Oh Man - More Visions The Sickness Continues
Discussion in 'Off Topic Hot Rods & Customs' started by corncobcoupe, Jan 11, 2026.
  1. Sharpone
    Sharpone
    Excellent
    Dan
    porkshop likes this.
  2. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Thanks fella’s.
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Ok ……
    Off the jack stands and back on the ground.
    Have 2 studs need to change. One funky threads / the other the stud is turning in the hub.
    All the others thread up / torque fine.
    Old car, figures .
    Started up / runs good / no smoke.
    Learning more things about the car.
    I’m leaning towards new tank / sending unit and line blow out as it idles fine but as soon as put in drive or reverse it moves short distance, then dies. Vacuum module ?
    Gas gage doesn’t work and had two gallons to put in only to find out it was a full tank.
    So no telling how old the gas is.
    So, new tank/ fuel pump/ guage sender.
    Ahhhh the love of old cars.
    Enjoy the updated pics……
    IMG_5368.jpeg ge IMG_5370.jpeg IMG_5369.jpeg IMG_5367.jpeg IMG_5364.jpeg IMG_5365.jpeg
    wicarnut, Jrs50, porkshop and 8 others like this.
  4. guthriesmith
    guthriesmith
    Way cooler with the Cragars! :cool:
    porkshop and Sharpone like this.
  5. Sharpone
    Sharpone
    WOW cleaned up real nice.
    Dan
    wicarnut and porkshop like this.
  6. Phillips
    Phillips
    Holy **** that’s so cool it makes my chest hurt.
    porkshop, Sharpone and guthriesmith like this.
  7. Phillips
    Phillips
    It’s the life size hot wheels ”custom barracuda”
  8. RodStRace
    RodStRace
    No headlight buckets or covers, auto trans is linkage only, HVAC is cable and wipers are electric.
    Vacuum should be confined to dist. 67 didn't have EVAP or TAC. No power brakes either.
    Will it stay running in gear not moving? I'd next support the rear axle off the ground and try it again.
    Diagnosis unclear, more testing needed.
  9. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Wish I got the residuals for every Hot Wheels Barracuda sold. ;)
    porkshop, Sharpone and Phillips like this.
  10. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Don't know, just pulled it out of the garage for the first time today.
    Idle was high so adjusted it to proper idle, shifted into drive to get it out of the garage to take a few pics and it died a short time rolling out. Then tried again, same thing.
    Shut off, took some pics and again shifted in reverse to back into the garage and it died after a short roll back.
    Started it up and finished rolling it back in.
    On a positive note - it did start and idle fine - no exhaust smoke etc, sounded good and did at idle give it some gas up and down and it responded.
    NOTE, I did put a new inline gas filter to the carb for the obvious to see if filter clogged etc.
    I'm just in the infancy of the quirks.
    I'll tinker in the next day or two, but will try as suggested start it and keep my foot on the brake, put it in gear with my foot still on the brake and see if it stays running.
    Thanks
  11. SS327
    SS327
    Those tires and wheels really helped transform the car. It doesn’t look the same.
  12. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Thanks.
    The vision.......
  13. gene-koning
    gene-koning
    When you backed the car out of the garage, was the motor up to operating temp, or was it still cold?
    When you said it was on fast idle, and you slowed it down, then backed it out and it died, it almost sounds to me like the motor was still cold, and probably still needed that fast idle you removed. The choke adjustments are critical for cold motor operation on that era Mopar.
    Sounds more like a carb out of adjustment, choke not set properly, an accelerator pump not functioning correctly, or simply a cold motor stumble then a fuel problem, but old gas probably is not helping either.
  14. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I gave it time to warm up. The idle was high for some time, and it seemed to come down some but still too high.
    It has an Holley 600 on it now. I turned the Idle screw back a half turn and that brought it back to 750/800 rpm’s which about right.
    After pics, I backed it into the garage and called it a day.
    Will tinker more with it today / tomorrow.
    Thanks.
    porkshop, SS327, Sharpone and 2 others like this.
  15. That’s coming along nicely!
    Sharpone likes this.
  16. slowmotion
    slowmotion
    Lookin' great Cob! As been said many times, wheels, tires, stance! You'll get the bugs sorted out promptly. They're just the elements an extended nap telling you what it needs. Nice job so far, that's gonna be sweet little cruiser!
    SS327 and Sharpone like this.
  17. Sharpone
    Sharpone
    One thing to look at is the kickdown linkage to make sure it’s adjusted correctly. A lot of people have the linkage set up wrong and fry the transmission. Not sure if it’s causing your problem but something to check.
    Hopefully just bad gas.
    A video from 318 Will Run
    I like his stuff he’s good.
    Dan
  18. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Gene,
    Well, tinkered with it today.
    Let it warm up.
    Had to return the idle one quarter turn back to the right to get it idle fine. 750/800.
    Sat in Park and idled fine.
    Put it in gear and held the brake. Will not stay running in gear with my foot on the brake. It died so I restated it, gave it a little gas and rolled it down the driveway and up the street ( slight uphill in case it died and had to roll it back down). I didn’t go fast enough for it to shift. I was just happy to get it moving up the road.
    Made it to the top and started to turn to back up and turn back. Put in reverse and rolled back about 5 feet and died. Restarted it and turned enough forward to head back down the hill.
