Technical HOG RINGS
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Feb 6, 2026.
  1. Bandit Billy
    Bandit Billy
    No not the one young people and our porcine bacon-buddies have hanging from their nostrils, I need to order a bag of hog rings to put the upholstery back on my truck seat since I destroyed them removing the lot. I see 3/8", 1/2" and 3/4" online, no idea what that measurement refers to. What is typical for ringing the upholstery to the seat frame? Time is of the essence, I need to add them to the shopping cart.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    This is what I used on the 56 when I replaced the seat foam
  3. dana barlow
    dana barlow
    from Miami Fla.
  4. K13
    K13
    Lots of info online. The most commonly used seems to be 3/4"
    Sharpone, Sporty45 and Bandit Billy like this.
  5. 51 mercules
    51 mercules
    3/4 were the ones we used when I took an upholstery cl***.
  6. ClayMart
    ClayMart
    If you really need them in a hurry you might find some in a local GM Dealer's parts department. The trick may be finding someone who knows how to access the GM Standard Parts catalog. Tell them they should be somewhere in Group 8.900.
    Driver50x, bchctybob, dirt t and 3 others like this.
  7. Bandit Billy
    Bandit Billy
    So the measurement is across the teeth or the spine? Is that a 1/2" ring?
    I found this on Amazon. Looks like the measurement is inside the back so your ring pictured above is 3/4"?
    And there are straight backs and arched backed for some reason. I am guessing from the responses the 3/4" straight back, stainless steel is the way to go?
    I am also buying my daughter a foam knife. This look decent?
    bchctybob likes this.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    Part #6616858
    Old part #4876466
  9. rusty valley
    rusty valley
    I used to go to an upholstery guy and he'd give me a coffee cup full from his 50# box
    Sharpone and partsdawg like this.
  10. 325w
    325w
    Upholstery supply
  11. 51 mercules
    51 mercules
  12. jaracer
    jaracer
  13. Bandit Billy
    Bandit Billy
    deathrowdave, bchctybob and 5window like this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    yup mine measures 1/2 at the opening and 3/4 inside at the back
  15. Bandit Billy
    Bandit Billy
    Order placed. Thanks gents
  16. squirrel
    Feed store has them too, but they're on the large side....
    alanp561, bchctybob, Sharpone and 3 others like this.
  17. theHIGHLANDER
    theHIGHLANDER
    I wish you were closer. I'm down to my last 8,000 or so...:eek:
    Seriously, if you end up hog tied lemme know. I'll throw a **** load in a USPS envelope for ya.
  18. Royalshifter
    Royalshifter
    Moderator
    Home Depot in the chain link fence area.
    They even have the pliers.
  19. Bandit Billy
    Bandit Billy
    I aint close to anything of note. I got em ordered and my daughter will get use out them as I am trying to make her an auto upholsterer. She is learning.
    She is making snowboarding mittens (gauntlets?). She was at a bookstore the other day and bought a book on muscle car interiors. She sent me this picture and asked if I recognized the stich pattern, I answered definitely Mopar. She said 66 Charger. She didn't know people could tell makes from interior patterns. I think she will be very good at auto interior.
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    In the '70s I worked in FoMoCo's Trim and Seating Engineering offices in Dearborn. The Trim Shop used mainly 3/4" straght backed hog rings. The trimmers had a special tool, like a vice grip like pliers with a groove in them that gripped the hog ring and the open end faced away from your hand grip. Squeezing the tool collapsed the ring around the anchoring wire(s).
    Billy, if you have such a tool the job will be easier. I suspect the arched back rings are useful of you do not have the appropriate tool and are designed to collapse more easily using regular pliers.
    bchctybob, Bandit Billy and Sharpone like this.
  21. bobbytnm
    bobbytnm
    ^^^^in a pinch you can take a set of cheapo pliers, clamp them in a vice with the jaws closed and drill a hole down from the end through the jaws to give you the little groove.
    Not quite as good as the ready made hog ring pliers but a lot better than trying to use pliers with no groove in them.
    Luckily, most places that sell the hog rings have hog ring pliers as well
    Good luck with it
  22. Onemansjunk
    Onemansjunk
    from Modesto,CA
    8A000297-8F81-4B06-85C7-C444FEC86397.jpeg 55F444AE-8AFE-4209-9360-D3C9A9F95B67.jpeg Be careful not to order hundreds, if not thousands of these - *****- less- units. Notice these have no points on them. You’ll never get these to poke through, these pos are worthless for upholstery. Fence work, maybe?
    The 39 guy, vtx1800, alanp561 and 7 others like this.
  23. bobbytnm
    bobbytnm
    I think you're right, no pointy ends are for fencing, pointy ends are for upholstery
    bchctybob and Bandit Billy like this.
  24. Happydaze
    Happydaze
    Save the installer of the hog rings a ton of grief and get the proper hog ring pliers. They essentially lock on to the ring making installation a snap. The installer is gripping, pulling and stretching material so has enough to contend with at the time!
    Chris
  25. hepme
    hepme
    HEH! couldn't help it: I just thought of a new business, nose rings installed quickly, all ss. Guarantee nothing like it. Tell partner to bring leash.
  26. Rocco611
    Rocco611
    from Madera Ca.
    They can also be purchased at most any farm supply. I usually use 3/4 pig size rings.
  27. 51 mercules
    51 mercules
    You're right! I just posted that pic for reference on how to measure them! Probably should of used this pic instead. 3-4_hog_ring_draft_measurements.jpg
    The 39 guy, bchctybob and 51504bat like this.
  28. 51 mercules
    51 mercules
    The knife is for styrofoam. Not sure if it will work for upholstery foam? Cheap alternative is an electric turkey carving knife. Found them cheap at thrift stores. Can sand and shape foam with a 1/4 inch angled die grinder after your done cutting it. Even used a band saw to cut thicker foam. The cheap Harbor Freight siphon feed spray gun is good for shooting glue too!
    51504bat, Bandit Billy and bchctybob like this.
  29. bchctybob
    bchctybob
    I’m disappointed, I was hoping for a picture thread with tattoos, pink and blue hair and nose rings….
    I inherited a big box o rings and the pliers from my Dad, but I guess the talent skips a generation.
