and Sharpone like this.
  29. 1pickup
    1pickup
  30. twenty8
    twenty8
    Wouldn't that be ****TER...???:D:rolleyes:
    Sharpone likes this.
