Technical Tad disappointed on what I found on my new 39
Discussion in 'The Hokey Ass Message Board' started by 1942g506, Feb 10, 2026.
  1. 1942g506
    1942g506
    I took the windshield out of my new 39 tonight which is a super solid car to find this rot. I wanted your thoughts on cutting it out to replace? How bad does this hurt the car in the long run? Thanks
    dana barlow and chryslerfan55 like this.
  2. Tim
    Tim
    from KCMO
    Looks like it’s the back of the dash? It’s not real structural but if you took the dash out it would be easy enough to fix on the bench.
  3. Wish that’s the worst rust I ever had to fix
    57Fury440, lostn51, Stogy and 18 others like this.
  4. 1942g506
    1942g506
    I don’t think the dash comes out in a 39? Like it does in the 41? Could be wrong
    Stogy likes this.
  5. Tim
    Tim
    from KCMO
    It does come out. Pretty much the same way. Bolts along the top, probably a 90 deg tab on the ends. Steering column. Etc
    seb fontana, Stogy and lothiandon1940 like this.
  6. ronzmtrwrx
    ronzmtrwrx
  7. henry29
    henry29
    I f that's the worst rust on it you pretty much hit the lottery for a 1939. That's a very easy fix for most of us.
    57Fury440, Stogy, Rickybop and 2 others like this.
  8. ronzmtrwrx
    ronzmtrwrx
    I know this is not The Ford Barn, but still yet, here when someone says 39 it’s pretty much ***umed that they are talking about a 39 Ford. If you are talking about a 39 Ford, then the dash absolutely unbolts out of it. I’m not sure about 39 something elses.
  9. NoelC
    NoelC
    Not one for taking pictures are you?
    Not to burst your bubble, but usually that kind of rust doesn't come with super solid. Cutting it out for a guy with some experience will still be work, don't expect a 5 minute tack job to solve it. Does it hurt the car, not if done right it shouldn't.
    More pictures better the opinions.
    lothiandon1940 and rusty valley like this.
  10. 1942g506
    1942g506
  11. 05snopro440
    05snopro440
    Car? Truck?
  12. 1942g506
    1942g506
    1939 Chevy 2 door sedan
    down-the-road likes this.
  13. Squablow
    Squablow
    Does it need to be cut out and welded up? Absolutely. Does it hurt the car in the long run? Not a bit, as long as the repair is done nicely. Minor repair. Probably a bit easier if the dash can be unbolted but it doesn't need to come out to weld that up, if the dash was welded in, you can work with that in place.
    Stogy likes this.
  14. lothiandon1940
    lothiandon1940
  15. lothiandon1940
    lothiandon1940
    It's a simple matter of hitting the "full image" ****on to avoid thumbnails.:rolleyes:
    Stogy, Moriarity, ronzmtrwrx and 2 others like this.
  16. lothiandon1940
    lothiandon1940
    @1942g506......You might want to consider putting your general area in your profile, at least your state, as there could be fellow HAMBers nearby that would be willing to lend a hand or some expertise. Just sayin'.
    Stogy, bchctybob, BJR and 5 others like this.
  17. oldolds
    oldolds
    I think the dash is welded in on a 39 Chevy. I will go against the grain a bit. That is inside the car. I would grind that to clean metal, and use a fiber gl*** reinforced putty on it (something like Tiger Hair or Mar gl*** if those names still exist). That will last for years in that area. That way you will have no heat to mess up the paint outside the car.
    Especially if that is the only thing you have to do to the car.
    If the welder is out for more repair and you are painting the whole car then weld it up.
    spudshaft likes this.
  18. CSPIDY
    CSPIDY
    I agree with the fibergl***, like welding if done correctly will last.
    lothiandon1940 likes this.
  19. 19Fordy
    19Fordy
    Wonder if JB Weld could be used?
  20. Cut out
    Make a new flange
    Weld it in
    done
    57Fury440, Dak Rat, lostn51 and 5 others like this.
  21. alchemy
    alchemy
    If you are going through the trouble of cleaning the rust from everything (sandblasting), then also do the effort to weld in a new piece. If you are half-***ing it, then just slop some goo on top and think it’s fine.
  22. CSPIDY
    CSPIDY
    Not everyone is a welder, many people don’t own a welder.
    lothiandon1940 and Blues4U like this.
  23. Everyone in a car hobby should own a welder
    Unless there’s a health reason
    vtx1800, 05snopro440 and lostn51 like this.
  24. gene-koning
    gene-koning
    I would be far more concerned about what looks like pin holes on the outside (left of the gl*** channel in the magnified picture) rather then the area behind the window rubber. The holes (if they are holes as they appear to me) on the outside will allow water to enter the car body and sit on the floor. If there is carpet, the carpet will absorb the water and begin the floor rot process. In a worst case situation, you may feel water dripping on your feet or legs in a rain storm.
    The damaged area on the inside of the gl*** rubber (the right side of the picture everyone else is seeing) will cause the same issues, but will be a much slower process. Usually the water won't get past the rubber until the vehicle is in heavy rain, depending on how well the rubber seals against the body. The rubber doesn't often seal as well as most think it does.
    Stogy likes this.
  25. 37slantback
    37slantback
    So, have you looked at the front floor? Just curious if this is the only area rusted.
  26. K13
    K13
    I sell the "goo" for a living and I wouldn't use it to fix something like that. As Anthony said if you are working on old cars you need a welder.
    57Fury440 and 05snopro440 like this.
  27. NoelC
    NoelC
    Half ***ed.
    -done with little effort or care; incompetent or inadequate.
    Sounds harsh. I think he surp***ed that by taking the windshield out. What gets done now to fix it, that's an equation of skills + equipment / over ambition divided by time. I think that's the formula?
    And as a welder, I'll call BS to you needing one to fix that or work on cars. Handy, yes, necessary, not always.
    Did we not see in a frame post where welding caused a problem? To be clear, as in crystal, it's my opinion the choice of any repair should be intent and purpose. His might be cheap and good not good and cost me what I can't afford or know to operate to reach someone elses high standard.
    Besides, what kind of welder? Good old fashion Oxyacetylene? GMAW or FCAW. GTAW maybe? How about one of those low amp Sears 1/16" stick welders? Don't for get a copper backing to chill it.
    How about he wire wheel the **** out of it, use acid to remove any last bit, a degreaser wipe followed by panel adhesive a backing under it for support and fill it with more adhesive. Smooth it out and good to go. Wham bam thank you mam.
  28. 52HardTop
    52HardTop
    I see that is the center of the windshield. Isn't there a good size garnish molding that will cover a lot of that?
  29. 1942g506
    1942g506
    I have a welder and not afraid to go after it. Yes it will hide all of it actually.
  30. Yes, weld some metal in, dress it down with a cut off wheel on edge, seal, and back in service.
