Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    After fixing the gauge situation, my coworker Steven stopped by on his new motorcycle. He was happy to try the roadster out for size. Like me, he's 6'3" and fits in the car pretty well.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Now to my next question. In the past few months, I've am***ed quite the hours gauge collection. Out of the three that I have, two have a tab marked "+", while the one I'm putting in the car seems to be marked "+" on each tab. Does that mean I just wire it in line like an amp gauge?
    Lots of Hobbs. But where's Calvin?
    Here is what we're working with. I removed the mounting clamp and nut. Any guidance would be greatly appreciated!
  3. No, hour meters need a + signal and ground. I would test it by placing the ground wire on the post and touching each of the terminals one at a time to see if the little ticker starts running to show that the meter is on, that would be the tiny rectangle to the right of the meter display. It will go from black to white and back to black periodically when the meter is powered up. If it doesn't work by grounding out the post then you can try putting positive and ground to each terminal and see what happens, it does look like there is a - symbol under the + one, so it could be either or. I have never seen one like that, usually they are clearly marked to which connection does what. If anyone knows more than me about this, feel free to correct and supercede my comment.
    OzMerc39, Outback, J.Ukrop and 4 others like this.
  4. Some Hobbs hour meters are listed as non polarity specific. Maybe this is one.
    winduptoy, J.Ukrop and 41 GMC K-18 like this.
  5. Tim
    Tim
    from KCMO
    I’ve seen it noted that double + poles on an hour meter gets constant power to one pole and switched power to the other. I’d have to dig deeper into tractor and boat forums to really sus it out.
    Outback, J.Ukrop, 41 GMC K-18 and 2 others like this.
  6. pprather
    pprather
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone for the Hobbs advice—I appreciate it big time.
    I didn't really feel like going down to the garage tonight, but as I was hauling out the recycling I decided to open up the door and take a peek. "While I'm down here," I thought, "why don't I take a look at the Hobbs gauge?"
    For the next 30 minutes, I started playing with circuits and test lights. I couldn't get any of the three meters to work, which seemed really odd. Switch on, switch off, different posts, etc. Then, after finding continuity, I realized I was heading in the right direction. Out came the cloth-wrapped wire, ring terminals, and heat shrink. I plugged everything in per @pprather's diagram and all of a sudden, I heard the sound of an old clock. Tickticktickticktickticktick. It works!
    Just for fun, I tried the NOS Hobbs "Electric" gauge, which I discovered doesn't make a sound. I'm going to stick with the NOS script gauge because it looks the best and fits with the car's overall feel. Last time I heard anything like this was TRJ's old forklift—talk about a throwback.
    I spent the remainder of my time down there cleaning up my thermostat and speedometer cable placements. Not the craziest night in the garage, but it felt great to check a couple more things off the list.
    rpm56, Ragged Edge, Six Ball and 10 others like this.
  8. winduptoy
    winduptoy
    Joey is living life outside of HAMB.....but he is back
    It doesn't wire like an amp gauge, which is in the circuit in series...meaning if you unhook one side everything else in the circuit has no power.
    An hour meter wires in parallel, with one side to ground and the other side to a switched power source....just like your headlights ...
    The oil pressure switch works like the headlight switch....when the engine is running, the pressure makes the normally open set of contacts and powers the hour meter.....loose oil pressure when you stop the engine and it opens, killing power to the meter....true engine run time
    you can switch the meter po wer from just the ignition switch....and it indicates the time the ignition is 'on'
    hope this helps and is understandable...
    good luck
    J.Ukrop, Six Ball, Outback and 4 others like this.
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Tonight's story starts the same as last night. I didn't have the mental capacity to start on the brakes, so I scanned my list to see what I could check off. Next up? "Bolt in seat."
    Not a hard task, but one that's tricky to do quietly. Nonetheless, I located the rest of the hardware, broke out the tools, and got things situated.
    The aforementioned tools.
    And said car. I popped the cowl top back on and took a moment to appreciate this thing.
  10. Hitchhiker
    Hitchhiker
    Don't make me come down there and fix them brakes...
    Woogeroo, winduptoy, warbird1 and 6 others like this.
  11. Outback
    Outback
    from NE Vic, Oz
    Maybe that's the master plan! :p
  12. RodStRace
    RodStRace
    Issue is, @Hitchhiker is in WA, Joey is in SF and the roadster show is in LA.
    It's Wed, so he would have to move fast to fix brakes and still make the show.
    winduptoy, warbird1, Outback and 2 others like this.
  13. Outback
    Outback
    from NE Vic, Oz
    they had better get cracking then! haha
    winduptoy, Six Ball and 41 GMC K-18 like this.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    haha you’re welcome here anytime.
    I can use all the help I can get!!
    No GNRS for me this time around, although I had a little project for the show that I’ll share more about at a later date.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last night’s progress consisted of buying a deep-well socket and two kinds of tape from Cole Hardware. I also ordered an extra spool of NiCopp from the local auto parts store to give me plenty of room for trial and error this weekend.
