Rotten Datsun
Discussion in 'Off Topic Hot Rods & Customs' started by hillbilly4008, May 21, 2025.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Redneck mathematics shows the weight of the engine, trans, clip, and radiator should drop the suspension about 4"
    simplestone likes this.
  2. hillbilly4008
    hillbilly4008
    from Rome NY
    Wish there was more time in the day
  3. gene-koning
    gene-koning
    I have lots of hours building inner fenders on my truck. They are not pretty, but you can not see them under the fenders they are attached to unless you remove them and set them on the floor. Mine are completely removable from the fenders, with the fenders bolted in place. They do what they are suppose to do.
    I suggest you install everything you need to have installed before you concern your self with the inner fenders. Make it run and drive first! Then, after everything else is done, cardboard (beverage containers) will be your best friend to patch together the inner fenders. You can cut, tape, and staple a pattern together then transfer the refined cardboard pattern onto pieces of steel you can weld together, and hold in place with screws. The purpose of the inner fenders is to keep the engine compartment free from road trash. They are hidden under the body, pretty is not what is important, function is.
    Deutscher and TrailerTrashToo like this.
  4. hillbilly4008
    hillbilly4008
    from Rome NY
  5. hillbilly4008
    hillbilly4008
    from Rome NY
    Onto the spine.
    20251230_134917.jpg 20251230_134924.jpg 20251230_134940.jpg I will have to lengthen the torque arm 10 inches.
    Deutscher likes this.
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    Also obviously need to lengthen the prop shaft 10". Makes total sense because the trucks wheelbase is 10" longer than the miata.
    I lost the heater box and most of the duct work. The coils will need to be relocated from the back of the engine to the firewall. And the heater hoses on the engine need to be re routed, I think there is a coolant reroute upgrade kit available that may solve my issue there.
  7. hillbilly4008
    hillbilly4008
    from Rome NY
    Some more t******* and prettying up needs to be done in this area yet.
  8. hillbilly4008
    hillbilly4008
    from Rome NY
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    FINALLY STARTING TO LOOK LIKE SOMETHING!! I love this part when it makes it from my head to reality.
    20251230_145626.jpg 20251230_145641.jpg 20251230_145716.jpg 20251230_145752.jpg 20251230_145909.jpg
  10. hillbilly4008
    hillbilly4008
    from Rome NY
  11. gene-koning
    gene-koning
    Looking pretty good there. Bet its going to be a fun truck.
    TrailerTrashToo likes this.
  12. hillbilly4008
    hillbilly4008
    from Rome NY
    Been a while since I did anything.
    Back bone needs to be stretched exactly 10 5/8".
    I found this bent piece of aluminum laying around. The same thickness, and the bend radius is pretty close. I'll be able to make it work, but I have to do it in pieces. ****'ll be fine.
  13. hillbilly4008
    hillbilly4008
    from Rome NY
    Slow progress
    Going to skeletonize it to match and possibly buff it out
  14. hillbilly4008
    hillbilly4008
    from Rome NY
    Finally! Just waiting on clear coat to dry.
  15. hillbilly4008
    hillbilly4008
    from Rome NY
    Now onto this thing
    Deutscher and hotrodjack33 like this.
  16. gene-koning
    gene-koning
    The backbone looks good.
    If I remember correctly, you need to have a longer drive shaft, correct?
    It is not suggested trying to lengthen a drive shaft. Shortening them is something that can be done at home, making them longer needs the tube replaced with a longer tube. Splicing two tubes together can create a huge issue with balance at the rpm range a driveshaft can spin. There is also a limit to the amount of length a drive shaft tube can be, dependent on the diameter of the tube itself (if I remember correctly, the longest recommended length of a drive shaft tube under 4" in diameter is 65" long).
    The drive shaft you have already appears to be pretty long for its tube diameter, however pictures can distort the reality. How much longer does the driveshaft need to be?
  17. MAD MIKE
    MAD MIKE
    from 94577
    Fantastic!!!
    I'm guessing 10-5/8".
  18. hillbilly4008
    hillbilly4008
    from Rome NY
    Bingo! 10 5/8" longer.
    I will be cutting the ends off and sourcing some new DOM tubing. From my research a stock tube has a inner diameter of 2 1/4", with a wall thickness of .065. I won't know for certain till I cut it though.
  19. hillbilly4008
    hillbilly4008
    from Rome NY
    Internet says stock shaft measures 41 1/4". So I need to be at 51 7/8"
    Both ends are fixed.
  20. gene-koning
    gene-koning
    You should be good to go at that length.
    Have you ever shortened a drive shaft before? The procedure to just change the tube would be about the same as shortening a shaft x 2. Just make sure the ends are correctly oriented with each other, and both are in the tube straight. Balancing can be done with a couple of worm gear hose clamps at home.
  21. hillbilly4008
    hillbilly4008
    from Rome NY
    Yeah I've done a few shafts over the years. None ever had any noticeable vibrations yet.
    Those were all on jeeps with mud tires, not that I would notice anyways...
  22. gene-koning
    gene-koning
    I've done more then a few, I've never had a balance issue either (a few of them were on very quick drag cars), but there is a balancing process using hose clamps, if needed.
    hillbilly4008 likes this.
  23. hillbilly4008
    hillbilly4008
    from Rome NY
    Bouncing around a bit.
    I been wanting to do this 3rd brake light for a while.
    20260216_114041.jpg 20260216_114047.jpg 20260216_114124.jpg 20260216_115808.jpg 20260216_115937.jpg 20260216_120251.jpg 20260216_120257.jpg
    Little 15 minute job thats been on my mind. I will be replacing the guts of the light with new hardware and a LED bulb.
    Gene, you asked a while back for a Pic of the parking brake handle.
  24. SS327
    SS327
    So you set the brake and then spear yourself getting out of the truck?
  25. hillbilly4008
    hillbilly4008
    from Rome NY
    Sure hope not
    SS327 likes this.
  26. hillbilly4008
    hillbilly4008
    from Rome NY
    Sure looks like thats how it is. This is the first time I pulled the lever.
    Maybe when everything is hooked up it won't have as much throw?
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I feel better about myself now. :)
    SS327 likes this.
  28. hillbilly4008
    hillbilly4008
    from Rome NY
    Why? What'd you do?
  29. hillbilly4008
    hillbilly4008
    from Rome NY
    Fuel tank mockup.
    I'm trying to keep the filler neck in the stock location. Its pretty friggin close how I have it oriented. It does look like its going to be a bit higher than I want it to be though. I need to space the tank up a bit to get it off the torque arm. Its going to be VERY close. If im lucky I can get away with t******* a couple crossmembers under the truck bed.
  30. gene-koning
    gene-koning
    Gas tank going to clear the driveshaft as it moves up and down with the suspension?
