What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. guthriesmith
    guthriesmith
    I would think you could post a thread to get help now in this section. Not really much different than me posting a thread about my 87 Chevy pickup.
  2. TrailerTrashToo
    TrailerTrashToo
    Go for it. This is the "Off-Topic" area. The complainers wont see the irony about the "Our-Hobby-Is Dying" threads...
    Russ
  3. The ideaman
    The ideaman
    New daily and VW build.
  4. wicarnut
    wicarnut
    The Blue truck is the color of my truck in 75. It was my first new vehicle, It had a rough life, I crashed it hard 2X in 75 and 76 snow. I purchased a slide in camper for my family as I was racing weekends , we had 3 small kids coming with and sometimes we camped with it before and after racing events, I called it my poor man's motor home. Then I used it for my shop truck for several years, just an FYI forklift truckers use your dropped tail gate as a stop when loading. Then the rust out came, I got used doors and the box from Az., tailgates we learned to take off, got new replacements local. I owned this truck for 10 years, motor, drive line never a problem, 350, manual trans, 3:73 gear. I felt bad selling it, it served me well. the HAMB brings up memories.
  5. wicarnut
    wicarnut
    We spent 6 winters in Apache Junction and the weather was great, the sunsets are the Best I've ever seen. Az. has many beautiful areas, quite a lot of diversity of scenery. We tried to hit every tourist thing, events, scenic area's, I hit the local and big event car shows, happy we did it, enjoyed it, good memories.
  6. Okie Pete
    Okie Pete
    IMG_3964.jpeg The led bulb replaced the original bulb . IMG_3963.jpeg the yellow led bulbs replacing the glow of the vacuum tubes
  7. Okie Pete
    Okie Pete
    Looking forward to the build thread on the 83 Caddie
  8. I got a chance to spend a day on my "Everyday",
    Cut open the "Cats" & got rid of the rotten egg smell, welded them back up & it even sounds much better. I was on a roll until I dropped the oil pressure sending unit down between the back of the engine & the firewall & it wedged itself in....took me 2 hours to get it out. My new Teslong Boroscope sure did come in handy LOL . Started to ****on it up & realized I broke the plastic vacuum fitting for the power brakes off. UGH done for today. Those that have changed oil sending units on an LS can feel my pain!:mad:
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
    chevy57dude, SS327, Okie Pete and 4 others like this.
  9. guthriesmith
    guthriesmith
    So far, I haven’t found anything about working on an LS that I like. Pulled a 6.0 apart recently to change a lifter…only to find out that they aren’t under the valley pan where they should have been and that we have to pull the heads… :mad: Pushed it outside for another day.
    chevy57dude, SS327, Okie Pete and 3 others like this.
  10. This is a 5.3 & I currently have a AFM delete in the OBD port, but I know probably this coming summer I will be pulling it apart to put a cam & lifters that delete the AFM the proper way. Of course the cam will be a little hotter & may put a set of header on it as well...Just can't leave anything stock LOL
    God Bless
    Bill
    chevy57dude, SS327, porkshop and 4 others like this.
  11. iwanaflattie
    iwanaflattie
    Soon..ive been working 4 10s and OT last friday..
    Plus its a 3hr commute...
    Well get there.
  12. CharlieBob
    CharlieBob
    Ford Jailbar with OT powertrain. Longer (7" doors), lower (a lot), wider (5"), fenders raised (2"), hood sectioned (3"), custom bed, etc.
    Started life as a WW2 firetruck, later spent decades on a Reservation. Bullet holes from the outside in, and a big one from the inside out! If only it could talk ...... IMG_8105.JPG IMG_8164.JPG
  13. Basically lost a whole day on the Avalanche between going to get a new fitting and spending a few hours laying on top of the engine trying to get the broken piece out of the back of the intake manifold!
    On a positive note... I now have an oil pressure gauge that works and it feels like I added 100 horsepower by emptying out the cats.
    God bless
    Bill
  14. FrozenMerc
    FrozenMerc
    The '85 hurt the motor over the holidays. #1 is down on compression and has a ton of blow-by, which results in a bunch of oil being pushed out. So I tore the spare motor apart and sent the block and crank off to the machinist so I can build up a short block and swap it out.
    The spare was a spare because it hydro-locked #7 at some point it it's previous life, which made for a nicely shaped rod...
  15. lumpy 63
    lumpy 63
    20260208_164410.jpg So I saw on FlamedAbones thread he had bought one of these alignment tools from Browell bellhousings...I ordered one and just tried it on the camaro engine, totally *****in:D
  16. droplord49
    droplord49
    from Bryan, Tx
    Been working on swapping in a 70's Datsun L16 and auto trans into my wife's 55 Hudson Metropolitan. Still have a couple things to sort out, but it moved under it's own power for the first time today. IMG_E6415.JPG IMG_E6415.JPG IKUM8869.JPG IMG_5732.JPG IMG_5728.JPG IMG_5792.JPG IMG_6428.JPG IMG_6430.JPG
    Oneball, Okie Pete, Sandcrab and 7 others like this.
  17. guthriesmith
    guthriesmith
    I am continuing with my story of not being a fan of working on an LS motor. This 6.2 in my sons SS Camaro is fighting me all the way…
  18. chevy57dude
    chevy57dude
    @lumpy 63 - The alignment tool is great! I went to the site, couldn't figure out how much it cost. (?)
  19. Looks a whole lot easier to change that oil pressure sending unit now Vs what I went through!:eek:
    I will probably be tearing mine apart sometime this summer to get rid of the AFM Junk cam & lifters, so thanks for the picture. Hoping mine will be a little easier, because it is in an Avalanche & it actually looks small in the engine compartment (plenty of room). Thinking about maybe just yanking it out & working on it in a stand.
    God Bless
    Bill
  20. lumpy 63
    lumpy 63
    With shipping it was around $180
  21. How close was it?
    porkshop and Bill's Auto Works like this.
  22. 57 Chevy, C10 ***embly, squarebody cut & buff... never a "dull" moment at Big Daddy's trim and custom lol 20260210_154955.jpg 20260210_142955.jpg 20260210_143000.jpg 20260207_113809.jpg 20260207_113729.jpg
  23. lumpy 63
    lumpy 63
    It was spot on Lloyd. when I did the vette I also used a new lakewood bell I dial indicated it and it too was well within tolerance.
  24. Almost mounted new wheels after having them polished and clear coated....
    Spun a stud on the left rear. Going cut the lug nut off, pull the axle and replace the studs.
    New
    Old
  25. squirrel
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    73ish Chevelle? man that seems awfully conventional... LOL
  27. lumpy 63
    lumpy 63
    Jim is getting soft in his advanced age:p
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    power steering, power disc brakes and maybe (gasp) air conditioning?
