Featured Projects flathead 471 blower/supercharger
Discussion in 'Traditional Hot Rods' started by Ed95, Jan 22, 2026.
  1. patsurf
    patsurf
    very nice!
    Ed95 and Outback like this.
  2. 19Eddy30
    19Eddy30
    from VA
    @Ed95
    No affect on Boots .
    Mounting depends on intake ,
    Mounting bolts on inside allows for narrow mounting area , (intake surface)
    You drill a squared off pocket hole & use
    Typically a cap screw bolt or taper head bolt , or regular head bolt ,if using
    Regular head bolt you need enough room to get the socket over the head of the bolt.
    "" & have to be low enough so rotors do not hit "" studs or bolts .030-.040
    recess/ below in case ..
    Some flip case , there are a few ways to do , I feel all same amount of work.
    & look you want , & some times a certain way is only way you can do,
    Intake , or if adaptor needed for flat mouthing surface..
    Not necessary But mill almost required again not necessary...
    Also how much detail you wanting to do to case ?? Alot of material needed to be removed if you want bottom to flow like top rounded is case Looking Round
    Or Oval by eye ..
    study pictures below to get a I deal how each one is done Diffrent ,
    & all shown are Not the
    "" inside mounting ""
    The one $700 ins New cast F-H intake with 4 mounting ears , If you cut ears off , now witch way are you going to mount ?
    In side bolts
    Make windows in intake to access nuts or studs , Mill pockets ect.
    Then you have Option of 3:71,4:71
    V case mount , Not as I pretty but another option ....
    & done these kind of mod's need to look
    2& 3 steps some times more ahead !!
    Ed95 likes this.
  3. Ed95
    Ed95
    I can remove the material with a drill press?
  4. Ed95
    Ed95
    I see that makes sense! I like the pruned look better for sure and also like the HH falthead intake. The pop off valves are very nice to have
    Bandit Billy likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    @Ed95
    Not trying to discourage , when using a drill press with certain task you should use a beefy drill press , One that will Not flex , Drill center line & table ..
    The more accurate drilling will make
    Job easer & not get over stressful ..
    Back to drill press ,
    Average one not a big deal to drill,
    & Hope fully speed adjustable,
    Drilling 1 inch or less , but lets say 3 ish inch or more & there flex in table or drill
    The hole will not be straight ..
    Also clamping , big enough table & sometime require unique thinking to hold ..
    Me some time's I give a little wiggle room in parts so I can make sure if needed to square things up .
    You are more likely going to need a ***ortment of different carbite's
    One's for cutting Aluminum fast
    Then fine ones for finishing ,
    Different shapes & sizes ..
    Since seem your first time ,
    Set back study & look, maybe notes
    & sketch draw.
    Outback and Ed95 like this.
  6. Fordors
    Fordors
    In a word, NO!
    Too many chances for injury, don’t even attempt that.
    Ed95 likes this.
  7. DDDenny
    My comment was referring to getting the holes drilled and tapped straight.
  8. Ed95
    Ed95
    LOL I see. I have a drill press. not worried about drilling the holes for studs now that I understand how that works...what's the best way to go about pruning the case? removing all that material seems like it will be fun!
  9. Ed95
    Ed95
    definitely my first time! But I want to do it. I want to do most if not all of it myself. I understand there may be some tasks I am just not gonna be able to do.
  10. Bandit Billy
    Bandit Billy
    I used bolts on my pruned 471 but I wish I had done the studs in retrospect. The reason is it is difficult to thread bolts in from the bottom, in a confined space, with fat fingers, while trying to align the blower and gasket. I ended up gluing the gasket to the blower then placing it and threading the bolts. Mike at H&H recommended not using grade 8 bolts, but said it likely wouldn't matter if there was a catastrophic event.
    If mine ever has to come back apart I'll be using studs when I reinstall.
    3blapcam likes this.
  11. Flatrod17
    Flatrod17
    Found some old pics of the first one I did.
    akoutlaw and Outback like this.
  12. Flatrod17
    Flatrod17
    Billy, even with the studs its tough to get to the washers and nuts on. My fat fingers, water manifolds in the way, it tough! I pretty much decided I would bolt the blower to the manifold then down to the block, but if have to take it apart I will have to drain the water remove the water manifolds then the intake or blower. Pruned cases look great but do create other problems.
    Outback and Bandit Billy like this.
  13. 19Eddy30
    19Eddy30
    from VA
    @Flatrod17
    Nice divider wheel turntable,
    Like to have one that "BIG"":cool:
  14. Bandit Billy
    Bandit Billy
    The cost of cool! I have had mine off twice, it wasn't a nightmare, but it required patience and I had forgot to stock up on that.
  15. Yeah, I'd love to have that rotary table! ;)
    Outback likes this.
  16. Flatrod17
    Flatrod17
    It was part of a Enco package I bought over 30 years ago. I would hate to buy one that size today!
    Outback likes this.
  17. roseville carl
    roseville carl
    where there is a will there is a way. 4-71 with homemade plenum on top of 2x4 manifold with homemade end plate and drive and idler bracket
    blower idler 002.jpg Blower Idler no 2 mount001.jpg blower mani 9 14 002.jpg blower mani 9 14 003.jpg DSC02822.JPG DSC02840.jpg ImageUploadedByH_A_M_B_1417583004_290955.jpg
  18. wheeltramp brian
    wheeltramp brian
    Sweet! BB are my initials
    Bandit Billy and Outback like this.
  19. 3blapcam
    3blapcam
    I love the simplicity of a bolt-on blower adapter like that! The extra height it provides probably helps fit things in there, too!
    3blap.
  20. Bandit Billy
    Bandit Billy
    Hmm, so are mine!
    Outback likes this.