    It’s kindof a strange feeling to walk down to the garage and not have 1,000,000 things to do. More will come up, I’m sure, but I’m trying to relish in the moment. That’s all for this bus-ride update. More soon!
  16. Six Ball
    Six Ball
    from Nevada
    This reminds me of V1 and all the work you put into getting the mechanical brakes dialed in. No leaks! :rolleyes: Hot rods are like watercolors. It is hard to know when to quit. :confused: :D
    winduptoy, Deutscher, Tim and 3 others like this.
  17. Tim
    Tim
    from KCMO
    When there’s a hole in the paper lol
    winduptoy, J.Ukrop and Six Ball like this.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    This weekend, progress was made on the brakes. Here are a few highlights from the bus.
    The story starts with a shop upgrade. For the first time since 2020, I have a vise mounted in my garage. It’s just temporary, but at least it’s solid!
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Next, I took the bus to the auto parts store to pick up more materials. The weather was so nice that I walked home.
    Nice place to store existing brake line tubing.
    After studying the work of Dennis Lacy and others, I made the move to more organic curves.
    Had to cut up some old test lines to get the best fittings.
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    For my final project of the night, I installed the new RF wheel cylinder. Things went smoothly, although I’m now waiting on a few more original lug nuts before I can call the task complete.
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    And that concludes the weekend updates. I’ll take a picture of the new rear brake line when the light is better. All fittings were installed using the tighten, loosen, tighten (4x) technique, so let’s hope they’ll hold.
    Next up, we’ll be replacing the LF wheel cylinder and replacing the master cylinder. Hopefully that will be later this week!
  22. Tim
    Tim
    from KCMO
    Your getting to the end of the list is not only inspiring that some day maybe I’ll be at the end of the list but also impressive that you’ve got so much restraint to just continue taking your time and doing it right.
    even if your feel like you have to grease that vice and operate in stealth mode.
    J.Ukrop, Six Ball and Outback like this.
  23. Outback
    Outback
    from NE Vic, Oz
    Amen!
    the funny thing as I read your post there was a vise squeaking in the background here :D
    J.Ukrop, Six Ball, Tim and 1 other person like this.
  24. Six Ball
    Six Ball
    from Nevada
    ****, I was feeling bad at the vise part.You have built and torn down and moved 3 shops before I have even cleaned mine. Of course I'm old.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks, Tim! Still a long ways to go, but we are getting there. It’s funny that you mentioned the vise. After two years on my Loyola Terrace back porch, it needed some maintenance to be noise compliant. Now it’s mostly smooth operating!
    hahah fully immersive reading experience
    Nothing to feel bad about. My spaces are usually really small!
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Nothing much to report other than I took another stab at ordering my exhaust tips last night. I also got my battery tender in the mail, so I can charge this thing before I attempt any sort of fire up.
    Tonight I’m focusing on the LF brake and prepping the new master cylinder for paint.
  27. Tim
    Tim
    from KCMO
    Any more ridiculous and they’d ask you to stop eating beans haha
    good stuff man, I’m headed to the garage right now :)
    Six Ball, J.Ukrop, Outback and 2 others like this.
  28. Hitchhiker
    Hitchhiker
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Tonight, I got the LF brake ***embled with the new wheel cylinder, copper washer, and the temporary shoes. Everything went smoothly. As I was working with the door open, an older couple approached the garage. "Still working on it?" The man asked. "Yes," I whispered, placing my index finger in front of my mouth. "It's getting close, though."
    I spent the next few minutes talking—in hushed tones—with the man and his wife. They're neighbors who have come by before. He told me that his friends in high school had roadsters, outfitted with hot rodded V8s. "Mine has a 1948 Ford V8 in it," I said. "Wow!" he replied. "I learned to drive on a 1939 Ford. Stick shift." I watched his outstretched hand follow the shift pattern of an early Ford transmission.
    I learned that he was 81 years old. "I'll take you for a drive when this thing's up and running," I said. "Hopefully we'll see you cruising through the Mission!" his wife said. With that, they waved and were off into the night.
    Lately, I've been working to practice gra***ude. As I installed my wheel cylinder, I couldn't help but think about how grateful I am to be using three chrome bolts with three chrome lock washers on an old chrome backing plate. Rubber lines are wrapped in NOS cable cover from the 1950s, and the original 1932 Ford axle was dropped by a friend of mine on the opposite coast.
    I look down at my vintage rug that I rushed to buy 20 minutes after it was posted on Facebook Marketplace, and I admire the torque-tube headers that were hand-delivered on my birthday in 2022. Everything here has a story. I can't wait to tell many, many more of them when this thing is back on the road.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So, after I got the brake all ****oned up, I poured some fluid in the master cylinder just to see if I could find any immediate leaks. Other than some weeping on, you guessed it, the left front copper washer, the rest seemed to be holding up just fine for now. I loosened and re-tightened the LF hose, and I think it sealed it better. Yama is coming over on Friday so we can give bleeding the system another shot.
    That does it for tonight. We'll see how things look in the morning, but I think I'm going to hold off on master cylinder replacement if the current one isn't leaking. Tomorrow will be odds'n ends: maybe some painting, wiring, etc. More on that later!