    Other new noises - either brakes are hanging up and tires rubbing on slight turning the inside rail. I don’t know. I have to get underneath and recheck the tires. I’m only running 15” x 6” wide in front so it should be fine.
    As far as the brakes, add that to the list to recheck. I did notice when I was putting on the new Cragar’s / tires that the front p***enger wheel/tire rolls freely whereas the drivers wheel/tire seems to be a bit tight rolling around. That being said this car has not been driven in quite some time. It has brand new brakes on it so I’m guessing maybe the drums have rust or crusty’s or they need adjusting and that was the sound that I heard but I had my foot on the brakes.
    I was able to drive it back down the hill into the garage. I didn’t drive it fast enough to do any shifting, but I can tell you that just in first gear I didn’t give it much gas, enough to just get air rolling and it definitely wanted to takeoff.
    Dan, in answer to your question, guess what ?
    The kick down Rod is not hooked up to the carburetor, so I have to climb underneath to make sure that the rod is connected to the Kick down Rod spring tab and get it adjusted to the carb.
    There is a brand new Holley 600 carb that they forgot to hook up the kick down Rod.
    So at least today took a baby step forward.
    Definitely a list of quirks to look into.
    I appreciate your suggestions, fellas.
    Will update as I go forward.
    Thanks,
    Cob
  19. gene-koning
    gene-koning
    Hopefully it wasn't driven much without the kick down connected. I have seen good transmissions killed in as little as 50 - 100 miles without the linkage connected.
    As far as the brakes are concerned, it might be a good idea to add all 3 of the brake hoses to the parts replacement list, might not be a bad idea to rebuild all the wheel cylinders as well. Years sitting tend to kill that kind of stuff.
  20. SS327
    SS327
    Idle speed should be set with the transmission in gear, parking brake set and wheels blocked if your by yourself.
  21. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    The car sat for 8 years and a new Holley 600 CFM Carb was put on it when it was fired back up.
    I think the Kick Down was not hooked up.
    It went on a trailer / Off a trailer / On a trailer / Off a trailer and up 600 ft up the street and 600 gt back/at maybe 5/10 mph.
    I don’t think it hasn’t had any miles on it.
    (Hope anyway)
    I’m going to hook up the kick down this week.
    I’ll pull the front wheels again to check the brakes.
    Hey Cragar’s and Gold Lines look great though huh ? :)
    Project in progress…..
  22. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I play it safe, thanks.
    RodStRace, porkshop and Sharpone like this.
  23. gene-koning
    gene-koning
    The Cragars look good, I was surprised you found them in the 15" size wheels. Twenty years ago, 14" mags in that bolt pattern were hard to come by, 15" were pretty much non existent. I've seen red stripped sidewalls and they look pretty good on some car, those yellow sidewall stripes are going to have to grow on me. Its not my car, as long as you like them its cool.
  24. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Cragar brought back the 15’s.
    I’ve had the Gold Lines for a little bit.
    Pinner striped tires originally they came out in 66/ 67/68 and mostly seen on Corvettes , Chevelle’s/ Camaros.
    Pin Strip Tires were a thing on Cragar’s back in the late 60’s so I figured I had them / use them.
    Red Lines were most common but I’m more uncommon with Odd Duck visions.
    They’re not for everybody, I do my own thing.
    wicarnut, RodStRace, porkshop and 5 others like this.
  25. Sharpone
    Sharpone
    How’s it going?
    Dan
  26. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Cragars and Gold Lines are on but have to pull them back off and adjust the new drum brakes that were on it when I bought it. Right front noise turning right as well to pin point.
    Have the power steering pump rebuild kit to pull / install and put back on.
    Woops, I need to order the ps hoses.
    Started power compounding the paint.
    Good 10 footer but a lot of scratches not able to m***age’ out....yet.
    With out getting out of hand, this won’t be a show car, but decent driver, the thought entered my head to ( maybe me ) or have it D/A’d and re-spray it. I’M NOT going to do a bunch of body work or does it need to have a bunch of body work done. It’s a pretty straight old car with good gaps. Someone did a decent job on it years back.
    The car is straight, just various scratches along the way, that aren’t buffing out as well as I’d like.....yet.
    So, might do a D/A scuff and re- spray may pull it up a tad. Not decided yet.
    My son wants to come down from Minnesota for Goodguy's July 4th big show at the Iowa State Fairgrounds
    ( 5000 car show) which I’m looking forward to Father / Son time. I want to have a car for him to drive for the weekend show is the plan.
    So, taking steps.
    porkshop, wicarnut, SS327 and 3 others like this.
  27. Looking good with those Cragars on there.
    Now it is my favorite 2 tone color. Black and chrome!!!
  28. gene-koning
    gene-koning
    Minor scratches adds character. It lets other people know its a real car, and makes it a lot more fun to drive. You don't have to worry about that first scratch or paint chip.
    Show cars are for show and tell. Cars with character are for driving and enjoying. I like driving and enjoying much better then show and tell.
  29. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Thanks !
    Seems looking at the shows now we’ve gotten stuck in these 18,20,22,24 “ custom billet wheels with rubber band tires.
    Bringing original chrome mags back seems guys are taking notice. Cragar S/S’s in particular.
    Originals …. Yea.
  30. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    It’s definitely not a show car Gene.
    Just putting together a nice driver.
    I’m in the process of cl***ifying how many minor and major scratches to make that determination of level of additional work needed
