Projects 1962 Biscayne Jr Stocker for the Street Build
Discussion in 'Traditional Hot Rods' started by Stock Racer, Mar 15, 2022.
  1. Stock Racer
    Stock Racer
    I sanded the floor and chipped out what was left of the old, cracked seam sealer and resealed it. Then I got some primer on the bare metal.
    AHotRod, tr_rodder, swade41 and 11 others like this.
  2. Stock Racer
    Stock Racer
    I got the floor painted today. Here is a before and after.
    My compressor is in one garage and the car is in another so I can't spray when it's this cold. This is the paint I used with a 4" roller. The nap worked better than the foam roller which just slid over the paint.
    pivir123, AHotRod, tr_rodder and 18 others like this.
  3. Dave G in Gansevoort
    from Upstate NY
    Wow! That paint goes on really thick! Look how it filled in those rust holes! LOL
  4. DDDenny
    It's magic!
  5. saltflats
    saltflats
    from Missouri
    I know the pain that was to do. Great job.
  6. Grumpy ole A
    Grumpy ole A
    Wow that was a Flintstone floor board. Nice repair
    Sharpone, Stock Racer and saltflats like this.
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
  8. Stock Racer
    Stock Racer
    Yea, my back is killing me, lol.
    Thanks guys!
    saltflats, 427 sleeper and Sharpone like this.
  9. Sharpone
    Sharpone
    Nice very nice
    Replaced the water soluble iron with some new stuff.
    Dan
    427 sleeper and Stock Racer like this.
  10. Stock Racer
    Stock Racer
    If only it were that easy, lol.
  11. Stock Racer
    Stock Racer
    Thanks!
  12. Stock Racer
    Stock Racer
    Now that I have the weight of the engine to load the suspension, I decided to check things out. Right upper ball joint was wasted. Since it's easier to change before the front end is on, here we go. This will give me an opportunity to clean and paint an area I couldn't get to before (just when I thought I was done with that, lol).
    I used Proforged 1/2" longer ball joints which help the geometry and I cut about half off of the rubber bumpers. Those mods will give me maximum suspension travel.
    Mission accomplished.
    enloe, AHotRod, guthriesmith and 7 others like this.
  13. Sharpone
    Sharpone
    Looking good
    Dan
    Stock Racer likes this.
  14. Poverty cap
    Poverty cap
    What a save, you have rescued that 62. Very Impressive.
    Stock Racer and Sharpone like this.
  15. Stock Racer
    Stock Racer
    Thanks guys!
    Sharpone likes this.
  16. Stock Racer
    Stock Racer
    Got a few more things done. Installed the floor drains, cleaned up and installed the brake pedal and pushrod, Modified the left rear brake line to clear the second upper control arm, and hung the starter and headers.
  17. Stock Racer
    Stock Racer
    Moved on to the Steering Column. A while back I cut everything off of it and Duraglased the holes to make a fake floor shift column. Both bearings were shot, the turn signal switch was missing, the grease bag on the u-joint was torn, and it was ****py looking.
    Gave it a quick cleanup and a spray bomb job and replaced the bearings and grease bag. The guys on the X-frame site said the repop T/S Switches were problematic so I sourced an NOS one from the auction site. When I get the other interior pieces ready to paint, I'll spray the shift bowls.
    enloe, pivir123, AHotRod and 12 others like this.
  18. Stock Racer
    Stock Racer
    Plugging away. Gl*** beading the rusty garnish moldings and dash pieces to prepare them for paint.
  19. Super/Stock Poncho
    Super/Stock Poncho
    from Missouri
    I’ve really been enjoying the build thread.
    You’re doing the 62 justice!
    Keep up the good work !
    enloe, lumpy 63, Stock Racer and 2 others like this.
  20. Stock Racer
    Stock Racer
    Thanks! Where can I see a full picture of that avatar?
  21. AHotRod
    AHotRod
    keep moving, it's time to get it finished up.
    Sharpone and Stock Racer like this.
  22. Taboo56Chevy
    Taboo56Chevy
    looking good, you are gonna have that car done by the time I get the 409 running in our 61, lol.
    Tickety Boo, Stock Racer and Sharpone like this.
  23. Stock Racer
    Stock Racer
    Man, I'm trying. My goal is to get it running and driving by the end of August.
    Thanks! I don't know about that. Checked out your thread, cool that you are doing it with your Grandpa.
  24. Super/Stock Poncho
    Super/Stock Poncho
    from Missouri
    slowmotion, treb11, enloe and 13 others like this.
  25. Stock Racer
    Stock Racer
  26. enloe
    enloe
    from east , tn.
  27. Stock Racer
    Stock Racer
    I tried an experiment with something that I read about here on the HAMB, Patina paint restoration. I started with CLR for a few minutes, washed it with Comet in Dawn dish soap, rubbed in some Meguire's #7 and left it over night, then I buffed it with rubbing compound. As you can see, it definitely brought back a lot of the blue so I'm calling it a victory. The car is going to get painted but for now she will look way better cleaned up a bit.
    Chucky, AHotRod, Chris L. and 10 others like this.
  28. Stock Racer
    Stock Racer
    Ok, enough screwing around with the Meguiars #7, time to get back to work.
    Finished gl*** beading the garnish. A few pieces had some pitting so I shot it with Eastwood high build. Pleasantly surprised, I sprayed it heavy enough to run but it laid down nice and sanded great.
    I picked up these arm rests on-line. One was painted black, gl*** beaded it and it came out nice. Sanded the other one.
    Sanded the coating off the roll bar.
    Sanded the dash.
    Tore down the instrument cluster and sanded that down.
    I'm ready to paint all this stuff, just waiting for more cooperative weather.
  29. saltflats
    saltflats
    from Missouri
    Nice. Is your dash one of the aluminum one's?
    I pulled the dash out of my 61 and was real surprised how heavy it was. That is something I need to look into on the Shaker to get that car on a diet.
  30. Stock Racer
    Stock Racer
    Yep, it's aluminum.
    Tickety Boo, Sharpone and saltflats like this.
