Technical How to lower 1955 BUICK Front End
Discussion in 'Traditional Customs' started by orula, Jun 4, 2025.
  1. orula
    orula
    Hi there, it's been a while since I wrote, greetings to everyone from little Italy.
    I took a '55 buick century 4 dr ht.
    To lower the rear I installed 2 '78 Chevy Malibu springs. It's perfect now.
    What springs can I get to lower the front end by 2"?
    Any help will be appreciated
    Thank you so much
    Frank64
    tb33anda3rd and Sharpone like this.
  2. Bandit Billy
    Bandit Billy
    Hotchkis and Beltech offer lowering springs for your car. If they are in decent condition, you could always remove them, place them in a bucket of water leaving only the top coil exposed to protect the temper of the remaining spring, cut them off with a torch or cut off wheel and reinstall. I say one coil at a time because you can always take more off, but it is hard to put them back if you go too far. :cool:
    bobss396 and Sharpone like this.
  3. Think late 70s Malibu springs will work. 3 inch or so drop
    Maybe.
    Sharpone likes this.
  4. Dan Hay
    Dan Hay
    I did Fatman Fabrications dropped uprights on a 56 Super. I believe they are out of business though, not surprised, their customer service was abysmal. So lowering springs are probably the only cheap and easy way.
    The Fatman product was good so if you can find some for sale, go for it.
  5. orula
    orula
    Thank you very much for your very fast replies and your precious advices.
    I really appreciated it ☺️
  6. BJR
    BJR
    I had a 54 Buick, cut 1 1/2 coils off of the front springs. Dropped it nice.
  7. bobss396
    bobss396
    I use the 1 coil method as my go-to.
    I put new front coils in my OT Belair 6 months ago. They matched the lengths of my old ones. We struggled to get one side done.... too high! Out it came. I didn't think 1 coil would do it, so 2 coils were lopped off.
    It does sit lower than stock and has settled a bit. The rears went in, stock length.
    Just be careful if there is any clocking between the bottom and top of the springs.
    Algoma56 likes this.
  8. Jalopy Joker
    Jalopy Joker
    try shocks2springs.com ,,,, eatondetroitspring.com
  9. aldixie
    aldixie
    Try Down Right Fab. They are on the Buick groups. Apparently they did the originals for Fatman.
    rockable and Algoma56 like this.
  10. jimmy six
    jimmy six
    Remember to have the alignment checked and on my 56 Ford I had to replace rubber stops I ruined and also cut them in 1/2..
  11. SuperWildcat
    SuperWildcat
    I was surprised to see a set of dropped uprights for a $1,000 for the Buick cars. Are there other options?
  12. rockable
    rockable
    Former Fatman employee bought the designs for the dropped spindles and uprights. Look up Down Right Fab on Facebook.
  13. Damon777
    Damon777
    I did 1.5 coils off the fronts in my 50. It was too much. I ended up getting 2" drop springs from Eaton. I am happy with those.
    rockable likes this.
  14. Cut 1 coil, it'll drop it 2 in.
