Projects LA HOT RODS Get's A 37 Pontiac Gasser Build
Discussion in 'The Hokey Ass Message Board' started by saltflats, Dec 24, 2022.
  1. 427 sleeper
    427 sleeper
    What's wrong with a chopped top? Didn't Ohio George's Willys have one after he put the Cammer in it?
  2. saltflats
    saltflats
    from Missouri
    What I have read in the rules say no body modifications.
    Not that I will be running in the SEGA but if a chopped top it is under their decision if it would p***.
  3. wrenchbender
    wrenchbender
    James your car may be chopped but it’s not a bonneville chop more of a beauty chop and yes there were gas cl*** cars that had chopped tops Ohio George is one of them the grist brothers ran a chopped 40 Willy’s coupe however I think it makes a difference on what time frame you are talking about originally they had to be liscened insured and street drivable cars but as time went on the rules changed a lot in today’s world it won’t matter except maybe southeast g***ers and unless you are competing for money it doesn’t matter there are about 9 people who would actually care in the world at the events you and I attend regularly it won’t matter that your top is chopped or your motor is back 2” to much
  4. 427 sleeper
    427 sleeper
    James, the chop on your car is SOOOOO SUBTLE that most people won't even realize that it's chopped. I'd stick with the G***er theme... It just fit's! JMO
  5. saltflats
    saltflats
    from Missouri
    Still testing the water. But this is really growing on me.
    Make some louvered panels to fill in the rest of the sides.
  6. fordor
    fordor
    from Finland
    I realy like it.:)
    porkshop, osage orange and saltflats like this.
  7. saltflats
    saltflats
    from Missouri
    Had to add a little bling.
  8. bchctybob
    bchctybob
    Personally, I think you were on the right track before, just needed a slight drop in the axle and a little more engine set back.
  9. saltflats
    saltflats
    from Missouri
    Good thing is I haven't done anything that would need to be undone at this point playing with this different idea. ;)
  10. saltflats
    saltflats
    from Missouri
    Little more bling while I keep the gears turning.
  11. saltflats
    saltflats
    from Missouri
    And this for motivation.
  12. saltflats
    saltflats
    from Missouri
    Need to think on the side panel.
  13. saltflats
    saltflats
    from Missouri
    Little test cardboard panel.
  14. Needs a pair of Doug Thorley headers. Hehe.
    porkshop, Okie Pete and saltflats like this.
  15. choptop40
    choptop40
    Full fenders , my preference......I know its a task....one piece tilt fibergl*** ..Itchy *** endeavor....
  16. 1971BB427
    1971BB427
    from Oregon
    Really nice work so far! I like the stance! I'd personally not make the side panels as it's losing the g***er appearance with them. I didn't even use the stock side panels on my '39 Chev g***er as I prefer the open sides.
    I also toss those wimpy front shackles most springs and axle kits come with and make my own thicker, and sturdier shackles on all the straight axle swaps I do.
    Always amazed me how much different Pontiac and Buick frames were compared to the same years on Chevys!
  17. saltflats
    saltflats
    from Missouri
    One thing that you guys need to remember is I'm building a race car that will never see street use.
  18. I presume your intent is to build Geronimo a few seconds faster than Saltshaker? Seems like you're headed in the right direction.
    Tickety Boo, saltflats and porkshop like this.
  19. 1971BB427
    1971BB427
    from Oregon
    Even more reason to leave the side panels off to help dissipate heat under the hood.
  20. saltflats
    saltflats
    from Missouri
    Running alcohol for fuel shouldn't be much of a heating problem.
  21. saltflats
    saltflats
    from Missouri
    Dropped axle showed up. Need to order some more bits but this is starting to have the look in my head.
  22. saltflats
    saltflats
    from Missouri
    I have to say I'm impressed with the quality of this Speedway axle. I read that the WAC is the one to get and not knocking them at all. Just thought this one looks well made. Guess track time will be the true answer.
    porkshop, SS327, bchctybob and 6 others like this.
  23. cfmvw
    cfmvw
    I like it! With those side panels, it looks great as a half-fendered hotrod! Especially if you were to add a pair of Guide 632 headlights mounted low on the framerails.
  24. SS327
    SS327
    It needs front fenders, is it going to get them?
    porkshop likes this.
  25. atch
    atch
    Not my car. Not my decision.
    If your primary objective is to go fast remember that the fenders will slow it down.
    That said, perhaps you (or someone) can photoshop one color onto the whole shootin' match to see how it looks. I'm sure that you've seen the photoshop thread on here that's probably a thousand pages long now where folks do just that for other people. I'm sure that they would do it for you. OR; rattle can the cardboard black to see how it looks. The cardboard sort of messes up the whole aesthetic; at least for my pea brain..
    Maybe you'll get a better perspective after seeing it all one color.
    Note: if speed were not the primary consideration, I'd recommend putting the fenders back on.
  26. saltflats
    saltflats
    from Missouri
    No front fenders. Going the altered direction.
  27. atch
    atch
    Good choice.
    Now get that thing done and go really fast.
  28. saltflats
    saltflats
    from Missouri
    Long way to go on this car Mike.
    With any luck the body will be off the frame so I can get it sand blasted this spring.
  29. atch
    atch
    Well; ya know if you need some old/weak grunt labor you can call.
    porkshop, saltflats and Tickety Boo like this.
  30. But you wanna play soon, don't you, James? I got the feeling that the vision you see is so tantalizing that it's going to have your attention for a while.
    porkshop and saltflats like this.
