Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Sharpone
    Sharpone
    Getting propane tanks filled so I can get garage up to working temp. I might get it warm enough by Feb lol
    Dan
  2. Blues4U
    Blues4U
    from So Cal
    Got the pained grill shell installed. Just ding some general clean up, polishing the wheels, and making sure the battery is charged up, getting ready for GNRS later this week. 20260124_171214.jpg
  3. Sharpone
    Sharpone
    Looking good very good!
    Dan
  4. mad mikey
    mad mikey
    Looks great, have a good time.
  5. deathrowdave
    deathrowdave
    from NKy
    I have been tinkering with the Tiger engine . Trying to locate correct era parts for the look , internals all modern stuff , as in roller cam and such . Clearing snow for the last 3 days
  6. Blues4U
    Blues4U
    from So Cal
    Thanks guys. Mike it should be a blast. I'll be there for set up day on Thursday and I have a 3 day p*** to drive in and be part of the show. I'll take lot's of pics!
  7. Working on some small welding art entries for an compe***ion at a custom Invitational we are going to in March.
    Fingers crossed.
    20260118_130119.jpg 20260119_102507.jpg 20260118_130033.jpg 20260119_141511.jpg 20260119_141601.jpg
  8. tim troutman
    tim troutman
    been working on the front floors rockers fire wall and cowl support of the 36 phaeton way more solid than before 20260129_193816[1].jpg
  9. chevy57dude
    chevy57dude
    Nice, Tim! It has to be sturdy when you stomp the gas.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Removing stuff that somehow got into the cab. IMG_5271.jpeg On to sorting. IMG_5274.jpeg IMG_5273.jpeg Much better. IMG_5276.jpeg Oh ****, there more on the other side IMG_5275.jpeg But at least when housekeeping is done there’s a resting place for the cab again. IMG_5270.jpeg
    saltflats, 5w Jen, Blues4U and 7 others like this.
  11. ERguitar
    ERguitar
  12. HOTRODNORSKIE
    HOTRODNORSKIE
    Finished my mallory double life today polished it ,new points and special thanks to Tubman for supplying the new condensers we had a heck of a time getting them hear but everything worked out in the end the distributor is going on my olds rocket. 20260207_113845.jpg 20260207_113819.jpg 0k
    Paul, Jeff34, BigRRR and 19 others like this.
  13. tim troutman
    tim troutman
    still working on the floor of my 36 not perfect but feeling good about it.next step bolting it to the frame 20260207_152114[1].jpg
  14. High test 63
    High test 63
    Looks like its coming along well Tim
  15. squirrel
    Taking apart another 327. Because I can. Kinda rusty. Oh well.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^* Just keeping the crankshaft?
  17. squirrel
    I don't know yet. Looks like it might need two sleeves, might not be worth messing with.
  18. I took advantage of 76-degree Monday and pulled the AOD to replace the seal. I think I got it, thanks to Saltflats and others who suggested punching out the old seal instead of pulling the pump. I got the trans married to the engine, tightened the torque converter nuts to the flex plate, getting ready to finish ***embly when the next warm(ish) day rolls around. Several things I've noticed during this annoying little exercise: The trans jack has raised the engine/transmission a little higher than it sits at stock height and the fan is just touching the bottom of the radiator, so I'll have to watch that closely once I lower the trans jack to re-install the trans crossmember; I noticed that the hose connecting the vacuum brake booster has come loose from the tube coming off the back of the intake, which explains why my power brakes weren't powering up; in using the starter to turn the engine so I could mesh the flex plate and torque converter studs I noticed that the carburetor was leaking at the transfer tubes so I've ordered new O-rings to stop the leak; in pulling down the temporary exhaust plumbing to remove the transmission, I noticed that a hose between the trans cooler and the cooler in the lower tank of the radiator was slightly burnt from touching the hot pipe, so re-routed that; while under the engine/transmission I noticed that oil was weeping from the drain plug on the oil pan. I'll see if NAPA has a new one. Wrapping the old one with Teflon tape wasn't getting it.
    If once I get this back together the transmission doesn't leak, I should be well on my way to big progress on other aspects of this project. If it still leaks, I'm back to pulling it down, then taking it to a transmission guy I can rely on and paying him to solve the issue.
    Sharpone, saltflats, 5w Jen and 6 others like this.
  19. deathrowdave
    deathrowdave
    from NKy
    Fitting up some parts , to determine what’s going to work and whats not IMG_4811.jpeg IMG_4810.jpeg
    enloe, swade41, Sharpone and 10 others like this.
  20. 5w Jen
    5w Jen
    from Sweden
    Working on welding some bungs on the headers for our Chrysler 354 Hemi,
  21. chevy57dude
    chevy57dude
    @squirrel - That looks like a forged crank, good stuff! Small or large journal?
  22. ^^ Damper shows it's small journal. I would like it. JW
    Sharpone, squirrel, porkshop and 2 others like this.
  23. squirrel
    It's a 1963 engine, steel crank small journal 327.
  24. hrm2k
    hrm2k
    IMG_3332.jpeg Finally putting a 6 point roll bar in the V8 . The yellow bar is from the 300 piece header modeling kit. Love that tool !!!
    enloe, porkshop, BigRRR and 7 others like this.
  25. chevy57dude
    chevy57dude
    Ay, yo, Anthony! Cool push****on.
    porkshop, Sharpone, mad mikey and 2 others like this.
  26. chevyfordman
    chevyfordman
    Got this off a 1937 ford truck sitting in a ditch; so I could try and save it and see how they work. It was very rusty but after a few weeks, I got it all working. IMG_3233.jpeg
    1952henry, rod1, porkshop and 12 others like this.
  27. Black_Sheep
    Black_Sheep
    A good part of the day was spent installing a headliner I made for the '58...
    enloe, deathrowdave, rod1 and 15 others like this.
  28. choptop4
    choptop4
    20260202_132403.jpg 20260202_132415.jpg 20260212_133814.jpg made new firewall insulation and toe kick panels. Woodgrained the heater to match the dash and trim.
  29. swade41
    swade41
    from Buffalo,NY
    I wet sanded the little Willys I painted last fall, then shot it with satin clear to give the gloss paint a more primer look.
    Then blacked out the grill and added some sticker headlights
    Sandcrab, deathrowdave, rod1 and 10 others like this.
